Please help! I need it urgently. Deadline is coming soon. thank you so much .
Due to work requirements, I have to measure the area and write it on the drawing. I use the lisp below but the result is not as expected. I want the result like this; 5000x5000 = 25m2, currently the lisp gives the result 25000000
I would like to ask you to help me fix the result like this. The room area is 5000mm x5000 = 25m2
Thanks for your help
(defun rh:dxf (code lst) (cdr (assoc code lst)))
(defun c:plarea ( / cmde ent e_typ e_lst area vtx x_lst y_lst z_lst x_pt y_pt z_pt c_lst v_lst)
  (cond ( (/= 0 (getvar 'cmdecho)) (setq cmde (getvar 'cmdecho))  (setvar 'cmdecho 0)))
  (while (setq ss (ssget "_+.:E:S" '((0 . "POLYLINE,LWPOLYLINE") (-4 . "<OR") (70 . 1) (70 . 3) (70 . 5)(-4 . "OR>"))))
    (setq ent (ssname ss 0)
          e_typ (rh:dxf 0 (setq e_lst (entget ent)))
          area (getpropertyvalue ent "area")
          v_lst nil
    );end_setq
    (cond ( (= e_typ "POLYLINE")
            (setq ent (entnext ent)
                  vtx (rh:dxf 10 (entget ent))
            );end_setq
            (if (< (length vtx) 3) (setq vtx (reverse (cons 0.0 (reverse vtx)))))
            (while (/= "SEQEND" (cdr (assoc 0 (entget ent))))
              (setq v_lst (cons vtx v_lst)
                    ent (entnext ent)
              );end_setq
            );end_while
            (setq x_pt (/ (apply '+ (mapcar '(lambda (x) (car x)) v_lst)) (length v_lst))
                  y_pt (/ (apply '+ (mapcar '(lambda (x) (cadr x)) v_lst)) (length v_lst))
            );end_setq
            (if (= (setq sum (apply '+ (mapcar '(lambda (x) (caddr x)) v_lst))) 0.0) (setq z_pt 0.0) (setq z_pt (/ sum (length v_lst))))
          ( (= e_typ "LWPOLYLINE")
            (setq z_pt (rh:dxf 38 e_lst))
            (foreach pr e_lst
              (if (= (car pr) 10) (setq v_lst (cons (cdr pr) v_lst)))
            );end_foreach
            );end_setq
    );end_cond
    (setq c_lst (list x_pt y_pt z_pt))
    (entmakex (list (cons 0 "MTEXT")
                    (cons 100 "AcDbEntity")
                    (cons 100 "AcDbMText")
                    (cons 10  c_lst)
                    (cons 40 (getvar 'textsize))
                    (cons 71 5)
                    (cons 72 5)
                    (cons 1 (rtos area 2 3))
              );end_list
    );end_entmakex
  );end_while
  (if cmde (setvar 'cmdecho cmde))
);end_defun
Edited by SLW210
Added Code Tags!!
  (cons 1 (rtos (/ area 1000000) 2 3))
Replace the above with the following.
(cons 1 (strcat (rtos (/ area 1000000.0) 2 3) "m2"))
If you need to change the number of decimal places, change the last argument to
(rtos ... 2 3) to the desired number (for example, 2 for two digits).
(cons 1 (strcat (rtos (/ area 1000000.0) 2 2) "m2"))
If you don't need the suffix "m2", (cons 1 (rtos (/ area 1000000.0) 2 3))
(defun c:plaream2 ( / cmde ent e_typ e_lst area vtx x_lst y_lst z_lst x_pt y_pt z_pt c_lst v_lst ss sum)
  (cond
      (setvar 'cmdecho 0)
  (while
        (-4 . "<OR")
        (-4 . "OR>")
          v_lst nil
    (cond
                ent (entnext ent)
          (setq z_pt 0.0)
        (foreach pr e_lst
    (entmakex
      (list
        (cons 0 "MTEXT")
        (cons 10  c_lst)
        (cons 71 5)
        (cons 72 5)
; (cons 1 (rtos (/ area 1000000.0) 2 3)) ; If you don't need the suffix "m2"
Please use Code Tags for your code (<> in the editor toolbar).
