We like everyone to use the same font style, so we created the program below. However, there are a few cases MText especially, where the style and font might be in out of sink and so the font does not change.
Is there a way to change the font file, by itself?
(defun C:UpdateAllText ( / acadobject acaddocument styleROMANS ssAllText ssCount entText oldText newText)
; Set initial variables
(setq acadobject (vlax-get-Acad-Object))
(setq acaddocument (vla-get-activedocument acadobject))
; Set "Style-Romans" - If Not already created
(setq styleROMANS (vla-add (vla-get-textstyles acaddocument) "Style-Romans"))
(vla-put-fontfile styleROMANS "Romans.shx")
(vla-put-height styleROMANS 0.000)
(vla-put-obliqueangle styleROMANS 0.0)
(vla-put-width styleROMANS 1.0)
(if (setq ssAllText (ssget "x" '((-4 . "<OR") (0 . "TEXT") (0 . "MTEXT") (-4 . "OR>"))))  ; Get only specific entity
(setq ssCount (sslength ssAllText))
(while (setq entText (ssname ssAllText 0))
(setq oldText (entget entText))
(setq newText (subst (cons 7 "Style-Romans")(assoc 7 oldText) oldText))
(entmod newText)
(ssdel entText ssAllText)
(command "Regen")
I tried using the vlax-put-property command; but I am not sure if there is a property name and if yes what it is. I tried some of the obvious combinations.
(vlax-put-property (vlax-ename->vla-object entText)
'fontfile "Romans.shx")
I also tried the vla-put-textfont command.
 (vla-put-textfont (vlax-ename->vla-object entText) "Romans.shx")
1) Is what I am trying to do, even possible?
2) General Question with vlax-put-property:
Can you simply relate the "property" part of vlax-put-property command to the label on the property palette?
