Power dimensioning window not showing
My co-worker is having an odd problem.
When selecting the POWER DIMENSION from the DIMENSION panel the editor does not appear as a tab at the top.
Has anyone else had this issue and solved it?
Thanks,
Bob
I moved your thread to the Mechanical & MDT Forum.
What version of AutoCAD Mechanical is your co-worker using?
Is the co-worker using the Mechanical Profile?
Did you check AMPOWERDIMEDITOR = 1?
If not that, you might try a reset of AutoCAD Mechanical to default.
Thank you SLW210.
He tried/confirmed all three suggestions but with no luck. The tool bar just want show up.
In all fairness, he has reached out to Autodesk for help and they haven't found the issue yet either.
And Martin Anderson, he has reinstalled the software several times with no luck.
What version of AutoCAD Mechanical?
Computer specifications, OS, Graphics Card and driver?
A complete Uninstall and Reinstall may be needed, did Autodesk do that?
