Hi , I use this lisp for years but I have a problem. When I Polyline on layout and select to create viewport from object , when I select the new viewport in properties say VIewport (1) and not Viewport. Then when  I run the attach lisp to create the grid on viewport say that no viewport selected. Can any one help me to fix this ?
Thanks
Surveygridneg.lsp
It says Viewport (1) because you've created a Viewport by object (Polyline), so they're linked.
Your code works fine here and only seems to error when the Viewport is on a locked layer, and the linked Polyline is not... but I am unable to produce the 'no viewport selected' you mentioned.
Is any way the code to support  Viewport (1) ?
Thanks
Thanks
It already supports that.
Viewport (1) just means that there's 1 object linked... click the dropdown and you'll see the Viewport and Polyline.
The code only allows selection of "VIEWPORT", so when you select it on screen, the Polyline is ignored.
so you said to add support viewports and polylines?
Something like this, takes into account the twist in a viewport.
