PGia Posted yesterday at 08:56 AM Posted yesterday at 08:56 AM Hi Good morning everyone I've searched the internet for information about this without success, so I thought I'd ask this here. Is it possible to detect with Lisp if any Windows application running is doing so with administrator privileges? Quote
lido Posted 14 hours ago Posted 14 hours ago I think you could do this by testing whether an operation that requires administrative rights can be performed. For example, copying a file to the Windows\System folder. Quote
mhupp Posted 12 hours ago Posted 12 hours ago (edited) like lido said In AutoLISP, cannot directly check for Windows Admin privileges, because AutoLISP is sandboxed within AutoCAD and cant see those types of windows things. tho I wouldn't try and copy files into sys folder. because if you do (admin rights) you would have a bunch of junk files in there. then the next step is to delete the copied file. that is a hop skip and a jump away from delete something needed. I suggest using cmd prompt. it can list admin users and you can output that to a txt file that autocad can then read. if user name true. something like "net localusers administrators > c:\admintest.txt" Edited 12 hours ago by mhupp 1 Quote
Steven P Posted 11 hours ago Posted 11 hours ago what is your end goal with detecting privileges / admin access? There might be other ways to do what you want of course. Quote
PGia Posted 7 hours ago Author Posted 7 hours ago Thanks for the answers. I’ve done some research and found that all processes invoked from AutoCAD inherit the same privilege level. Therefore, it may be enough to know the privilege level with which AutoCAD is running (although ideally, it should work to check any process). I need this to predict whether a task that requires privileges can be carried out or not Quote
BlackBox Posted 7 hours ago Posted 7 hours ago 6 minutes ago, PGia said: Thanks for the answers. I’ve done some research and found that all processes invoked from AutoCAD inherit the same privilege level. Therefore, it may be enough to know the privilege level with which AutoCAD is running (although ideally, it should work to check any process). I need this to predict whether a task that requires privileges can be carried out or not Post your code. Those that know how do this may feel that it's sus to 'check privileges to see if a task can be carried out', based on what little info you've posted, FWIW. Quote
GLAVCVS Posted 3 minutes ago Posted 3 minutes ago 7 hours ago, PGia said: Thanks for the answers. I’ve done some research and found that all processes invoked from AutoCAD inherit the same privilege level. Therefore, it may be enough to know the privilege level with which AutoCAD is running (although ideally, it should work to check any process). I need this to predict whether a task that requires privileges can be carried out or not Hi Indeed, any process started from AutoCAD will inherit its privilege level. For example, if AutoCAD opens an instance of Word, that instance will inherit the same privilege level as AutoCAD. However, if a Word instance is already running and AutoCAD starts controlling it, its privilege level might be different. In that case, it might be necessary to check it in order to warn the user. Could your issue be something similar to that? As Mhupp says, there is no direct way to determine this from VLisp. But there are some tricks to achieve it: For example: (defun acadAdmin? (/ arch r ruta ruta1 f sh) (if (findfile (setq ruta1 (strcat (getenv "TEMP") "\\acAdmin.si"))) (vl-file-delete ruta1) ) (if (setq arch (open (setq ruta (strcat (getenv "TEMP") "\\ea.bat")) "w")) (progn (write-line "@echo off net session >nul 2>&1 if %errorlevel% == 0 ( echo SI> \"%temp%\\acAdmin.si\" )" arch ) (close arch) (setq sh (vlax-create-object "WScript.Shell")) (vlax-invoke sh 'Run ruta 0 :vlax-true) (vlax-release-object sh) (vl-file-delete ruta) (if (setq r (findfile ruta1)) (progn (vl-file-delete ruta1) T ) ) ) ) ) This returns T or nil whether AutoCAD is running as admin or not. Simply write a .bat file and run it Quote
