st55 Posted May 29 Posted May 29 Morning All, I have a quick question regarding issues i am having with XREF'S. We have a GA xref attached to most our drawings as it is the base plan. My issue is that i cannot open any drawings with that xref if someone is working on the base xref (if that makes sense). Hope i've explained it well enough. Cheers guys Paul Quote
SLW210 Posted May 29 Posted May 29 I have moved your thread to the AutoCAD Drawing Management & Output Forum. Maybe these will help ... AutoCAD 2022 Help | XLOADCTL (System Variable) | Autodesk Xref files are read-only and cannot be opened in AutoCAD AutoCAD 2022 Help | Commands for Working With External References | Autodesk Quote
