Siberian Posted January 14, 2008 Posted January 14, 2008 Is there an option to make a viewport stay on top of another and not have the underlying one shine through? Or do I have to line up their boundaries to prevent this? Quote
watso75 Posted January 14, 2008 Posted January 14, 2008 The only way i found around this is to use the wipeout command in model space of the underlying viewport. Basically to mask off the unwanted area. This then gives you the option to turn off that particular layer if you wish to have more viewports where you want that part of the drawing showing. A basic way around the problem but can work. Quote
Guest Alan Cullen Posted January 14, 2008 Posted January 14, 2008 This has been asked a few times before. I can't remember the answer because it was never something that concerned me. I think it had something to do with cycling through the viewports somehow to get the one you want on top. Maybe do a search and check out similar threads listed below here. Quote
GE13579 Posted January 14, 2008 Posted January 14, 2008 I remember reading this- wasto75's response is one way, or you can create a viewport out of a polyline to the shape of the "background" viewport, or I think there is a way to trim the viewport? There isn't a way to cycle through them though, just to clarify :wink: Quote
Siberian Posted January 14, 2008 Author Posted January 14, 2008 I solved it using VPCLIP, but there really should be a way to make them able to overlap... Quote
quamper Posted January 14, 2008 Posted January 14, 2008 Why would you want to have them overlap since you can create irregular shaped viewports that achieve what seems to me the same effect? Maybe I'm misunderstanding the use/benefit. Quote
SLW210 Posted January 14, 2008 Posted January 14, 2008 Try reading this thread. http://www.cadtutor.net/forum/showthread.php?t=16691 Quote
quamper Posted January 14, 2008 Posted January 14, 2008 Ok I see what you're talking about. Actually having one viewport completely over/inside another one. If it's just a matter of overlapping that's different and thats what I was thinking about. Quote
rustysilo Posted January 14, 2008 Posted January 14, 2008 I always just moved/adjusted them as needed while working with them so they didn't overlap 100%. It seems that there is a way to cycle through them, but I never remember that one as it's not very often I have this situation. Quote
GE13579 Posted January 15, 2008 Posted January 15, 2008 I always just moved/adjusted them as needed while working with them so they didn't overlap 100%. It seems that there is a way to cycle through them, but I never remember that one as it's not very often I have this situation. I think in this instance the requirement isn't for viewports directly on top of one another, but the cycle you refer to is "CTRL+LEFT MOUSE". This can be used on lines and viewports alike. I think this is what you mean? Quote
cadmatic Posted December 31, 2013 Posted December 31, 2013 ctrl R cycles through the viewports once one has been selected. Quote
Simbel Posted December 8, 2023 Posted December 8, 2023 Ctrl R is to go from a view to another view in the same page. Quote
Steven P Posted January 12, 2024 Posted January 12, 2024 Am I in some sort of parallel universe were questions from 16 years ago are answered with 1 liners? 1 Quote
BIGAL Posted January 13, 2024 Posted January 13, 2024 Yeah almost forgot my keys after 16 years, oh yeah keyhole viewport. 1 Quote
CyberAngel Posted January 22, 2024 Posted January 22, 2024 On 1/12/2024 at 3:02 PM, Steven P said: Am I in some sort of parallel universe were questions from 16 years ago are answered with 1 liners? Occupational hazard. Be glad someone out there is paying attention. Quote
