devitg Posted June 8, 2025 Posted June 8, 2025 How to get a user variable status . I use ACAD VLIDE to make LISP programs, Before I update to 2024 , I got all user global variable by section the defun and do a CHECK selection and it return at the Visual Lisp Console , all global variables . I can not set the way to get it again . Thanks in advance Quote
devitg Posted June 8, 2025 Author Posted June 8, 2025 Solved. It is at General options diagnostic diagnostico.bmp Quote
BIGAL Posted June 8, 2025 Posted June 8, 2025 (edited) A slight variation on the theme, I use Notepad++ so it does not have check variables. I use VLIDE when I am real stuck, also Bricscad Blade checks but does not display a list like VLIDE. Anyway I usually add variable names at end of testing etc. So they can end up like this (X pt1 Y p4 zone a b c pt end start) and so on so wrote a sort them alphabetically then just copy and past back into code a nice sorted list of variable names. Code attached. just copy and paste your variable names when asked, copy the result back to your code. Found this example (defun c:test ( / f d p s a x tam a1 a2 b1 b2 c1 c2 sa sp) (defun c:test ( / a a1 a2 b1 b2 c1 c2 d f p s sa sp tam x) makevars.lsp Edited June 8, 2025 by BIGAL Quote
