Howdy,
A regular task I perform is manually moving text to improve legibility, occasionally there are hundreds of items to move. Looking for any suggestions for streamlining this process making it less labour/time intensive. Open to using LISP, commands and any other techniques you may think is helpful.
Thanks in advance
Can you post a before and after .dwg?
Text or MText?
Considering the many different places that text could be moved, I think that there will never be a completely clear drawing produced without manual intervention.
In some congested instances, I have been known to use leaders to show which ground level refers to which spot.
Text size is also a significant factor.
