hello:
I would like to know if there is any LSP routine that helps me define the definition of attributes
like similar to Tcount from  master LEE MAC .
Here I attach an example dwg of the entities that I need to quantify
thanks
example.dwg
I have something that would have done what you want, but it looks for blocks with attributes, I personally only ever make blocks with say a single attribute.
Complicating it even more the display is the tag names. It's not a very nice dwg.
lastly the answer is in lst3 but you have not said what you want done with it.
; count attdefs via tagname
; BY AlanH July 2025
(defun c:wow ( / lst lst2 att cnt lst3)
(defun my-count (a L)
  (cond
   ((null L) 0)
   ((equal a (car L)) (+ 1 (my-count a (cdr L))))
   (t (my-count a (cdr L))))
; By Gile
(defun remove_doubles (lst)
  (if lst
    (cons (car lst) (remove_doubles (vl-remove (car lst) lst)))
(setq ss (ssget '((0 . "ATTDEF"))))
(setq lst '())
  (setq att (vlax-ename->vla-object (ssname ss (setq x (1- x)))))
  (setq lst (cons (vlax-get att 'tagstring) lst))
(setq lst (acad_strlsort lst))
(setq lst2 (remove_doubles lst))
(foreach val lst2
  (setq cnt (my-count val lst))
  (setq lst3 (cons (list val cnt) lst3))
