Mike1234 Posted June 21, 2025 Posted June 21, 2025 Yesterday I got a new PC and downloaded Autocad 2026LT, I didnt like the interface and eventually worked out how to get my old 2020LT interface back, how my old system operated if I wanted to trim or extend to an object I would click the trim icon, select the object/objects to be trimmed to, right click then click on the line to be trimmed right, how and where in the settings can I set these settings regards Mike Quote
ReMark Posted June 21, 2025 Posted June 21, 2025 Have you tried the TRIMEXTENDMODE system variable? Quote
Mike1234 Posted June 21, 2025 Author Posted June 21, 2025 23 minutes ago, ReMark said: Have you tried the TRIMEXTENDMODE system variable? No I haven't, how do I do that Quote
ReMark Posted June 21, 2025 Posted June 21, 2025 Type the system variable at the Command line then press the Enter key. Quote
Discus84 Posted June 25, 2025 Posted June 25, 2025 I often use T for trim and then hit spacebar twice - this way you don't need to specify a fence and it cuts through all lines. If you want to cut through a group you turn off group mode with ctr+shift+a. This works in Autocad 12. Quote
