LIU Posted June 21, 2025 Posted June 21, 2025 (edited) HI , WHEN ARCHITECTURAL UNIT IS SELECTED IN A DRAWING, THEN FOR 2.6MM TEXT, WHAT WILL BE ENTERED IN TEXT HEIGHT BOX IN TEXT TAB OF DIMENSION-STYLE-MANAGER DIALOG ? DONT THINK THIS IS A FOOL'S QUESTION. YOU CAN IMAGINE, HOW BEGIINERS STRUGGLE !!!!! Edited June 21, 2025 by LIU SPELLINGS TESTED Quote
ReMark Posted June 21, 2025 Posted June 21, 2025 I have a few questions. 1) Did you create your drawing using the acadiso.dwt drawing template file (for metric drawings)? 2) Will your dimensions be placed entirely in model space or in paper space? 3) Will you be making use of Annotative dimensions? 4) Are you familiar with the DIMSCALE command and scale factors? Quote
BIGAL Posted June 21, 2025 Posted June 21, 2025 " ARCHITECTURAL UNIT IS SELECTED " you are mixing to different units imperial and metric, which one are you using, or are you trying to draw in feet and inches but normally work in metric ? 2.5mm is like 0.125 in imperial. Quote
SLW210 Posted September 1, 2025 Posted September 1, 2025 On 8/31/2025 at 6:59 AM, oddssatisfy said: Enter 2.6 in the Text Height box. If Architectural units are being used, entering 2.6 in the Text Height box would make the text 2.6" in Architectural format that's shown as 2- 15/32". The equivalent to 2.6mm text height for Architectural is 1/8" or .125". Quote
