신민수 Posted June 30, 2025 Posted June 30, 2025 (edited) 이걸 지금 오토캐드2026 무료버전으로 그리려고 하거든 이것에 대한 방법을 자세히 쉽게 설명해줘 Quote Now that I'm going to draw this as a free version of Autocad 2026, please explain in detail how to do this. Edited June 30, 2025 by SLW210 Translated to English Quote
CyberAngel Posted June 30, 2025 Posted June 30, 2025 I would start with studying the commands RECTANGLE, ARRAY, and DONUT. Also linetypes and dimensions. Quote
BIGAL Posted June 30, 2025 Posted June 30, 2025 Drawing a complex reinforcement bar slab is difficult. A good idea would be to look at the Array command. 14@200, Array pickbar Enter R Col 14 200 Row 1 3xEnter. You swap row and col for horizontal and vertical arrays. It is the sort of thing you would use a lisp to draw. But you would start with very simple REO patterns then get more and more complex. 14@200 in lisp would be pick reo-line, enter spacing, enter number, all done. The labels again a lisp by dragging over the lines and adding a donut at each bar and adding the label details. There may be some draw reinforcement details lisps out there, you need to google, they may be free or at a cost. Quote
