Hi all,
I have a lisp which get the X & Y coordinates with leader, text. But it would be very useful if the coordinates comes with MLEADER (Text/Arrow height - 2.5).
Please help me out here anyone
What LISP?
Get the X&Y coordinates of what?
Can you post a drawing? Preferably a before and after example and a list of the steps you take.
See if this recommendation works for you.   There are some LISPs in the thread as well.
On 6/14/2025 at 3:18 AM, kathir said:
Hi all,
Welcome to the forum!
If I understand your issue, you give the function a point, and it creates a leader to the point, along with a label with the coordinates. What you want now is a multileader instead of a plain leader.
I wrote a LISP function that creates a multileader. It's on the forum somewhere. Surely there are other versions. It's not as simple as calling a command, you have to define an entity. With that, it should be easy to insert the coordinates as the text.
Here's some old code to place an mleader with X Y coordinates. They do not automatically update if moved.
(defun c:lp (/ ml mle p1 p2)
  (if (and (setq p1 (getpoint "\nPick point to label: "))
	   (setq p2 (getpoint (setq p1 (trans p1 0 1)) "\nPick point to label: "))
    (progn (command "._mleader" p1 (trans p2 0 1) "")
	   (setq ml (vlax-ename->vla-object (setq mle (entlast))))
	   (entmod (subst (cons 8 "northing_easting") (assoc 8 (entget mle)) (entget mle)))
	   (vla-put-textstring ml (strcat "E " (rtos (car p1) 2 2) "\\\PN " (rtos (cadr p1) 2 2)))
  • 1 month later...
Here's the code. I hope this helps you. The MLeader style follows your current style.
Looking for tools to speed up your workflow? Explore this resource: https://lispautocad.gumroad.com/l/eezilo
(defun C:DV_MLP (/ pt x y text)
  (vl-load-com)
  (setvar "CMDECHO" 0)
  (setq pt (getpoint "\nPick point: "))
  (if pt
      (setq x (rtos (car pt) 2 3))
      (setq y (rtos (cadr pt) 2 3))
      (setq text (strcat "(" x " ; " y ")"))
      (command "._MLEADER" pt pause text)
    (princ "\nNo Point selected!")
  (setvar "CMDECHO" 1)
Edited by DATVO
  (vl-load-com)
  (if pt
Good start.
A few points if you like:
- what would happen if a user pressed ESC while Mleader command is active?
- What's the need of function vl-load-com in your routine?
- You assumed that the system variable CMDECHO was set to 1 but it could be the contrary.
First, the code sets CMDECHO to 0 to prevent program from displaying commands like MLEADER or its interactions in the command line. This helps keep cleaner while the program runs. At the end of the program, the code resets CMDECHO to 1, which is AutoCAD's default setting.
I copied my old file into this one, so I probably forgot to remove that line. But in this code, it's not necessary. 🤣
The command will cancel.
... And the system variable would still remains you set it firstly. Right? 😉
The OP disappeared without answering any questions.
  • Agree 1
  • 9 months later...
