Danielm103 Posted June 12, 2025 Posted June 12, 2025 (edited) Reads an Excel value into a field import traceback from pyrx import Rx, Ge, Gi, Db, Ap, Ed import openpyxl as xl # Some notes # - AcFdFieldEvaluatorLoader and AcFdFieldReactor are embedded (BricsCAD does not have the reactors) # - if you follow the normal %<\MyFieldID fcode>%, it should pick up your evaluator # - Fields are like custom objects, name and evalname(FieldID) should be unique if you plan on sharing # - AutoCAD caches the last evaluation, so of the evaluator it not loaded, your data should still show # %<\XLSXField M:\\Dev\\Projects\\PyRxGit\\tests\\media\\testdata.xlsx|Show|A1>% # %<\XLSXField M:\\Dev\\Projects\\PyRxGit\\tests\\media\\testdata.xlsx|Show|B1>% # %<\XLSXField M:\\Dev\\Projects\\PyRxGit\\tests\\media\\testdata.xlsx|strings|A4>% print("added command - addevaluator") print("added command - remevaluator") print("added command - makeField") # you may not need to override all of these, in AutoCAD it's enough just to override # format, or evaluate. # for platforms that do not support begin/endEvaluateFields, use command ended event # or on idle to clear your cache class FieldEvaluator(Db.FieldEvaluator): def __init__(self, name, evalname): Db.FieldEvaluator.__init__(self, name, evalname) self.cache = {} def getValueFromXL(self, field: Db.Field): fcode = field.getFieldCode(Db.FieldCodeFlag.kFieldCode).strip("\\XLSXField") if fcode in self.cache: return str(self.cache[fcode]) path, sheet, cell = fcode.split("|") workbook = xl.load_workbook(filename=path.strip(), read_only=True) worksheet = workbook[sheet] return str(worksheet[cell].value) def format(self, field: Db.Field): print("\nformat") return self.getValueFromXL(field) def compile(self, field: Db.Field, db: Db.Database, result: Db.AcValue): try: print("\ncompile") result.setString(self.getValueFromXL(field)) return Db.FieldEvalStatus.kSuccess except Exception as err: traceback.print_exception(err) return Db.FieldEvalStatus.kOtherError def evaluate( self, field: Db.Field, ctx: int, db: Db.Database, result: Db.AcValue ) -> Db.FieldEvalStatus: try: print("\nevaluate") result.setString(self.getValueFromXL(field)) return Db.FieldEvalStatus.kSuccess except Exception as err: traceback.print_exception(err) return Db.FieldEvalStatus.kOtherError # not in ZRX def beginEvaluateFields(self, ctx: int, db: Db.Database): try: print("\nbeginEvaluateFields") self.cache.clear() except Exception as err: traceback.print_exception(err) # not in ZRX def endEvaluateFields(self, ctx: int, db: Db.Database): try: print("\nendEvaluateFields") self.cache.clear() except Exception as err: traceback.print_exception(err) evaluator = FieldEvaluator("XLSX Field", "XLSXField") @Ap.Command() def makeField(): try: db = Db.curDb() fld = Db.Field( "%<\\XLSXField M:\\Dev\\Projects\\PyRxGit\\tests\\media\\testdata.xlsx|strings|A4>%" ) fld.evaluate() mt = Db.MText() db.addToCurrentspace(mt) mt.setField(fld) except Exception as err: print(err) @Ap.Command() def addevaluator(): try: engine: Db.FieldEngine = Db.FieldEngine.getEngine() engine.registerEvaluator(evaluator) except Exception as err: print(err) @Ap.Command() def remevaluator(): try: engine: Db.FieldEngine = Db.FieldEngine.getEngine() engine.unregisterEvaluator(evaluator) except Exception as err: print(err) Edited October 10, 2025 by Danielm103 update 1 Quote
