In the script below vl-fle-dialog is not recognised and I get the error:-
; error: no function definition: VL-FILE-DIALOG
Is Vl-FILE-DIALOG contained in a library or other resource that I need to load?
<(defun c:SelectFolder ()
  (vl-load-com)
  (setq folder (vl-file-dialog "Select a Folder" nil nil 1))
  (if folder
      ;; Extract the folder name from the full path
      (setq folder-name (vl-filename-base (vl-filename-directory folder)))
      (princ (strcat "\nSelected folder: " folder-name))
    (princ "\nNo folder selected.")
vl-file-dialog is not a function which exists in the AutoLISP API - I'm guessing this code came from an LLM?
I am new to lisp and asked chat gpt. I suspected this was not correct as cannot find reference to that function anywhere on the net.
 rlx kindly gave me the routine below and I have been working on breaking it down to understand the code.
there are 3 sub routines allfolders, allfiles and getshellfolder, that dont appear to do anything....
i am trying to update this c:wbf routine to allow selection of a folder to which the blocks are wblocked to, at present they appear in the folder the parent dwg has been opened from and the path users/me/test seems to be irrelevant...
(defun c:wbf ( / symbolpath adoc item oldfiledia name blk blist oldexpert)
  (setq symbolpath "C:\\Users\\Me\\Test\\")
  (setq adoc (vla-get-ActiveDocument (vlax-get-acad-object)))
  (vlax-For item (vla-get-Blocks adoc)
    (if (not (or (eq :vlax-true (vla-get-isXRef item))
            (eq :vlax-true (vla-get-isLayout item))))
    (setq name (vla-get-Name item))
    (if (/= (substr name 1 1) "*")(setq blist (cons name blist))))))
  (setq oldfiledia (getvar "FILEDIA"))
  (setq oldexpert (getvar "FILEDIA"))
  (setvar "FILEDIA" 0)
  (foreach item blist
    (setq blk (strcat symbolpath item))
    (command "-wblock" blk "="))
  (setvar "FILEDIA" oldfiledia)
(defun allfolders ( d / sf so fo l)
  (defun sf (f / s)(if (< 0 (vlax-get (setq s (vlax-get f 'subfolders)) 'count))
    (vlax-for x s (setq l (cons (vlax-get x 'path) l))(sf x))))
  (setq so (vla-getinterfaceobject (vlax-get-acad-object) "Scripting.FileSystemObject"))
  (setq fo (vlax-invoke so 'getfolder (vl-string-trim "\\/" d)))
  (sf fo) (vl-catch-all-apply 'vlax-release-object (list so))
  (acad_strlsort (mapcar 'dos_path (cons d l)))
;;; (length (allfiles "c:/temp/lisp"))
(defun allfiles ( dir / l f r rl ) (setq l (allfolders dir)) (foreach f l (if (vl-consp (setq r
  (mapcar '(lambda (x) (strcat f x))(vl-directory-files f "*.*" 1)))) (setq rl (append rl r)))) rl)
; generic getfolder routine with possibility to create a new subfolder (GetShellFolder "select path")
(defun GetShellFolder ( m / f s) (if (and (setq s (vlax-create-object "Shell.Application"))
  (setq f (vlax-invoke s 'browseforfolder 0 m 65536 "")))(setq f (vlax-get-property (vlax-get-property f 'self) 'path))
     (setq f nil))(vl-catch-all-apply 'vlax-release-object (list s))
  (if f (strcat (vl-string-right-trim "\\" (vl-string-translate "/" "\\" f)) "\\"))) >
Maybe start at Lee-macs "Browse for folder lisp.
Lots of errors in that code.
If you say want a directory under the current dwg location use this example. Dwgpre is the directory name.
; check that block directory exists
(setq dwgpre (strcat (getvar "dwgprefix") "\block"))
(if (= (vl-file-directory-p dwgpre) nil)
(vl-mkdir dwgpre)
Please use Code Tags (<> in the editor toolbar), I have  asked you a few times now.
Try using Lee Mac's and AfraLISP sites to learn AutoLISP and VLISP instead of Chat GPT.
You can also use the Developers Guide in your AutoCAD help.
i am using them ?
what is the problem?
thanks for the resources.  i have a lot of experience with vb but the constructs are very different in lisp.  Have Autodesk made a commitment to lisp or will things move towards pyhthon, c etc ??
couldn't be easier :
(defun c:t1 ( / folder)
  (if (setq folder (GetShellFolder "Select the folder of your dreams"))
    (alert (strcat "The folder you selected was :\n " folder))
    (alert "Folder selection aborted")
2 hours ago, jamami said:
i am using them ?
Thanks for the help
