The Attribute Extraction on blocks with the same name and the same insertion point gives false results.
For example, we use block called FITTING, with 3 attributes - NAME, KEY, NOTES. In some cases, there are more than one fittings in one point, and we insert multiple blocks FITTING in this point, each with different value, like:
NAME I KEY I NOTES
DAV(kit) d1/d2=110/63 I 102 I For deep montage
Elbow BW d110 SDR11 I 94 I PE(100)
TA(kit) d63 SDR11 I 12 I PE(80)
The result after Attribute Extraction on those three blocks, inserted in the same point is
Block Name I Count I NAME I KEY I NOTES
FITTING I 3 I TA(kit) d63 SDR11 I 12 I PE(80)
Which is obviously not the correct result. I'm using AutoCAD 2004.
Is there any solution to this problem?
I would really appreciate an answer to my problem.
Hmm.. not sure whats happening with the Attribute Extraction command, but I could probably write you a LISP to extract the values - although they would be written to a csv excel file, so you may need to copy paste into a proper Excel Doc.
I'm looking forward to some assistens with this problem.
That's doesn't sound right. Can you post a sample file along with the attribute extraction template. file? -David
Hello
A lisp (french) who count block's, taking into account or not (depending on the level indicated, 0 = no) the value of the attribute.
The result can be written in a text file that can then import into excel
Lstatt.lsp
Thank you, it work just fine.
