Discus84 Posted June 4 Posted June 4 Offset command often leaves the previous distance , even after hitting escape. This is in autocad 12. Any ideas why? Quote
BIGAL Posted June 5 Posted June 5 (edited) Trying to think of an answer, maybe, "Why is it so ?" It just happens and has done so since maybe when Autocad was originally coded. I have a dynamic offset lisp type o123 and it will offset an object 123 distance. You can type any Oxxx etc. One little gotcha need to use minus "-" for decimal point in values. eg 12.5 = 12-5 Fillet offset circle.lsp Edited June 5 by BIGAL Quote
Discus84 Posted June 14 Author Posted June 14 This could be converted to frequently used offsets.. o1=.125, o2=.250 etc... Quote
BIGAL Posted June 15 Posted June 15 @discuss no extra defuns needed just type O0-125 and offset is called with that offset as default. So any value but not negative. The - is used instead of "." as the errror check falls over if a "." used. Checking now why not working in my Bricscad sure it did previously. Quote
