I don't know anything about lisp !
I found the lisp to calculate hach area on the web. I would like to ask you who understand lisp to help me calculate the area in m2.
area = 5000 x 5000 = 25m2
(defun C:hatcharea () (hatcharea))
(defun hatcharea ( / ss area i eo pt)
(setq
    ss (ssget '((0 . "hatch")))
    area 0
    i 0
(cond
    ((and(and ss) (> (sslength ss) 0))
        (repeat (sslength ss)
        (setq eo (vlax-ename->vla-object (ssname ss i)))
        (setq area (+ area (vlax-get eo 'Area)))
        (setq i (+ i 1))
        (while (not pt)(setq pt (getpoint "\nSelect area text insertion point >")))
        (command "text" pt "" "" (strcat "Area = " (rtos area 2 2) " sq. units") "")
Edited by SLW210
Added Code Tags!!
Like this?
  (setq
      area 0
      i 0
  (cond
          (setq i (+ i 1))
          (setq area (/ area 1000000.))
          (command "text" pt "" "" (strcat "Area = " (rtos area 2 2) " m2") "")
Edited by Isaac26a
thank you very much @Isaac26a
please see and help me
This lisp calculates the area of a closed polyline.
I want to record the result as you edited
area = 5000x5000 = 25m2
(defun rh:dxf (code lst) (cdr (assoc code lst)))
(defun c:plarea ( / cmde ent e_typ e_lst area vtx x_lst y_lst z_lst x_pt y_pt z_pt c_lst v_lst)
  (cond ( (/= 0 (getvar 'cmdecho)) (setq cmde (getvar 'cmdecho))  (setvar 'cmdecho 0)))
  (while (setq ss (ssget "_+.:E:S" '((0 . "POLYLINE,LWPOLYLINE") (-4 . "<OR") (70 . 1) (70 . 3) (70 . 5)(-4 . "OR>"))))
    (setq ent (ssname ss 0)
          e_typ (rh:dxf 0 (setq e_lst (entget ent)))
          area (getpropertyvalue ent "area")
          v_lst nil
    );end_setq
    (cond ( (= e_typ "POLYLINE")
            (setq ent (entnext ent)
                  vtx (rh:dxf 10 (entget ent))
            );end_setq
            (if (< (length vtx) 3) (setq vtx (reverse (cons 0.0 (reverse vtx)))))
            (while (/= "SEQEND" (cdr (assoc 0 (entget ent))))
              (setq v_lst (cons vtx v_lst)
                    ent (entnext ent)
              );end_setq
            );end_while
            (setq x_pt (/ (apply '+ (mapcar '(lambda (x) (car x)) v_lst)) (length v_lst))
                  y_pt (/ (apply '+ (mapcar '(lambda (x) (cadr x)) v_lst)) (length v_lst))
            );end_setq
            (if (= (setq sum (apply '+ (mapcar '(lambda (x) (caddr x)) v_lst))) 0.0) (setq z_pt 0.0) (setq z_pt (/ sum (length v_lst))))
          ( (= e_typ "LWPOLYLINE")
            (setq z_pt (rh:dxf 38 e_lst))
            (foreach pr e_lst
              (if (= (car pr) 10) (setq v_lst (cons (cdr pr) v_lst)))
            );end_foreach
            );end_setq
    );end_cond
    (setq c_lst (list x_pt y_pt z_pt))
    (entmakex (list (cons 0 "MTEXT")
                    (cons 100 "AcDbEntity")
                    (cons 100 "AcDbMText")
                    (cons 10  c_lst)
                    (cons 40 (getvar 'textsize))
                    (cons 71 5)
                    (cons 72 5)
                    (cons 1 (rtos area 2 3))
              );end_list
    );end_entmakex
  );end_while
  (if cmde (setvar 'cmdecho cmde))
);end_defun
Edited by SLW210
Added Code Tags!!
This is a simple way to get a centroid of a pline.
(setq obj (vlax-ename->vla-object (car ent)))
(setq cpt (osnap (vlax-curve-getStartPoint obj) "gcen"))
Please use Code Tags and better titles for your threads.
