KLKSMILE Posted April 27, 2009 Author Share Posted April 27, 2009 oh - sorry - are you referring to the WBlocking comment? I didn't know what that ment. Quote Link to comment Share on other sites More sharing options...
KLKSMILE Posted April 27, 2009 Author Share Posted April 27, 2009 I c - well then I think that's it! You Rock! Thank you so much! Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted April 27, 2009 Share Posted April 27, 2009 Oh, sorry, maybe I didn't explain it well enough: When I output the drawings, I WBlock each border to the output file. But I can't access the output file to make changes on it (hence I can't zoom extents in the output file). Which is why I also had to insert the Date Tag in the main drawing before I Wblock'ed it. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted April 27, 2009 Share Posted April 27, 2009 This will provide you with another option: a script is created which, if run, will save all the drawings with zoom extents. ;; Drawing Cutter V4, by Lee McDonnell 27.04.2009 (defun c:DwgCut (/ *error* vlst ovar tOff doc file path ss dSs miPt maPt winLst iSs i Nme fname wBss wLst Scr sfile docLst) (setq tOff 1.6) ; <<-- Adjust this if necessary (setq Scr T) ; <<-- Write Script to Zoom Extents (T or nil) (vl-load-com) (defun *error* (msg) (if ovar (mapcar 'setvar vlst ovar)) (if (not (member msg '("Function cancelled" "quit / exit abort"))) (princ (strcat "\nError: " msg)) (princ "\n<<-- Function Cancelled -->>")) (princ)) (setq vlst '("CLAYER" "OSMODE") ovar (mapcar 'getvar vlst)) (setvar "OSMODE" 0) (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))) (or (tblsearch "LAYER" "DATESTAMP") (vla-put-color (vla-add (vla-get-Layers doc) "DATESTAMP") acYellow)) (setq file (getfiled "Select Location for New Files" (if $def $def "") "dwg" 1)) (if (not (setq $def file)) (exit)) (setq path (vl-filename-directory file)) (if (setq ss (ssget "X" '((0 . "INSERT") (2 . "BORDER")))) (progn (foreach Obj (mapcar 'vlax-ename->vla-object (mapcar 'cadr (ssnamex ss))) (vla-getBoundingBox Obj 'miPt 'maPt) (setq winLst (mapcar (function (lambda (x) (vlax-safearray->list x))) (list miPt maPt))) (vla-ZoomExtents (vlax-get-acad-object)) (setq iSs (ssget "_C" (car winLst) (cadr winLst)) i 2) (foreach ent (vl-remove-if 'listp (mapcar 'cadr (ssnamex iSs))) (if (and (eq "TitleText" (cdr (assoc 8 (entget ent)))) (member (cdr (assoc 0 (entget ent))) '("TEXT" "MTEXT"))) (setq Nme (cdr (assoc 1 (entget ent)))))) (if (member (strcat Nme ".dwg") (vl-directory-files path "*.dwg" 1)) (progn (setq Nme (strcat Nme (chr 40) (itoa i) (chr 41)) i (1+ i)) (while (member (strcat Nme ".dwg") (vl-directory-files path "*.dwg" 1)) (setq Nme (strcat (substr Nme 1 (- (strlen Nme) 3)) (chr 40) (itoa i) (chr 41)) i (1+ i))))) (setq fname (strcat path "\\" Nme ".dwg")) (if (setq dSs (ssget "X" '((0 . "*TEXT") (8 . "DATESTAMP")))) (mapcar 'entdel (mapcar 'cadr (ssnamex dSs)))) (ssadd (Make_Text (polar (car winLst) pi (- tOff 0.86)) (DStamp Nme) (/ pi 2)) iSs) (setq wBss (vla-add (vla-get-SelectionSets doc) "wBss") wLst (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex iSs))))) (vla-additems wBss (vlax-make-variant (vlax-safearray-fill (vlax-make-safearray vlax-vbobject (cons 0 (1- (length wLst)))) wLst))) (vla-wBlock doc fname wBss) (vla-delete (vla-item (vla-get-SelectionSets doc) "wBss")) (setq docLst (cons fname docLst))) (if Scr (progn (setq sfile (open (strcat path "\\DwgCut.scr") "w")) (foreach dc docLst (write-line (strcat "open \"" dc "\" zoom extents qsave close") sfile)) (close sfile)))) (princ "\n<!> No Borders Found <!>")) (mapcar 'setvar vlst ovar) (princ)) (defun Make_Text (pt val rot) (entmakex (list '(0 . "TEXT") (cons 8 "DATESTAMP") (cons 10 pt) (cons 40 (getvar "TEXTSIZE")) (cons 1 val) (cons 50 rot) (cons 7 (getvar "TEXTSTYLE")) '(71 . 0) '(72 . 0) '(73 . 1) (cons 11 pt)))) (defun DStamp (DNme / cAP cDate cMon cHrs cMin tStr) (setq cAP "AM" cDate (rtos (getvar "CDATE") 2 4) cMon (nth (1- (atoi (substr cDate 5 2))) '("JAN" "FEB" "MAR" "APR" "MAY" "JUN" "JUL" "AUG" "SEP" "OCT" "NOV" "DEC")) cHrs (atoi (substr cDate 10 2)) cMin (substr cDate 12 2)) (cond ((<= 13 cHrs) (setq cAP "PM" cHrs (itoa (- cHrs 12)))) ((= 12 cHrs) (setq cAP "PM" cHrs (itoa cHrs)))) (setq tStr (strcat "DRFT: KLK FILE:" DNme " DATE: " cMon (chr 32) (substr cDate 7 2) ", " (substr cDate 1 4) " TIME: " cHrs (chr 58) cMin (chr 32) cAP)) tStr) Quote Link to comment Share on other sites More sharing options...
KLKSMILE Posted August 13, 2009 Author Share Posted August 13, 2009 HI! It's been awhile... SO I started noticing that the split up files are not inserted at the origin, this creats a problem when I need to re-edit the split up file. Is there a way to modify the lisp program to split up the drawings and insert each bottom left corner of the "BORDER" block at 0,0? Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 13, 2009 Share Posted August 13, 2009 The way my program functions, I think you would have to edit the new files - perhaps through the use of a script. Quote Link to comment Share on other sites More sharing options...
KLKSMILE Posted August 13, 2009 Author Share Posted August 13, 2009 hmm...i c So will I have to open each file and then run a script? Quote Link to comment Share on other sites More sharing options...
KLKSMILE Posted August 13, 2009 Author Share Posted August 13, 2009 I really don't know much about writing script but I was wondering if this idea would work... If I make a point on a specific layer at the bottom left corner of every BORDER block before I split it up, then can I open each file after it is split and somehow move everything on the page from the location of that point to the origin using a script??? Or is there a better way to do it? Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 14, 2009 Share Posted August 14, 2009 A script is very easy to make - don't worry. The script works as if you were entering commands at the command line, and a space or new line is translated as the user hitting enter. Hence you might want something like: open "C:/Users/....dwg" move ... etc Perhaps you could use a short LISP routine within the script to move the objects, something like this maybe, to move the basepoint of your border block to 0,0,0: (defun mvObj (/ oldos ss blk bPt) (setq oldos (getvar "OSMODE")) (if (and (setq ss (ssget "_X")) (setq blk (ssget "_X" '((0 . "INSERT") (2 . "BORDER"))))) (progn (setq bPt (cdr (assoc 10 (entget (ssname blk 0))))) (setvar "OSMODE" 0) (command "_.move" ss "" bPt '(0 0 0)))) (setvar "OSMODE" oldos) (princ)) Then call it within the script: open "C:/Users/...dwg" (mvObj) qsave close Hope this helps, Lee If in doubt, just google AutoCAD scripts. Quote Link to comment Share on other sites More sharing options...
KLKSMILE Posted August 14, 2009 Author Share Posted August 14, 2009 So I tried a bunch of differnt things but couldn't get this to work. When I open one of the split files and click on the border block , the insert point is usually somewhere far away. I think this is why it isn't working? Also, is there supposed to be a C: infront of mvObj in the LISP routine? I attached one of the split files...do you think you could maybe try it? HANSCF04.dwg Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 14, 2009 Share Posted August 14, 2009 When I open one of the split files and click on the border block , the insert point is usually somewhere far away. I think this is why it isn't working? I see, perhaps we can do something with EXTMIN/MAX Also, is there supposed to be a C: infront of mvObj in the LISP routine? No, I defined it as a sub-function and called it as such Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 14, 2009 Share Posted August 14, 2009 Just curious, why are all your dimensions exploding? Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 14, 2009 Share Posted August 14, 2009 Perhaps include something like this in the script: (defun mvObj (/ oldos ss bPt) (setq oldos (getvar "OSMODE") miP (getvar "EXTMIN")) (if (setq ss (ssget "_X")) (progn (setq bPt (polar miP 0 0.4)) (setvar "OSMODE" 0) (command "_.move" ss "" bPt '(0 0 0)))) (setvar "OSMODE" oldos) (princ)) Quote Link to comment Share on other sites More sharing options...
KLKSMILE Posted August 14, 2009 Author Share Posted August 14, 2009 Sweet - it worked! Is there a way to then zoom extent each file, save it, and then close it? Also, in the script file, can I run all the drawing files I want to do this to at once? Maybe by just putting the same script line with each different file name? Quote Link to comment Share on other sites More sharing options...
KLKSMILE Posted August 14, 2009 Author Share Posted August 14, 2009 Just curious, why are all your dimensions exploding? That is the way out drafting department does it...I get a lot of headaches from them. Quote Link to comment Share on other sites More sharing options...
KLKSMILE Posted August 14, 2009 Author Share Posted August 14, 2009 oK - so I got the zoom extents, save, close to work. Is there some way to enter everyfile into the script program so that I only have to run the program once? Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 14, 2009 Share Posted August 14, 2009 That is the way out drafting department does it...I get a lot of headaches from them. Thats CRAZINESS! Why would they do that...??? That is the number 1 thing you SHOULDN'T do with dimensions! oK - so I got the zoom extents, save, close to work. Is there some way to enter everyfile into the script program so that I only have to run the program once? Yes, just put the same thing on a new line I'm guessing you have something like this: open "C:/Users/test.dwg" (mvObj) zoom e qsave close open "C:/Users/test2.dwg" (mvObj) zoom e qsave close Or, you can even create a LISP program that will write a script for you I added that facility on the end of your last program. Quote Link to comment Share on other sites More sharing options...
KLKSMILE Posted August 17, 2009 Author Share Posted August 17, 2009 So I have no idea why, but I can not run the dwgcut.lsp file now. I keep getting the following error message: Command: DwgCut Command: Error: bad argument type: stringp 10 Command: I even tried replacing the whole lisp file with one I sent to someone that I know worked. I think it has something to do with AutoCAD and not with the actual program. Any suggestions? Quote Link to comment Share on other sites More sharing options...
KLKSMILE Posted August 17, 2009 Author Share Posted August 17, 2009 I have also tried running the file on several different dwgs - one's that I could split apart on Friday and now it gives me the above message. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 17, 2009 Share Posted August 17, 2009 I would have to see the version you are using Quote Link to comment Share on other sites More sharing options...
