Upper Slab Drawing How to Draw Autocad
이걸 지금 오토캐드2026 무료버전으로 그리려고 하거든 이것에 대한 방법을 자세히 쉽게 설명해줘
Quote
Now that I'm going to draw this as a free version of Autocad 2026, please explain in detail how to do this.
Edited by SLW210
Translated to English
  • SLW210 changed the title to Upper Slab Drawing How to Draw Autocad
I would start with studying the commands RECTANGLE, ARRAY, and DONUT. Also linetypes and dimensions.
Drawing a complex reinforcement bar slab is difficult. A good idea would be to look at the Array command. 14@200, Array pickbar Enter R Col 14 200 Row 1 3xEnter. You swap row and col for horizontal and vertical arrays.
It is the sort of thing you would use a lisp to draw. But you would start with very simple REO patterns then get more and more complex. 14@200 in lisp would be pick reo-line, enter spacing, enter number, all done. The labels again a lisp by dragging over the lines and adding a donut at each bar and adding the label details.
There may be some draw reinforcement details lisps out there, you need to google, they may be free or at a cost.
