Discus84 Posted June 3, 2025 Posted June 3, 2025 Hi, The object's transparency is set to 50, it does plot as a normal line though. Any ideas? Lu Quote
Discus84 Posted June 25, 2025 Author Posted June 25, 2025 I set the transparency to 10 expecting it to be 10% . It has to be set to 90 instead, Thanks! Quote
troggarf Posted July 11, 2025 Posted July 11, 2025 When you print/plot to PDF make sure that the setting to print with transparency is turned on. 1 Quote
