I made up this one or 2 upgrades ago:
(defun c:setupworkspace ( / MyWorkspace )
  ;;Get workspace name to edit menubars later
  (setq MyWorkspace (getvar "wscurrent") )
  ;;close ribbon
  (command "ribbonclose")
  ;;Show menubars / toolbar
  (setvar 'menubar 1)
  ;;menus
  (command "-toolbar" "draw" "s")
  (command "-toolbar" "draw order" "s")
  (command "-toolbar" "layers" "s")
  (command "-toolbar" "modify" "s")
  (command "-toolbar" "standard" "s")
  (command "-toolbar" "styles" "s")
  (command "-toolbar" "properties" "s")
  (command "properties")
  ;;ViewCube
  (command "DISPLAYVIEWCUBEIN2D" "Off")
  (command "DISPLAYVIEWCUBEIN3D" "On")
  ;;modelspace paper colour, RGB "255 255 255" = white "0 0 0" = black
    (defun somefunc (x y z)
      (apply '+ (mapcar 'lsh (list x y z) '(16 8 0)))
  (setenv "Background" (itoa (somefunc 255 255 255)))
  ;;Go to model space
  (setvar "ctab" (nth 0 (layoutlist) ))
  (setvar "ctab" "Model" )
  ;;custom alerts to set up user things like papaer sizes
  (alert "Set up Ax Full Bleed to 0mm margins")
  (alert "Set up Ax Expand to 0mm margins")
  (alert "Set up 'DWG to PDF - No Preview.pc3'\nChange PDF Options")
  (alert "SP: See plotter configuration files folder, copy to AutoCAD folder")
oh nice. ive got very similar setup. i just use layer/styles/properties toolbars though (i havent actually looked at the others properly in such a long time so i might check out some of those other ones you've called up)
was going to copy some of this to my main lisp file but no need really as you would only need to run 1 time when you upgrade to new version or something. i'll set up a separate routine. thanks!
Added a few options since the first version for those who like to pimp things.
Same restrictons as b4 , text display is very basic , keep them short or use wider buttons , background fill is fine for standard drawings sizes , but very large units can take some time so added option in setup dialog to tweak fill percentage. Very small drawings / zoom factor also impacts fill. But then if I have to live with these limits of lisp , so do you. Very satisfying I can tell you.
App can be started with c:GrM (Graphic Menu) , you probably want to fill the app list with your favorite lisp routines and app still  works by loading 'MyLisp' and then assumes it starts with (c:MyLisp).
Haven't tested it on a virgin system yet so hope it runs on first use. App should display toolbar with default settings and enters a grread loop , there you can select button or press S for setup , O to change orientation (left / right / top / center / bottom) and also do some zooming, oh just read the freaking command prompt.
One button(key)  isn't listed , D , that was for debugging. Just left it there for those who get off pressing buttons. In setup dialog top left will show if debug mode is active. You probably use it once in you life but it could be a nice template for future apps.
You also can directly go to setup dialog with (C:GrMS)
Well I could go on but what be the fun in that. If I did my work app should explain itself. My reason for making this is that for every job I do I make my tools on the fly and having to edit / recompile my autocad toolbar every freaking time started to irritate me and now I just pimp my own toolbar / app-list (you can save multiple toolbar data files in the app-list dialog)
Well , as you should know by now hope you have fun or else bite me (or your mother in law)
Oh , if you choose center orientation I would advise to use the fixed width / height option ... or not , I'm not your mommie ...daddy? ... maybe...
2025-09-07 :  updated a couple of first use issues & added 'hotkey' [C]olor to cycle different colors
GrM.lsp
Edited by rlx
fixed some first use issues (I hope)
  • Like 2
All working.
I assume the DAT file is just a list of LISPs, I am getting 'Bad argument value: non-negative: -1' ?
Edited by Steven P
yes the list is just a plain text file.
Seems there still is a gremlin in the app , have to hunt it down... think starting setup dialog while toolbar is active is the culprit, probably better to have tootlbar and setup separate. I will have a look at this.
Thanks... looking good though...
(oh, you do know that one day I will ask for the dragon - very cool)
found the dragon somewhere on line but not sure where anymore , but I know its way above my drafting skills haha.
The error is probably the default name for the dat file , on a new system it doesn't exist yet so it has to be created , but think I forgot to put that in yet , wil check it out and update the code. Creating a file c:\\temp\\GrM-Rlx.dat might fix the error for now (that is , if that caused the error)
Draak3d.dwg
Cheers, I have broken my rules... weekend and CAD is off... and now it is weekend and beer time.... CAD is still on....
No, that didn't work - I'll have a look tomorrow or Monday to see if it is my machine doing something odd.
Dragon is brilliant, thanks!
have nice weekend :beer:
ps updated the code a little bit (create empty data file on first use) , reset environment (cleared registry / data files) but no error... usually the error you describe has to do with nth function. But I'll do some more testing to try to reproduce the error.
upd. 2025-09-07 : addressed some first use issues  and couldn't resit added 'hotkey' [C]olor to cycle background color for 'buttons'. Code above updated.
Edited by rlx
addressed a couple of first use issues
Hi @rlx
Is it possible that you forgot to include some functions that are called from your code?
For example, 'rlx_sf'?
you're absolutely right GLAVCVS , took out too much when I cleaned out some obsolete code. Usually I forget the 'void' function but paid special attention I didn't this time. At the expense of rlx_sf this time so it seems.
Have done a few changes , renamed orientation to justification (change with letter j / J while menu is displayed) , change (background) color with b (or B) and with keys c / C & r / R decrease / increase columns & rows. Hope all the bugs are dead now...
;;; GrM - Graphic Menu , Rlx sep '25
;;; Known limitations : keep app names short , use fixed width & height not really useful, probably gonna remove that
;;; option was intended to be able to have like a 4x4 in center of screen and not fill entire screen... maybe later..
;;; last update	: 2025-09-04 - cleaned up & connected dialog with subroutines
;;;             : 2025-09-05 - did some further t&c (tweaking & cleaning)
;;;		: 2025-09-06 - time for fieldtesting
;;;		: 2025-09-07 - fixed a couple of 1st use issues
;;;		: 2025-09-10 - included rlx_sf
(defun c:GrMS
        ;;; globals
        regkey regvar reg-var-list old-err screen-width screen-height GrM-NoF-Columns GrM-NoF-Rows start-toolbar
        cell-height cell-width x y cell-number app-list corner start-viewsize app
        default-button-width default-button-height
        ;;; test variables so I can run program without dialog
        tst-NoF-Rows tst-NoF-Columns tst-cell-height tst-cell-width
        ;;; dimscreen : view x-/y-/x+/y+/height/width/center
        vx- vy- vx+ vy+ vh vw vc
        ;;; toolbar corner points
        tb-x- tb-x+ tb-y- tb-y+ tb-ll tb-ul tb-lr tb-ur tb-dX tb-dY
        ;;; setup dialog variables
        setup-dialog-fn setup-dialog-fp setup-dialog-dcl setup-dialog-tl setup-dialog-rd
        ;;; registry
        GrM-NoF-Rows						;;; Number of rows in menu , left-right (vertical) Justification
        GrM-NoF-Columns						;;; Number of columns in menu , left-right (vertical) Justification
        GrM-Button-Background-Fill				;;; 100(%) means 1 vector line per unit
        GrM-Button-Width-Height-Ratio				;;; width-ratio 2 means cell width is 2 x cell height
        GrM-Max-Button-Width-Height-Ratio			;;; set on 3 (width is max 3 times button height)
        GrM-Max-Button-Background-Fill				;;; 0-100 (%) in steps of 10
        GrM-Use-Fixed-Cell-Height				;;; boole , "0" = nope , "1" = jip
        GrM-Cell-Height						;;; 10 means screen width / 10
        GrM-Use-Fixed-Cell-Width				;;; boole , "0" = nope , "1" = jip
        GrM-Cell-Width						;;; 10 means screen height / 10
        GrM-Frame-Color						;;; default is "7" (white)
        GrM-Text-Color						;;; default is "7" (white)
        GrM-Background-Color					;;; colors like "8" (gray) , "143" (dirty blue)
        ;;; options
        GrM-Max-Columns GrM-Max-Rows				;;; Limmits on number of columns & row
        GrM-Follow-Justification GrM-Sort-On-Load			;;; Swap #rows - #cols when switching Left/Right - Top/Center/Bottom
        GrM-Text-Size-Factor					;;; usually 9 or 10
        GrM-Toolbar-Justification					;;; left/right/top/bottom/center
        GrM-App-List-File
        GrM-Debug-Mode						;;; if "1" function inspect displays variables & values
  ;;; initialyze environment
  (set_reg_var_list) (princ "\nstart GrM ... ") (GrM_Init) (princ "start setup dialog\n")
  ;;; (chk_reg_vars) ;;; debug on;y
  (GrM_Setup_Dialog_Start)
  (GrM_Exit)
(defun c:GrM
  ( / regkey regvar reg-var-list old-err screen-width screen-height GrM-NoF-Columns GrM-NoF-Rows cell-height cell-width x y
   cell-number app-list corner vx- vy- vx+ vy+ vh vw vc tb-x- tb-x+ tb-y- tb-y+ tb-ll tb-ul tb-lr tb-ur tb-dX tb-dY
   setup-dialog-fn setup-dialog-fp setup-dialog-dcl setup-dialog-tl setup-dialog-rd app
   GrM-NoF-Rows GrM-NoF-Columns GrM-Button-Background-Fill GrM-Button-Width-Height-Ratio GrM-Max-Button-Width-Height-Ratio
   GrM-Max-Button-Background-Fill GrM-Use-Fixed-Cell-Height GrM-Cell-Height GrM-Use-Fixed-Cell-Width GrM-Cell-Width
   GrM-Frame-Color GrM-Text-Color GrM-Background-Color GrM-Max-Columns GrM-Max-Rows GrM-Follow-Justification GrM-Sort-On-Load
   GrM-Text-Size-Factor GrM-Toolbar-Justification GrM-App-List-File GrM-Debug-Mode)
  (set_reg_var_list) (princ "\nstart GrM ... ") (GrM_Init) (princ "start toolbar\n")
  ;;; (chk_reg_vars) ;;; debug only
  (GrM_Draw_Toolbar)
  (if (eq GrM-Debug-Mode "1")
    (inspect
      (list 'vh 'vw 'GrM-Toolbar-Justification 'GrM-NoF-Columns 'GrM-NoF-Rows 'GrM-Use-Fixed-Cell-Height
            'GrM-Cell-Height 'cell-Height 'GrM-Use-Fixed-Cell-Width  'GrM-Cell-Width  'cell-width
            'GrM-Frame-Color 'GrM-Text-Color 'GrM-Background-Color
  ;;; get user input
  (GrM_Start_GrRead)
  (GrM_Exit)
  ;;; launch app
  (if app (GrM_Start_App app))
(defun set_reg_var_list ()
  (setq reg-var-list
    (list
      'GrM-NoF-Rows 'GrM-NoF-Columns 'GrM-Button-Background-Fill 'GrM-Button-Width-Height-Ratio 'GrM-Max-Button-Width-Height-Ratio
      'GrM-Max-Button-Background-Fill 'GrM-Use-Fixed-Cell-Height 'GrM-Cell-Height 'GrM-Use-Fixed-Cell-Width 'GrM-Cell-Width
      'GrM-Frame-Color 'GrM-Text-Color 'GrM-Background-Color 'GrM-Max-Columns 'GrM-Max-Rows 'GrM-Follow-Justification 'GrM-Sort-On-Load
      'GrM-Text-Size-Factor 'GrM-Toolbar-Justification 'GrM-App-List-File 'GrM-Debug-Mode
(defun GrM_Init ()
  ;;; error handler
  (setq old-err *error* *error* GrM_Err)
  ;;; setup default data list (unless it exists)
  (create_default_data_file "c:\\temp\\GrM-Rlx.dat")
  ;;; init registry variables
  (InitDefaultRegistrySettings)(ReadSettingsFromRegistry)
  ;;; record viewsize at session begin
  (setq start-viewsize (getvar "viewsize"))
  ;;; get app-list if any
  (GrM_Preload_App_List)
  ;;; fixed button height / width is viewsize / factor (default = 12)
  (setq default-button-height (/ (getvar "VIEWSIZE") 10)
        default-button-width (* default-button-height 2.0))
(defun GrM_Err ($s)
  (princ (strcat "\n\n\n" $s))(GrM_Exit)(setq *error* old-err)(gc)(princ))
(defun GrM_Exit ()
  ;;; dialog
  (if (not (null setup-dialog-dcl))(unload_dialog setup-dialog-dcl))
  (if (not (null setup-dialog-fp))(close setup-dialog-fp))
  (if (and (not (null setup-dialog-fn))(findfile setup-dialog-fn))(vl-file-delete setup-dialog-fn))
  ;;; flush cache
  (redraw)(gc)(terpri)(princ "\r\n")(princ)
;;; --- Registry Settings ------------------------------- Begin Registry Settings ------------------------------- Registry Settings --- ;;;
(defun InitDefaultRegistrySettings ()
  (record "InitDefaultRegistrySettings")
  (setq regkey "HKEY_CURRENT_USER\\SOFTWARE\\GrM\\")
  ;;; regkeys must be strings
  ;;; ("variable name" "default value")
  (setq regvar
           ("GrM-NoF-Rows" "10")				;;; Number of rows in menu , left-right (vertical) Justification
           ("GrM-NoF-Columns" "1")				;;; Number of columns in menu , left-right (vertical) Justification
           ("GrM-Button-Background-Fill" "100")			;;; 100(%) means 1 vector line per unit
           ("GrM-Max-Button-Background-Fill" "100")		;;; value between 10-100 (%) in steps of 10
           ("GrM-Button-Width-Height-Ratio" "2")		;;; width-ratio 2 means cell width is 2 x cell height
           ("GrM-Max-Button-Width-Height-Ratio" "3")		;;; limit on how many times the height the width of the button can be.
           ("GrM-Use-Fixed-Cell-Height" "0")			;;; boole , "0" = nope , "1" = jip
           ("GrM-Cell-Height" "")				;;; 10 means screen width / 10
           ("GrM-Use-Fixed-Cell-Width" "0")			;;; boole , "0" = nope , "1" = jip
           ("GrM-Cell-Width" "")				;;; 10 means screen height / 10
           ("GrM-Frame-Color" "7")				;;; default is "7" (white)
           ("GrM-Text-Color" "7")				;;; default is "7" (white)
           ("GrM-Background-Color" "8")				;;; colors like "8" (gray) , "143" (dirty blue)
           ("GrM-Max-Columns" "10")				;;; Limmits on number of columns
           ("GrM-Max-Rows" "10")				;;; Limmits on number of rows
           ("GrM-Follow-Justification" "1")			;;; Swap #rows - #cols when swapping Left/Right - Top/Center/Bottom
           ("GrM-Sort-On-Load" "1")				;;; Sort app-list upon load
           ("GrM-Text-Size-Factor" "9")
           ("GrM-Toolbar-Justification" "left")			;;; left/right/top/bottom/center
           ("GrM-App-List-File" "c:\\temp\\GrM-Rlx.dat")
           ("GrM-Debug-Mode" "0")				;;; hidden image button &d toggles dubug
  (mapcar '(lambda (x)(set (read (car x)) (cadr x))) regVar)
(defun ReadSettingsFromRegistry () (record "ReadSettingsFromRegistry")
  (mapcar '(lambda (x / n v)
    (if (setq v (vl-registry-read regkey (setq n (car x)))) (set (read n) v) (vl-registry-write regkey n (cadr x)))) regvar))
(defun WriteSettingsToRegistry () (record "WriteSettingsToRegistry")
  (mapcar '(lambda (x) (vl-registry-write regkey (car x) (eval (read (car x))))) regvar))
;;; (setq a 1 b t   c "") (vl-every 'boundp (list 'a 'b 'c)) -> T
;;; (setq a 1 b nil c "") (vl-every 'boundp (list 'a 'b 'c)) -> nil
(defun chk_reg_vars ()
  (if (not (vl-every 'boundp reg-var-list))
    (progn (princ "\n * reg var err - attempting to reload *")
      (gc) (ReadSettingsFromRegistry)))
  (if (not (vl-every 'boundp l))
    (progn (alert " * reg var err - please reload GrM *")(exit)))
;;; --- Registry Settings -------------------------------- End Registry Settings -------------------------------- Registry Settings --- ;;;
;;; --- dialog section ----------------------------------- begin dialog section ------------------------------------ dialog section --- ;;;
; SaveDialogData evaluates all vars from %tl and returns them as a list, reset does the opposite
(defun Save_Setup_Dialog_Data      (%tl) (mapcar '(lambda (x) (eval (car x))) %tl))
(defun Reset_Setup_Dialog_Data (%tl %rd) (mapcar '(lambda (x y) (set (car x) y)) %tl %rd))
(defun Set_Setup_Dialog_Tiles      (%tl) (mapcar '(lambda (x / v) (if (eq 'str (type (setq v (eval (car x))))) (set_tile (cadr x) v))) %tl))
(defun Setup_Dialog_Cancel     () (Reset_Setup_Dialog_Data setup-dialog-tl setup-dialog-rd) (WriteSettingsToRegistry))
;;; --- dcl plus-minus block --------------------------------------------------
;;;             _____
;;; No. Dragons |  1|  [ + ] [ - ]
;;; k = key (will be prexid with eb_ & bt_ / app-list = label / w = edit box width
;;; (dcl_plus_min "rlx" "No. Dragons" "3")
(defun dcl_plus_min (k app-list w)
  (strcat ":row {children_fixed_width=true;"
          ":text {fixed_width=true;width=10;label=\"" app-list "\";}"
          ":edit_box {key=\"eb_" k "\";edit_width=" w ";}"
          ":button {key=\"bt_" k "_plus\";label=\"+\";}"
          ":button {key=\"bt_" k "_min\";label=\"-\";}spacer;}"
(defun dcl_button_image1 (k app-list)
  (strcat ":button {fixed_width=true;width=18;key=\"bt_" k "\";label=\"" app-list "\";}"
          ":image {fixed_width=true;width=4;color=-2;key=\"im_" k "\";}"))
(defun GrM_Setup_Dialog_Create ( / f ) (record "GrM_Setup_Dialog_Create")
  (if (and (setq setup-dialog-fn (vl-filename-mktemp "GrM.dcl"))
           (setq setup-dialog-fp (open setup-dialog-fn "w")))
    (mapcar
      '(lambda (x)(write-line x setup-dialog-fp))
      (list
        (strcat "GrM_Setup : dialog {label=\"GrM - Setup screen (Rlx " (now) ")\";")
        ":text_part {key=\"tp_debug_mode\";}"
        ":boxed_column {label=\"Dimensions\";"
        "  :row {"
        "    :column {" (dcl_plus_min "nof_rows" "Rows" "3") "spacer;"(dcl_plus_min "fill"  "Fill  (%)" "3") "}"
        "    :column {" (dcl_plus_min "nof_columns" "Columns" "3") (dcl_plus_min "button_width_height_ratio" "Ratio W/H " "3") "}"
        "  :row {alignment=centered;"
        "    :column {width=10;}"
        "    :toggle {label=\"Use fixed cell width\";key=\"tg_use_fixed_width\";}"
        "    :edit_box {edit_width=3;key=\"eb_fixed_width\";}"
        "    :column {width=12;}"
        "    :toggle {label=\"Use fixed cell height\";key=\"tg_use_fixed_height\";}"
        "    :edit_box {edit_width=3;key=\"eb_fixed_height\";}"
        "    :column {width=2;}"
        ":boxed_row {label=\"Colors\";"
          (dcl_button_image1 "frame_color" "Frame")
          (dcl_button_image1 "text_color" "Text")
          (dcl_button_image1 "background_color" "Background")
        ":boxed_radio_row {label=\"Justification\";"
        "  :radio_button {key=\"rb_left\";label=\"Left\";}"
        "  :radio_button {key=\"rb_top\";label=\"Top\";}"
        "  :radio_button {key=\"rb_center\";label=\"Center\";}"
        "  :radio_button {key=\"rb_bottom\";label=\"Bottom\";}"
        "  :radio_button {key=\"rb_right\";label=\"Right\";}"
        "spacer;"
        ":boxed_column {"
        "  :row {:edit_box {edit_width=3;label=\"Max Col\";key=\"eb_max_columns\";}"
        "        :edit_box {edit_width=3;label=\"Max Row\";key=\"eb_max_rows\";}"
        "        :edit_box {edit_width=3;label=\"Max Ratio\";key=\"eb_max_ratio\";}"
        "        :edit_box {edit_width=3;label=\"Max Fill\";key=\"eb_max_fill\";}"
        "        :edit_box {edit_width=3;label=\"Text size\";key=\"eb_text_size_factor\";}"
        "  spacer;spacer;"
        "  :row {:toggle {label=\"Sort app-list on load\";key=\"tg_sort_on_load\";}"
        "        :toggle {label=\"Follow Justification\";key=\"tg_follow_Justification\";}}"
        "spacer;spacer;"
        ":column {:row {fixed_width=true;alignment=centered;"
        "  :button{key=\"bt_app_list\";label=\"App list\";}"
        "  :button{key=\"bt_preview\";label=\"Preview\";}"
        "  :image_button {color=dialog_background;width=0.1;height=0.1;fixed_height=true;key=\"ib_debug_mode\";label=\"&d\";}"
        "   ok_button;cancel_button;}}"
        "spacer;spacer;"
  (if setup-dialog-fp (close setup-dialog-fp))(gc)
  ;(if (setq f (findfile setup-dialog-fn)) (startapp "notepad" f)(alert (strcat "huh? " (vl-princ-to-string f))))
(defun GrM_Setup_Dialog_Start ( / drv)
  (GrM_Setup_Dialog_Create)
  (if (and (setq setup-dialog-dcl (load_dialog setup-dialog-fn))
           (new_dialog "GrM_Setup" setup-dialog-dcl))
      (GrM_Setup_Dialog_Update)
      (GrM_Setup_Dialog_Action)
      (setq drv (start_dialog))
      (if setup-dialog-fn (vl-file-delete setup-dialog-fn))
      (cond
	((= drv  0)(Setup_Dialog_Cancel))
	((= drv  1)(WriteSettingsToRegistry)(GrM_Draw_Toolbar))
        ((= drv  2)(WriteSettingsToRegistry)(Preview_Toolbar))
(defun Preview_Toolbar ()
  (GrM_Draw_Toolbar)
  (princ "\rPress any key to return to dialog")
  (vl-catch-all-apply 'grread (list nil 8 0))
  (redraw)
(defun cycle_Justification ( / co ol i)
  (setq co GrM-Toolbar-Justification ol '("left" "right" "top" "center" "bottom"))
  (if (setq i (vl-position co ol))
      (if (> i 3)
        (setq GrM-Toolbar-Justification (nth 0 ol))
        (setq GrM-Toolbar-Justification (nth (1+ i) ol))
      (GrM_Swappie)(WriteSettingsToRegistry)(GrM_Draw_Toolbar)
(defun cycle_color ( / c cl i)
  ;;; grey1 (8), blue (144), green (72), red (12), pink (244), brown (24)
  (setq c GrM-Background-Color cl '("8" "144" "72" "12" "214" "24"))
  (if (setq i (vl-position c cl))
      (if (> i 4)
        (setq GrM-Background-Color (nth 0 cl))
        (setq GrM-Background-Color (nth (1+ i) cl))
    ;;; user can have selected color not in color list so start with list color numero uno
(defun GrM_Setup_Dialog_Update ()
  (setq setup-dialog-tl
      (GrM-NoF-Rows "eb_nof_rows")
      (GrM-NoF-Columns "eb_nof_columns")
      (GrM-Button-Background-Fill "eb_fill")
      (GrM-Button-Width-Height-Ratio "eb_button_width_height_ratio")
      (GrM-Use-Fixed-Cell-Width "tg_use_fixed_width")
      (GrM-Use-Fixed-Cell-Height "tg_use_fixed_height")
      (GrM-Cell-Width "eb_fixed_width")
      (GrM-Cell-Height "eb_fixed_height")
      ;;; options
      (GrM-Max-Columns "eb_max_columns")
      (GrM-Max-Rows "eb_max_rows")
      (GrM-Max-Button-Width-Height-Ratio "eb_max_ratio")
      (GrM-Max-Button-Background-Fill "eb_max_fill")
      (GrM-Text-Size-Factor "eb_text_size_factor")
      (GrM-Follow-Justification "tg_follow_Justification")
      (GrM-Sort-On-Load "tg_sort_on_load")
      ;;; GrM-Max-Columns GrM-Max-Rows GrM-Follow-Justification GrM-Sort-On-Load GrM-Text-Size-Factor
  ;;; rd = reset data (val1 val2 ...) , in case of a cancel store original values before start of dialog
  (if (null setup-dialog-rd) (setq setup-dialog-rd (Save_Setup_Dialog_Data setup-dialog-tl)))
  ;;; set edit boxes and toggle values
  (Set_Setup_Dialog_Tiles setup-dialog-tl)
  ;;; update color images (Frame , Text & Background
  (GrM_Update_Color_Images)
  ;;; update radiobuttons (Justification top/left/bottom/right
  (GrM_Update_Radio_Buttons)
  ;;; Check & set debug mode
  (set_tile "tp_debug_mode" (if (and GrM-Debug-Mode (eq GrM-Debug-Mode "1")) " * debug mode *" ""))
(defun GrM_Setup_Dialog_Action ()
  (mapcar '(lambda (x)(action_tile (car x) (cadr x)))
    '(("cancel" "(done_dialog 0)") ("accept" "(done_dialog 1)")
      ("bt_preview" "(done_dialog 2)")
      ("ib_debug_mode" "(Toggle_Debug_Mode)")
      ("eb_nof_rows" "(setq GrM-NoF-Rows $value)")
      ;;; GrM_IncTile - just for testing
      ("bt_nof_rows_plus" "(GrM_IncTile $key 1)") ("bt_nof_rows_min" "(GrM_IncTile $key -1)")
      ("eb_nof_columns" "(setq GrM-NoF-Columns $value)")
      ("bt_nof_columns_plus" "(GrM_IncTile $key 1)") ("bt_nof_columns_min" "(GrM_IncTile $key -1)")
      ("eb_fill" "(setq GrM-Button-Background-Fill $value)")
      ("bt_fill_plus" "(GrM_IncTile $key 1)") ("bt_fill_min" "(GrM_IncTile $key -1)")
      ("eb_button_width_height_ratio" "(setq GrM-Button-Width-Height-Ratio $value)")
      ("bt_button_width_height_ratio_plus" "(GrM_IncTile $key 1)")
      ("bt_button_width_height_ratio_min" "(GrM_IncTile $key -1)")
      ;;; fixed width / height
      ("tg_use_fixed_width" "(setq GrM-Use-Fixed-Cell-Width $value)")
      ("tg_use_fixed_height" "(setq GrM-Use-Fixed-Cell-Height $value)")
      ("eb_fixed_width" "(setq GrM-Cell-Width $value)")
      ("eb_fixed_height" "(setq GrM-Cell-Height $value)")
      ;;; color handling
      ("bt_frame_color" "(get_frame_color)") ("bt_text_color" "(get_text_color)")
      ("bt_background_color" "(get_background_color)")
      ;;; options
      ("eb_max_columns" "(setq GrM-Max-Columns $value)")
      ("eb_max_rows" "(setq GrM-Max-Rows $value)")
      ("eb_text_size_factor" "(setq GrM-Text-Size-Factor $value)")
      ("tg_follow_Justification" "(setq GrM-Follow-Justification $value)")
      ("tg_sort_on_load" "(setq GrM-Sort-On-Load $value)")
      ;;; toolbar Justification / justification
      ("rb_left" "(GrM_Set_Justification $key)")("rb_right" "(GrM_Set_Justification $key)")
      ("rb_top" "(GrM_Set_Justification $key)")("rb_center" "(GrM_Set_Justification $key)")
      ("rb_bottom" "(GrM_Set_Justification $key)")
      ;;; ("bt_app_list" "(done_dialog 3)") (GrM_App_List_Dialog)
      ("bt_app_list" "(GrM_App_List_Dialog)")
;;; low tec but functional
(defun Toggle_Debug_Mode ()
  (cond ((eq GrM-Debug-Mode "1") (setq GrM-Debug-Mode "0"))
  ((eq GrM-Debug-Mode "0") (setq GrM-Debug-Mode "1")) (t (setq GrM-Debug-Mode "0")))
(defun GrM_Update_Color_Images ()
  (mapcar '(lambda (i c)(GrM_SetColorImage i c))
           (list "im_frame_color" "im_text_color" "im_background_color")
           (list GrM-Frame-Color GrM-Text-Color GrM-Background-Color)))
(defun GrM_Update_Radio_Buttons ()
  (cond ((eq GrM-Toolbar-Justification "left")(set_tile "rb_left" "1"))
        ((eq GrM-Toolbar-Justification "right")(set_tile "rb_right" "1"))
        ((eq GrM-Toolbar-Justification "top")(set_tile "rb_top" "1"))
        ((eq GrM-Toolbar-Justification "bottom")(set_tile "rb_bottom" "1"))
        ((eq GrM-Toolbar-Justification "center")(set_tile "rb_center" "1"))
;;; when Justification changes from horizontal to vertical , swap nof columns & nof rows
(defun GrM_Swappie ( / i1 i2)
  (setq i1 (atoi GrM-NoF-Columns) i2 (atoi GrM-NoF-Rows))
  (cond
    ;;; horizontal
    ((member GrM-Toolbar-Justification '("top" "center" "bottom"))
     (setq GrM-NoF-Columns (itoa (max i1 i2)) GrM-NoF-Rows (itoa (min i1 i2))))
    ;;; vertical
    ((member GrM-Toolbar-Justification '("left" "right" ))
     (setq GrM-NoF-Columns (itoa (min i1 i2)) GrM-NoF-Rows (itoa (max i1 i2))))
;;; gonna assume that when Justification is left or right (vertical) , the number for rows is larger
;;; than the number for columns , this is handeld by setting GrM-Follow-Justification in dialog
(defun GrM_Set_Justification (k)
  (setq GrM-Toolbar-Justification (substr k 4))
  (if (eq GrM-Follow-Justification "1")
    (progn (GrM_Swappie)(set_tile "eb_nof_columns" GrM-NoF-Columns)(set_tile "eb_nof_rows" GrM-NoF-Rows))
;;; for now fixed max number of rows / columns to 10  (i is not used anymore , uses tile name instead
(defun GrM_IncTile ( tl i / v cmax rmax ratmax fmax)
  (if (isnum GrM-Max-Columns)(setq cmax (atoi GrM-Max-Columns))(setq cmax 12))
  (if (isnum GrM-Max-Rows)(setq rmax (atoi GrM-Max-Rows))(setq rmax 12))
  (if (isnum GrM-Max-Button-Width-Height-Ratio)(setq ratmax (atoi GrM-Max-Button-Width-Height-Ratio))(setq ratmax 3))
  (if (isnum GrM-Max-Button-Background-Fill)(setq fmax (atoi GrM-Max-Button-Background-Fill))(setq fmax 100))
  (cond
    ;;; columns
    ((eq tl "bt_nof_columns_plus") (setq GrM-NoF-Columns (itoa (1+ (atoi GrM-NoF-Columns))))
     (if (> (atoi GrM-NoF-Columns) cmax) (setq GrM-NoF-Columns (itoa cmax)))
     (set_tile "eb_nof_columns" GrM-NoF-Columns))
    ((eq tl "bt_nof_columns_min") (setq GrM-NoF-Columns (itoa (1- (atoi GrM-NoF-Columns))))
     (if (< (atoi GrM-NoF-Columns) 1) (setq GrM-NoF-Columns "1"))
    ;;; rows
    ((eq tl "bt_nof_rows_plus") (setq GrM-NoF-Rows (itoa (1+ (atoi GrM-NoF-Rows))))
     (if (> (atoi GrM-NoF-Rows) rmax) (setq GrM-NoF-Rows (itoa rmax)))
    ((eq tl "bt_nof_rows_min") (setq GrM-NoF-Rows (itoa (1- (atoi GrM-NoF-Rows))))
     (if (< (atoi GrM-NoF-Rows) 1) (setq GrM-NoF-Rows "1"))
    ;;; width / height ratio
    ((eq tl "bt_button_width_height_ratio_plus") (setq GrM-Button-Width-Height-Ratio (itoa (1+ (atoi GrM-Button-Width-Height-Ratio))))
     (if (> (atoi GrM-Button-Width-Height-Ratio) ratmax) (setq GrM-Button-Width-Height-Ratio (itoa ratmax)))
     (set_tile "eb_button_width_height_ratio" GrM-Button-Width-Height-Ratio))
    ((eq tl "bt_button_width_height_ratio_min") (setq GrM-Button-Width-Height-Ratio (itoa (1- (atoi GrM-Button-Width-Height-Ratio))))
     (if (< (atoi GrM-Button-Width-Height-Ratio) 1) (setq GrM-Button-Width-Height-Ratio "1"))
    ;;; button background fill
    ((eq tl "bt_fill_plus") (setq GrM-Button-Background-Fill (itoa (+ (atoi GrM-Button-Background-Fill) 10)))
     (if (> (atoi GrM-Button-Background-Fill) fmax) (setq GrM-Button-Background-Fill (itoa fmax)))
     (set_tile "eb_fill" GrM-Button-Background-Fill))
    ((eq tl "bt_fill_min") (setq GrM-Button-Background-Fill (itoa (- (atoi GrM-Button-Background-Fill) 10)))
     (if (< (atoi GrM-Button-Background-Fill) 10) (setq GrM-Button-Background-Fill "10"))
    ;;; overkill...really
    (t (alert (strcat "\nUnknown IncTile : " (vl-princ-to-string tl) " / " (vl-princ-to-string i))))
;;; --- color handling -------------------------------------- color handling --------------------------------------- color handling --- ;;;
(defun getcolor (d) (if (or (void d) (not (isnum d)))(setq d 7)) (acad_colordlg d nil))
;;; check color , byblock/bylayer or nil are converted to color 7 (white)
(defun checkcolor (c) (if (string-p c)(setq c (strcase c t)))
  (cond ((member c '(0 256 "0" "256" "byblock" "bylayer")) 7) ((numberp c) c) ((string-p c)(atoi c)) (t 7)))
(defun GrM_SetColorImage (tilename color / col x y )
  (if (isnum color) (cond ((= (type color) 'STR)
    (setq col (atoi color)))((= (type color) 'INT)(setq col color))(t (setq col 7))))
  (if (and (string-p color) (member (strcase color T) '("bylayer" "byblock"))) (setq col 7))
  (if col (progn (setq x (dimx_tile tilename) y (dimy_tile tilename))
    (start_image tilename) (fill_image 0 0 x y col) (end_image)))
(defun get_frame_color ( / c d )
  (if (setq c (acad_colordlg (atoi GrM-Frame-Color) nil))
    (progn (GrM_SetColorImage "im_frame_color" c)(setq GrM-Frame-Color (itoa c)))))
(defun get_text_color ( / c d )
  (if (setq c (acad_colordlg (atoi GrM-text-Color) nil))
    (progn (GrM_SetColorImage "im_text_color" c)(setq GrM-text-Color (itoa c)))))
(defun get_background_color ( / c d )
  (if (setq c (acad_colordlg (atoi GrM-background-Color) nil))
    (progn (GrM_SetColorImage "im_background_color" c)(setq GrM-background-Color (itoa c)))))
;;; --- dialog section ------------------------------------ end dialog section ------------------------------------- dialog section --- ;;;
;;; (re) calculate display parameters (dim_screen)
;;; screensize = (1840.0 685.0) (PC dependent / zoom independent)
;;; viewsize = height of current screen , varies with zoom
;;; viewctr = screen center point , varies with zoom
;;; recalculate after each zoom : dx dy / vx- vy- vx+ vy+ / vc vs ss dx dy vx- vy- vx+ vy+ vh vw)
(defun dim_screen ( / dx dy)
  (setq vc (getvar "VIEWCTR") vs (getvar "VIEWSIZE") ss (getvar "SCREENSIZE"))
  ;;; view (half) width & view (half) height (assist for cornerpoints calculation)
  (setq dx (* vs (/ (car ss) (cadr ss)) 0.5) dy (* vs 0.5))
  ;;; view corner points
  (setq vx- (- (car vc) dx) vy- (- (cadr vc) dy) vx+ (+ (car vc) dx) vy+ (+ (cadr vc) dy))
  ;;; view height en view width
  (setq vh (- vy+ vy-) vw (- vx+ vx-))
  ;;; inspect / debug
  ;(inspect (list 'vx- 'vy- 'vx+ 'vy+ 'vh 'vw 'vc))
;;; cell width / height depends on viewsize / #rows / #colomns / Justification
;;; if Justification = horizontal then justification can be top / center / bottom
;;; if Justification = vertical then justification can be left / right
;;; - calculate cell width / cell height
;;;   if Justification = horizontal : cell width  = screen width  / #cols , cell height = cell width  / 2
;;;   if Justification = vertical   ; cell height = screen height / #rows , cell width  = cell height * 2
;;; - calculate corner points , then start from center point
;;; replaces dim_cell with GrM_Draw_Toolbar which uses data from dialog / registry variables
(defun GrM_Draw_Toolbar ( / tb-hw tb-hh)
  ;;; have no idea why sometimes GrM_Init is skipped , dirty fix
  (chk_reg_vars)
  ;;; get view data
  (dim_screen)
  ;;; first thing I need is cell height & cell width
  (if (member GrM-Toolbar-Justification '("top" "center" "bottom"))
    ;;; horizontal
      (cond
        ;;; if use fixed cell width = true
        ;;; (X-to-N = anything to number , allow zero = 0 , fix numer = 0)
        ((= GrM-Use-Fixed-Cell-Width "1")
         (if (not (void GrM-Cell-Width))
           (setq cell-width (X-to-N GrM-Cell-Width 0 0))(setq cell-width default-button-width)))
        ;;; divide screen-width by number of columns
        ((and (= GrM-Use-Fixed-Cell-Width "0") (setq i (X-to-N GrM-NoF-Columns 0 0)))
         (setq cell-width (/ vw i)))
        (t (setq cell-width (/ vw 10.0)))
      (cond
        ((eq GrM-Auto-Cell-Size-Ratio "1")
         (setq cell-Height (* cell-width 0.5)))
        ;;; if use fixed cell height = true
        ((= GrM-Use-Fixed-Cell-Height "1")
         (if (not (void GrM-Cell-Height))
           (setq cell-height (X-to-N GrM-Cell-Height 0 0))(setq cell-height default-button-height)))
        (t (setq cell-height (* cell-width 0.5)))
      (setq tb-height (* cell-height (atoi GrM-NoF-Rows)))
      (cond
         (setq tb-x- vx- tb-y- (- vy+ tb-height) tb-x+ vx+ tb-y+ vy+))
        ;;; tb-hw = toolbar half width , tb-hh = toolbar half height
         (setq tb-hw (* (atoi GrM-NoF-Columns) cell-width 0.5)
               tb-hh (* (atoi GrM-NoF-Rows) cell-height 0.5))
         (setq tb-x- (- (car vc) tb-hw) tb-x+ (+ (car vc) tb-hw))
         (setq tb-y- (- (cadr vc) tb-hh) tb-y+ (+ (cadr vc) tb-hh))
         (setq tb-x- vx- tb-y- vy- tb-x+ vx+ tb-y+ (+ tb-y- tb-height)))
    ;;; "vertical"
      ;;; calculate cell-height first
      (cond
        ;;;height is width / 2
        ((and (eq GrM-Auto-Cell-Size-Ratio "1") (setq i (X-to-N GrM-NoF-Rows 0 0)))
         (setq cell-height (/ vh i)))
        ;;; if use fixed cell height = true (1 "1" T) check height (zero not allowed, dont fix result
        ((and (= GrM-Use-Fixed-Cell-Height "1") (setq i (X-to-N GrM-Cell-Height 0 0)))
         (setq cell-Height i))
         ;;; divide screen-height by number of rows (zero not allowed , intergers only (fix result)
        ((and (= GrM-Use-Fixed-Cell-Height "0") (setq i (X-to-N GrM-NoF-Rows 0 0)))
        ;;; set default for column of 10 rows
        (t (setq cell-height (/ vh 10.0)))
      ;;; calclate cell-width
      (cond
         (setq cell-width (* cell-height 2.0)))
        ;;; if use fixed cell width = true (1 "1" T) check width (zero not allowed, dont fix result
        ((and (= GrM-Use-Fixed-Cell-Width "1") (setq i (X-to-N GrM-Cell-Width 0 0)))
         (setq cell-width i))
        (t (setq cell-width (* cell-height 2.0)))
      ;;; find toolbar alignment point
      ;;; for vertical these are left / center / right
      ;;; calculate width of toolbar for number of columns
      (setq tb-width (* cell-width (atoi GrM-NoF-Columns)))
      (cond
         (setq tb-x- vx- tb-y- vy- tb-x+ (+ tb-x- tb-width) tb-y+ vy+))
         (setq tb-x- (- (car vc) (* tb-width 0.5)) tb-x+ (+ (car vc) (* tb-width 0.5)) tb-y- vy- tb-y+ vy+))
         (setq tb-x- (- vx+ tb-width) tb-x+ vx+ tb-y- vy- tb-y+ vy+))
    (inspect
      (list
        'GrM-Use-Fixed-Cell-Height 'GrM-Cell-Height 'cell-Height
  (setq cell-text-height (/ cell-height 2.0))
  ;(setq tst-cell-height cell-height tst-cell-width cell-width)
  ;;; some more testing (x- y- x+ y+ r c co  / xl yl)
  (Draw_Frame tb-x- tb-y- tb-x+ tb-y+ (atoi GrM-NoF-Rows) (atoi GrM-NoF-Columns) 2)
;;; x-=xmin, x+=ymax etc, r=rows, c=columns, co=color
;;; (setq e- (getvar "EXTMIN") e+ (getvar "EXTMAX"))
;;; (Draw_Frame (car e-)(cadr e-)(car e+)(cadr e+) 5 5 1)
(defun Draw_Frame (x- y- x+ y+ r c co  / xl yl pl text-size bcol fcol tcol justy ) (record "Draw_Frame")
  (if (and (not (void GrM-background-Color))(isnum GrM-background-Color))
    (setq bcol (atoi GrM-background-Color))(setq col 142))
  (if (and (not (void GrM-Frame-Color))(isnum GrM-Frame-Color))
    (setq fcol (atoi GrM-Frame-Color))(setq fcol 7))
  (if (and (not (void GrM-Text-Color))(isnum GrM-Text-Color))
    (setq tcol (atoi GrM-Text-Color))(setq tcol 7))
  (redraw)(Fill_Toolbar_Background x- y- x+ y+ bcol)
  ;;; create x & y list for all grid coordinates
  (setq xl (gnl+ x- (1+ c) (/ (abs (- x+ x-)) c)) yl (gnl- y+ (1+ r) (/ (abs (- y+ y-)) r)))
  ;;; draw all horizontal lines
  (foreach y yl (grdraw (list x- y) (list x+ y) fcol))
  ;;; draw all vertical lines
  (foreach x xl (grdraw (list x y+) (list x y-) fcol))
  ;;; draw the texts
  (setq pl (gmpl xl yl))
  ;;; cell-text-height is cell-height / 2
  (if (and (not (void GrM-Text-Size-Factor))(isnum GrM-Text-Size-Factor))
    (setq text-size (/ cell-text-height (atoi GrM-Text-Size-Factor)))
    (setq text-size (/ cell-text-height 9))
  ;;; bad idea : grtxt routine has its limitations so I'll adjust text justification along with toolbar Justification
  ;;; all text insertion points are calculated based on middle algnment so lets keep it that way for now
  ;(cond ((eq GrM-Toolbar-Justification "left")(setq justy "L"))((eq GrM-Toolbar-Justification "right")(setq justy "R"))(t (setq justy "M")))
  (setq justy "M")
  (mapcar '(lambda (p s) (grtxt (strcase s) p tcol 0 justy text-size))
           pl (if (vl-consp app-list) (mapcar 'vl-filename-base app-list) '("Empty")))
;;; fill toolbar background
;;; next y depends on zoom factor (viewsize) , 0.1 is emperical, bigger means bigger linespacing
(defun Fill_Toolbar_Background (x- y- x+ y+ c / i vws) (setq i y- vws (getvar "viewsize"))
  (while (<= i y+)(grdraw (list x- i)(list x+ i) c)(setq i (+ i (* 0.1 (/ vws start-viewsize))))))
;;; makes use of dialog variable (atoi GrM-Button-Background-Fill) 10-100 in steps of 10
(defun Fill_Toolbar_Background (x- y- x+ y+ c / i vws bgf-fac)
  (setq i y- vws (getvar "viewsize") bgf-fac (/ 0.1 (/ (atof GrM-Button-Background-Fill) 100.0)))
  (while (<= i y+)(grdraw (list x- i)(list x+ i) c)(setq i (+ i (* bgf-fac (/ vws start-viewsize))))))
;;; (setq cel-id (GrM_GetCellNumber x y))
(defun GrM_GetCellNumber (x y / id )
  ;;; cell number from dialog , without accouting for page number
  ;(setq id (+ (* (atoi GrM-NoF-Columns) (fix (/ y cell-height))) (fix (1+ (/ x cell-width)))))
  (if (eq tst-Justification "horizontal")
    (setq id (+ (* (atoi tst-NoF-Columns) (fix (/ y tst-cell-height))) (fix (1+ (/ x tst-cell-width)))))
    (setq id (+ (* (atoi tst-NoF-Rows) (fix (/ y tst-cell-height))) (fix (1+ (/ x tst-cell-width)))))
;;; (GrM_GetCell-ID (list 100.0 100.0) (list 130.0 70.0) 3 3 (list 122.0 79.0))
;;; get cell-id from point selection to use as nth for app-list
(defun GrM_GetCell-ID (ul lr c r p / dy dy x y)(setq x (car p) y (cadr p))
  (setq dx (/ (abs (- (car lr) (car ul))) c) dy (/ (abs (- (cadr ul) (cadr lr))) r))
  (+ (/ (fix (abs (- x (car ul))))(fix dx))(* (1- (- r (/ (fix (abs (- y (cadr lr))))(fix dy)))) c))
;;; (show_grid)
(defun show_grid ( / x dx y dy i)
  (setq x (fix screen-width) y (fix screen-height))
  (setq dy (/ y (atoi GrM-NoF-Rows)) dx (/ x (atoi GrM-NoF-Columns)))
  (setq i 0)(while (< i x)(grdraw (list i 0) (list i y) 3)(setq i (fix (+ i dx))))
  (setq i 0)(while (< i y)(grdraw (list 0 i) (list x i) 3)(setq i (fix (+ i dy)))))
;;; (setq corner (GrM_GetCellCorner 5))
(defun GrM_GetCellCorner ( cell / col row)
  (if (= (rem cell (atoi GrM-NoF-Columns)) 0)
    (setq col (atoi GrM-NoF-Columns) row (1- (/ cell (atoi GrM-NoF-Columns))))
    (setq col (rem cell (atoi GrM-NoF-Columns)) row (/ cell (atoi GrM-NoF-Columns))))
  (list (* cell-width (1- col)) (* cell-height row)))
;;; (Dim_Box (list 400 75) cell-width cell-height)
;;; arg top left point , width , height , return list cornerpoints
(defun Dim_Box (p w h)
  (list p (polar p 0 w) (polar p (atan h w) (sqrt (+ (expt w 2)(expt h 2)))) (polar p (/ pi 2) h)))
;;; --- GrTxt ---------------------------------------------------- GrTxt ---------------------------------------------------- GrTxt --- ;;;
;;; found this old lisp (grtxt.lsp) , don't know author but all credits are for this human from earth
;;; text string / coordinate point / color / angle / justification/ z for text height
;;; *** UPPER CASE ONLY ***  (grtxt (STRCASE "Rob") (getvar "viewctr") 1 0 "M")
;;; 2025-07-29 added z for text height as parameter
(defun grtxt (ts cp cl a j z / vp ltb i xp c p1 p2 lp ld n al)
  ;;; vertex points
  (setq vp '(( 1 ( 0.50  0.25))( 2 ( 0.50  0.55))( 3 ( 0.50  0.85))( 4 ( 0.50  1.00))( 5 ( 0.25  1.00))
             ( 6 ( 0.00  1.00))( 7 (-0.25  1.00))( 8 (-0.50  1.00))( 9 (-0.50  0.85))(10 (-0.50  0.55))
             (11 (-0.50  0.25))(12 (-0.50  0.10))(13 (-0.25  0.10))(14 ( 0.00  0.10))(15 ( 0.25  0.10))
             (16 ( 0.50  0.10))(17 ( 0.50 -0.05))(18 ( 0.50 -0.45))(19 ( 0.50 -0.85))(20 ( 0.50 -1.00))
             (21 ( 0.25 -1.00))(22 ( 0.00 -1.00))(23 (-0.25 -1.00))(24 (-0.50 -1.00))(25 (-0.50 -0.85))
             (26 (-0.50 -0.40))(27 (-0.50 -0.05))(30 ( 0.35  0.85))(31 (-0.35  0.85))(32 (-0.35 -0.85))
             (33 ( 0.35 -0.85))(40 ( 0.25  0.35))(41 (-0.25  0.35))(42 ( 0.25 -0.15))(43 (-0.25 -0.15))
             (44 ( 0.00  0.45))(45 ( 0.00 -0.25))(50 ( 0.30  0.20))(51 ( 0.30  0.35))(52 ( 0.20  0.35))
             (53 ( 0.20  0.20))(54 ( 0.30  0.10))(55 ( 0.30 -0.10))(56 ( 0.20 -0.10))(57 ( 0.20  0.10))
             (60 (-0.30  0.20))(61 (-0.30  0.35))(62 (-0.20  0.35))(63 (-0.20  0.20))(64 (-0.30  0.10))
             (65 (-0.30 -0.10))(66 (-0.20 -0.10))(67 (-0.20  0.10))))
  ;;; letter table
  (setq ltb '(("A" 24 9 7 5 3 20 16 12) ("B" 12 15 1 3 5 8 24 21 19 17 15) ("C" 3 5 7 9 25 23 21 19)
              ("D" 3 5 8 24 21 19 3) ("E" 4 8 12 15 12 24 20) ("F" 4 8 12 15 12 24)
              ("G" 3 5 7 9 25 23 21 19 16 14) ("H" 20 -4 8 -24 16 12) ("I" 7 5 6 22 23 21) ("J" 4 19 21 23 25)
              ("K" 8 24 12 13 4 13 20) ("L" 8 24 20) ("M" 24 8 14 4 20) ("N" 24 8 20 4) ("O" 3 5 7 9 25 23 21 19 3)
              ("P" 12 15 1 3 5 8 24) ("Q" 3 5 7 9 25 23 21 19 3 -19 20 45) ("R" 20 14 12 15 1 3 5 8 24)
              ("S" 3 5 7 9 11 13 15 17 19 21 23 25) ("T" 4 8 6 22) ("U" 8 25 23 21 19 4 20) ("V" 8 22 4)
              ("W" 8 23 14 21 4) ("X" 4 -24 8 20) ("Y" 8 14 22 14 4) ("Z" 8 4 24 20) ("0" 3 5 7 9 25 23 21 19 -3 4 24)
              ("1" 31 7 6 22 21 23) ("2" 9 7 5 3 1 15 13 27 24 20) ("3" 9 7 5 3 1 15 13 15 17 19 21 23 25)
              ("4" 8 12 16 15 5 21) ("5" 4 8 12 15 17 19 21 23 25) ("6" 3 5 7 9 25 23 21 19 17 15 12) ("7" 8 4 22)
              ("8" 3 5 7 9 11 13 27 25 23 21 19 17 15 13 15 1 3) ("9" 25 23 21 19 3 5 7 9 11 13 16)
              ("<" 4 12 20) (">" 8 16 24) ("," 33 21) ("." 19 20 21 33 19) ("\'" 4 30) ("\"" 4 -30 7 31)
              (";" 50 51 52 53 -50 54 55 56 57 55 45) (":" 50 51 52 53 -50 54 55 56 57 55) ("\\" 8 20) ("/" 4 24)
              ("?" 11 10 7 5 2 1 45 22) ("|" 6 -44 45 22) ("+" 44 -45 13 15) ("=" 40 -41 43 42) ("-" 13 15) ("_" 20 24)
              (")" 6 2 18 22) ("(" 6 10 26 22) ("*" 40 -43 41 -42 45 44) ("&" 21 31 7 6 26 25 23 16) ("^" 10 6 2)
              ("%" 57 54 55 56 -57 63 60 61 62 -63 5 24) ("$" 3 5 7 9 11 13 15 17 19 21 23 25 -26 22 6)
              ("#" 24 -6 22 -4 1 -11 17 27) ("@" 42 15 40 44 41 13 43 45 42 17 3 5 7 9 25 23 21 19) ("!" 6 -45 22 22)
              ("~" 9 31 44 40 2) ("`" 8 31) ("[" 6 8 24 22) ("]" 6 4 20 22) ("{" 6 7 41 12 43 23 22)
              ("}" 6 5 40 16 42 21 22) ("")))
  ;;; text height - use z as parameter
  ;;;(setq z (/ (getvar "VIEWSIZE") (cadr (getvar "SCREENSIZE")) 0.1))
  ;;;(setq z (/ (getvar "VIEWSIZE") 10))
  (cond
    ;;; left justification
    ((eq (strcase (substr j 1 1)) "L")  (setq xp (list (+ (car cp) z) (cadr cp)) i 1))
    ;;; middle justification
    ((eq (strcase (substr j 1 1)) "M")  (setq xp (list (- (car cp) (* z (strlen ts) 0.5)) (cadr cp)) i 1))
    ;;; right justification
    ((eq (strcase (substr j 1 1)) "R")  (setq xp (list (- (car cp) (* z (strlen ts) 1.5)) (cadr cp)) i 1))
  (repeat (strlen ts)
    ;;; each charachter / line point list / letter point def
    (setq c (substr ts i 1) lp '() ld (cdr (assoc c ltb)))
    (while (> (length ld) 1)
      (setq p1 (cadr (assoc (abs (nth 0 ld)) vp)) p2 (cadr (assoc (abs (nth 1 ld)) vp))
            p1 (mapcar '* (list z z) p1) p2 (mapcar '* (list z z) p2)
            p1 (mapcar '+ xp p1) p2 (mapcar '+ xp p2)
            lp (append lp (list (if (minusp (nth 0 ld)) 0 cl) p1 p2)) ld (cdr ld))
    ;;; add rotation angle
    (setq n 0 al nil)
    (repeat (/ (length lp) 3)
      (setq al (cons (nth n lp) al)
            al (cons (polar cp (+ a (angle cp (nth (+ n 1) lp))) (distance cp (nth (+ n 1) lp))) al)
            al (cons (polar cp (+ a (angle cp (nth (+ n 2) lp))) (distance cp (nth (+ n 2) lp))) al))
      (setq n (+ n 3))
    (and al (grvecs (reverse al)))
    (setq xp (list (+ (car xp) (* z 1.5)) (cadr xp)) i (1+ i))
  (prin1)
;;; --- App list dialog ------------------------------------- App list dialog ------------------------------------- App list dialog --- ;;;
;;; Simple File Dialog
;;; f = dialog file name , p = pointer , d = dialog , app-list = list , i = input , idx = listbox index
(defun GrM_App_List_Dialog ( / f p d app-list i idx regkey regvar Filli-Dat-File return-to-setup-dialog)
  (setq idx 0)
  ;;; (InitDefaultRegistrySettings)(ReadSettingsFromRegistry)
  ;;; first use
  (if (or (null GrM-App-List-File)(not (eq (type GrM-App-List-File) 'STR)))
      (setq GrM-App-List-File (vl-filename-mktemp "app-list.dat") p (open GrM-App-List-File "w"))
      (close p)(gc)
  ;;; read data file
  (if (and (findfile GrM-App-List-File)(setq p (open GrM-App-List-File "r")))
    (progn (while (setq i (read-line p))(setq app-list (cons i app-list)))(close p)))
  ;;; check data list
  (if (vl-consp app-list)(setq app-list (acad_strlsort app-list)) (setq app-list (list "Empty")))
  ;;; create dialog
  (if (and (setq f (vl-filename-mktemp "filli.dcl") p (open f "w")))
    (mapcar '(lambda (x)(write-line x p)) (list
      (strcat "app_list : dialog {label=\"App list dialog (Rlx " (now) ")\";")
      "spacer;:text_part {key=\"tp\";}spacer;"
      ":boxed_row {label=\"File list\";:column {:list_box {key=\"lb\";width=64;}}spacer;"
      ":column {:button {key=\"add\";label=\"Add\";}:button {key=\"del\";label=\"Del\";}"
      ":button {key=\"up\";label=\"Up\";}:button {key=\"down\";label=\"Down\";}:button {key=\"sort\";label=\"Sort\";}}}"
      ":text_part {key=\"tp_file_info\";}"
      "spacer; :column {:row {fixed_width=true;alignment=centered;:button{key=\"load\";label=\"Load\";}"
       ":button{key=\"save\";label=\"Save\";}:button{key=\"saveas\";label=\"Saveas\";}"
         ":button{key=\"edit\";label=\"Edit\";} ok_button;cancel_button;}}spacer;spacer;}"
    (princ "\nComputer says no : unable to create dialog")
  ;;; clean desk policy
  (if p (progn (close p)(gc)))
  ;;; start dialog
  (if (and (setq d (load_dialog f)) (new_dialog "app_list" d))
      ;;; fill list box
      (setq idx 0)(lb_upd)
      ;;; activate buttons
      (action_tile "cancel" "(done_dialog 0)")(action_tile "accept" "(done_dialog 1)")
      (action_tile "lb" "(setq idx (atoi $value))(lb_upd_info)")
      (mapcar '(lambda (x)(action_tile x "(action_key $key)"))
              '("add" "del" "up" "down" "sort" "load" "save" "saveas" "edit"))
      (setq drv (start_dialog)) (if (and f (setq f (findfile f))) (vl-file-delete f))
      (cond
	((= drv  0))
	((= drv  1)(WriteSettingsToRegistry))
;;; just to have a little less code in main loop
(defun action_key (k)
  (cond
    ((= k "add")(_add))((= k "del")(_del))((= k "up")(lb_mod "up"))((= k "down")(lb_mod "down"))
    ((= k "sort")(lb_sort))((= k "load")(_load))((= k "save")(_save))((= k "saveas")(_saveas))
    ((= k "edit")(_edit_dat_file))
;;; lb_upd = update list box (init / redraw / refresh)
(defun lb_upd ()
  (set_tile "tp" (strcat "    Data file : " (vl-princ-to-string GrM-App-List-File)))
  (start_list "lb")(mapcar 'add_list (mapcar 'vl-filename-base app-list))(end_list)
  (set_tile "lb" (itoa idx))
  (lb_upd_info)
;;; update the text part below listbox to show complete path & filename
(defun lb_upd_info ()
    (set_tile "tp_file_info" (strcat " File : " (vl-princ-to-string (nth idx app-list))))
    (set_tile "tp_file_info" " File : - ")
;;; lb_sort = sort list box
(defun lb_sort () (setq app-list (acad_strlsort app-list))
  (start_list "lb")(mapcar 'add_list app-list)(end_list)(set_tile "lb" (itoa idx)))
;;; lb_mod = modify list box
;;; m = mode up or down ("u" or "d") , app-list = app list (global) , xl = temp list (local)
;;; idx = index (global) , i = index (local) , i1 / i2 = scrap lists (local)
(defun lb_mod (m / i xl i1 i2) (setq i idx xl (vl-remove-if '(lambda (x)(= x "")) app-list))
  (cond ((void i))((or (null xl)(< (length xl) 2)))((and (= i 0) (= m "up")))((and (>= i (1- (length xl)))(= m "down")))
    (t (setq i1 (nth i xl)) (if (= m "up") (setq i (1- i) i2 (nth i xl)) (setq i (1+ i) i2 (nth i xl) ))
     (setq xl (subst "i1" i1 xl) xl (subst "i2" i2 xl) xl (subst i2 "i1" xl) xl (subst i1 "i2" xl) idx i)))
  (cond ((< idx 0)(setq idx 0))	((>= idx (length xl))(setq idx (1- (length xl)))))
  (setq app-list xl) (lb_upd)
;;; --- Tiny lisp section --------------------------------- Tiny lisp section ----------------------------------- Tiny lisp section --- ;;;
(defun void (x)
  (or (eq x nil)(and (listp x)(not (vl-consp x)))(and (eq 'STR (type x))(eq "" (vl-string-trim " \t\r\n" x)))))
(defun isnum (n)(if (or (numberp n) (and (= (type n) 'STR) (distof n))) t nil))
(defun string-p (s) (if (= (type s) 'str) t nil))
(defun uc (s) (alert (strcat "Under construction : " s)))
(defun now ( / s l )
  (setq s (rtos (getvar "CDATE")) l '("Jan""Feb""Mar""Apr""May""Jun""Jul""Aug""Sep""Oct""Nov""Dec"))
    (strcat (substr s 7 2) "-" (nth (1- (atoi (substr s 5 2))) l) "-'" (substr s 3 2)))
;;; remove from list
(defun rfl (e app-list) (apply 'append (subst nil (list e) (mapcar 'list app-list))))
;;; anything to number : n = number in any format (INT/REAL/STR) , z = allow 0 (zero) , f = fix result
;;; (X-to-N "0.0" 0 0) = nil , (X-to-N "0.0" 1 0) = 0.0 , (X-to-N "0.0" 1 1) = 0 , (X-to-N "rlx" 1 1) = nil
(defun X-to-N (n z f / r )
  (cond ((eq (type n) 'INT )(setq r n))((eq (type n) 'REAL)(setq r n))((distof n)(setq r (distof n)))(t (setq r nil)))
    (cond ((not r))((and (zerop r) (member z '(0 "0" nil)))(setq r nil)))(cond ((not r) nil)((member f '(1 "1" T))(fix r))(t (float r))))
;;; for debugging , sort of trace list
(defun record (s)(setq rec-list (cons s rec-list))) ;;; (setq rec-list nil)
;;; (setq a 1 b nil) (inspect (list 'a 'b))
(defun inspect (lst / _f)
  (defun _f (l) (apply 'strcat (cdr (apply 'append (mapcar (function (lambda (x) (list "\n" x))) l)))))
    (alert (_f (mapcar '(lambda (x) (strcat (vl-symbol-name x) " = " (vl-princ-to-string (vl-symbol-value x)))) lst))))
;; tiny lisps
;;; generate number (gnum 1 5) -> '(1 2 3 4 5)
(defun gnum (s e / i l)
  (and (numberp s)(numberp e)(setq i s)(while (<= i e)(setq l (cons i l) i (1+ i)))) (reverse l))
;;; i = startnumber n = number of numbers , d = difference (gnl- 100 6 12) -> (100 88 76 64 52 40)
;;; generate all x-coordinates between xmin=322.5 & xmax =347.5 , 5 columns
;;; (gnl- xmax col+1 (- xmax xmin))
;;; (gnl- 347.5 (1+ 5) (/ (- 347.5 322.5) 5)) -> (347.5 342.5 337.5 332.5 327.5 322.5)
(defun gnl- (i n d / l)(setq l (list i))(repeat (1- n)(setq l (cons (setq i (- i d)) l)))(reverse l))
;;; same but incremental
;;; (gnl- xmin (1+ col) (- xmax xmin))   (gnl- -10 6 (- -10 10))
;;; (gnl+ 322.5 (1+ 5) (/ (- 347.5 322.5) 5)) -> (322.5 327.5 332.5 337.5 342.5 347.5)
(defun gnl+ (i n d / l)(setq l (list i))(repeat (1- n)(setq l (cons (setq i (+ i d)) l)))(reverse l))
;;; generate midpoint list
;;; (gmpl '(10 20 30 40 ) '(100 90 80)) -> '((15 95) (25 95) (35 95)   (15 85) (25 85) (35 85))
(defun gmpl (xl yl / f x y)
  (defun f (l)(mapcar '(lambda (a b) (+ a (/ (- b a) 2.0))) l (cdr l)))
  (setq x (f '(10 20 30 40))) ;;; -> '(15.0 25.0 35.0)
  (setq y (f '(100 90 80)))   ;;; -> '(95.0 85.0)
  (mapcar '(lambda (yy) (mapcar '(lambda (xx)(cons xx yy)) (f '(10 20 30 40)))) (f '(100 90 80)))
  ;;; -> (((15.0 . 95.0) (25.0 . 95.0) (35.0 . 95.0)) ((15.0 . 85.0) (25.0 . 85.0) (35.0 . 85.0)))
(defun gmpl (xl yl / f)
  (defun f (l)(mapcar '(lambda (a b)(+ a (/ (- (float b) (float a)) 2.0))) l (cdr l)))
    (apply 'append (mapcar '(lambda (y)(mapcar '(lambda (x)(list x y 0.0))(f xl)))(f yl))))
;;; rlx_sf - sub folders : c:/temp/test -> ("c:" "temp" "test")
(defun rlx_sf ( fol / i)
  (if (setq i (vl-string-search "\\" fol))
    (cons (substr fol 1 i) (rlx_sf (substr fol (+ i 1 (strlen "\\")))))  (list fol)))
;;; rlx_mf - make folder
(defun rlx_mf ( fol / sf)
  (defun MF (rt sf) (if sf ((lambda (fol)(vl-mkdir fol)(MF fol (cdr sf)))(strcat rt "\\" (car sf)))))
    (if (setq sf (rlx_sf (vl-string-translate "/" "\\" fol))) (MF (car sf) (cdr sf))) (vl-file-directory-p fol))
;;; --- File operations ------------------------------------ File operations -------------------------------------- File operations --- ;;;
;;; load / save (data) file
;;; app-list = global list for list box , app-list is global name for data file
(defun _load ( / fn fp i lst def)
  (if (or (void GrM-App-List-File) (not (setq def (car (fnsplitl GrM-App-List-File))))
          (not (vl-file-directory-p def)))(setq def ""))
  (if (and (setq fn (getfiled "Select a data file" def "dat" 0))(setq fp (open fn "r")))
    (while (setq i (read-line fp))(setq lst (cons i lst)))) (if fp (close fp))
  (if (vl-consp lst)
      (if (and (> (length lst) 1)(member "Empty" lst))
        (setq lst (vl-remove "Empty" lst)))
      (setq GrM-App-List-File fn)
      (if (eq GrM-Sort-On-Load "1")
        (setq app-list (acad_strlsort lst))
        (setq app-list (reverse lst))
      (lb_upd)
;;; (create_default_data_file "c:\\temp\\rlx\\rlx\\xxx.xxx")
(defun create_default_data_file ( fn / split)
  (cond
    ((or (null fn) (not (eq (type fn) 'STR)) (eq fn ""))
     (alert (strcat "unable to create file : " (vl-princ-to-string fn))))
    ((findfile fn))
    (t
     (setq split (fnsplitl fn))
     (if (not (vl-file-directory-p (car split))) (rlx_mf (car split)))
     (if (setq fp (open fn "w"))
       (progn (close fp)(gc))
(defun GrM_Preload_App_List ( / fn fp lst)
  (if (and (not (void (setq fn GrM-App-List-File)))(findfile fn)(setq fp (open fn "r")))
  ;(if (vl-consp lst)(setq app-list lst)(setq app-list '("Empty")))
  (if (vl-consp lst)(setq app-list (reverse lst))(setq app-list '("Empty")))
(defun _save ( / fn fp def )
  (if (and (not (void (setq fn GrM-App-List-File)))(findfile fn)(vl-consp app-list)(setq fp (open fn "w")))
      ;;; remove "Empty" from list if items have been added
      (if (and (> (length app-list) 1)(member "Empty" app-list))
        (setq app-list (vl-remove "Empty" app-list)))
      (foreach x app-list (write-line x fp))
      (close fp)
      (gc)
(defun _saveas ( / fn fp def )
  (if (and (vl-consp app-list)(setq fn (getfiled "Select a data file" def "dat" 1))(setq fp (open fn "w")))
      (foreach x app-list (write-line x fp))(close fp)(gc)
      (setq GrM-App-List-File fn)(WriteSettingsToRegistry)
;;; add / del to / from list
;;; update : add full path instead of filename only
(defun _add ( / f d e) (setq e "lsp")
  (if (or (void GrM-App-List-File)(not (setq d (car (fnsplitl GrM-App-List-File))))(not (vl-file-directory-p d)))(setq d ""))
  (if (setq f (getfiled "Select a lisp file" d e 0))
      (if (or (not (vl-consp app-list)) (equal app-list (list "Empty")))
        (setq app-list (list f)) (setq app-list (append app-list (list f)))
      (lb_upd)
(defun _del () (setq app-list (rfl (nth idx app-list) app-list)) (lb_upd))
(defun _edit_dat_file ( / fn)
  (if (and (not (void (setq fn GrM-App-List-File)))(findfile fn))
    (progn (done_dialog) (startapp "notepad" fn)(alert "Press ok when done")(GrM_App_List_Dialog))))
(defun GrM_Start_GrRead ( / done inp)
  (setq done nil)
  (while (not done)
    (princ "\rSelect button or [B]ackground color,[CcRr] (+/- col/row),[J]ustification,[S]etup,[Z]oom (E/+/-),[Q]uit (Space/Enter/Esc/RM) :")
    (setq inp (vl-catch-all-apply 'grread (list nil 8 0)))
    (cond
      ((vl-catch-all-error-p inp)(setq done T))
      ;;; point selection
      ((= (car inp) 3)
       (setq pt (cadr inp))
       (setq id (GrM_GetCell-ID (list tb-x- tb-y+) (list tb-x+ tb-y-) (atoi GrM-NoF-Columns) (atoi GrM-NoF-Rows) pt))
       (setq app (nth id app-list) done T))
      ;;; nah, just for fun...o key cycles Justification
      ((or (equal inp '(2 106))(equal inp '(2 74)))(cycle_Justification))
      ;;; also lots of fun...B key cycles background color
      ((or (equal inp '(2 66))(equal inp '(2 98)))(cycle_color))
      ;;; s or S (setup)
      ((or (equal inp '(2 115))(equal inp '(2 83)))(GrM_Setup_Dialog_Start))
      ; user pressed E of e
      ((member inp '((2 69)(2 101))) (command "zoom" "e")(GrM_Draw_Toolbar))
      ; user pressed +
      ((equal inp '(2 43)) (vl-cmdf "zoom" "2x")(GrM_Draw_Toolbar))
      ; user pressed -
      ((equal inp '(2 45)) (vl-cmdf "zoom" ".5x")(GrM_Draw_Toolbar))
      ; user pressed z or Z
      ((member inp '((2 122)(2 90))) (vl-cmdf "'zoom" "")(GrM_Draw_Toolbar))
      ;;; Enter Space or q/Q key or R-mouse button
      ((or (equal inp '(2 13)) (equal inp '(2 32)) (equal inp '(2 113))
           (equal inp '(2 81)) (equal (car inp) 25)) (setq done T))
      ; user pressed D of d - Toggle Debug Mode
      ((member inp '((2 68)(2 100)))(Toggle_Debug_Mode))
      ;;; c (column) smaller (2 99) (GrM_IncTile "bt_nof_columns_min" 0)
      ((equal inp '(2 99)) (GrM_IncTile "bt_nof_columns_min" 0)(GrM_Draw_Toolbar))
      ;;; K (Kolom = column) bigger (2 67) (GrM_IncTile "bt_nof_columns_plus" 0)
      ((equal inp '(2 67)) (GrM_IncTile "bt_nof_columns_plus" 0)(GrM_Draw_Toolbar))
      ;;; r (row) smaller (2 114) (GrM_IncTile "bt_nof_rows_min" 0)
      ((equal inp '(2 114)) (GrM_IncTile "bt_nof_rows_min" 0)(GrM_Draw_Toolbar))
      ;;; R (row) bigger (2 82) (GrM_IncTile "bt_nof_rows_plus" 0)
      ((equal inp '(2 82)) (GrM_IncTile "bt_nof_rows_plus" 0)(GrM_Draw_Toolbar))
  (redraw)
;;; program assumes no self starting routines and start command is "C:" + app name
(defun GrM_Start_App (app / fn)
  (cond
    ((setq fn (findfile app))
     (redraw)(load fn)(eval (read (strcat "(C:" (vl-filename-base app) ")"))))
    (t (redraw)(princ (strcat "\nUnable to load " (vl-princ-to-string app) " ...bye")))
(vl-load-com)
(princ "\nGrM - Graphic Menu - Rlx - last update 2025/09/10 (added rlx_sf)")
;;; (c:GrMs) ;;; Setup Dialog
;;; (C:GrM)  ;;; Display Toolbar
@rlx will definitely have a look at it, your dcl stuff is great. One thing you can do is unzip a zip file using lisp, so could have all the files and a DAT file and save them to a known directory, as part of my Install.lsp it adds the support paths and load the toolbar.
The reason for comment was I used CIV3D so I had a custom menu that had often used Civ3D commands, this saved having to change workspaces. You just have to open the CUI and copy the commands to say notepad.
Edited by BIGAL
I'm trying to get it to work in my AutoCAD 2021, but it takes a very long time to load (about 20 seconds).
The problem seems to be with the 'Fill_Toolbar_Background' function (it appears to be duplicated).
Could it be that my slow computer is the cause?
it uses drawing units to fill the background so if your drawing is very large , like site layout or big 3D drawing , yes , then it will take a long time. You can try setting fill in setup to 10% , or I could make it a factor like 1 (vector) line per 1/10 or 1/100 per viewsize. I usually work with standard drawings A4-A0 , also site layouts but most of the time electrical diagrams and instrument loop diagrams. You could switch to paperspace and see what happens. But I will look into making backgroud fill depend of viewsize, should be fairly simple. Probably also make sure ucs is set to view when using menu in 3d drawings , never use 3d for the kind of work I do.
try this :
(defun Fill_Toolbar_Background (x- y- x+ y+ c / y vws bgf-fac delta-y)
  (setq y y- vws (getvar "viewsize") bgf-fac (/ 0.1 (/ (atof GrM-Button-Background-Fill) 100.0)))
  (setq delta-y (/ vws 1000.0))
  (while (<= y y+)(grdraw (list x- y)(list x+ y) c)(setq y (+ y (* delta-y bgf-fac (/ vws start-viewsize))))))
did very little testing though...
oh , about the 'duplicated' background fill , although there are two and the first could (should) have been deleted, it doesn't matter because lisp only evaluates the last version. Every new definition overwites the previous one.
