Danielm103 Posted July 18, 2025 Posted July 18, 2025 Just having some fun… A custom object that does triangulation and contours. Its very fast (I think) I’ve only tested on one drawing; Binaries are in the release folder here (AutoCAD 2025-2026, ZwCAD 2025-2026, GstarCAD 2026) https://github.com/CEXT-Dan/ArxTin Command: TINNER Select objects: Specify opposite corner: 41769 found Select objects: Enter a major contour interval: 100 Enter a minor contour interval: 10 CArxTinUIApp::CArxTinUIApp_tinner Done , 0.000235 seconds Command: LIST Select objects: CEXTDBTIN Layer: "tin" Space: Model space Color: BYLAYER Linetype: "Continuous" Handle = cb4cf Number of points: 41769 Number of triangles: 82720 Minimum elevation: 5503.992569 Maximum elevation: 7060.996567 2D area: 37224000.000000 3D area: 47335595.172935 1 1 Quote
Danielm103 Posted July 18, 2025 Author Posted July 18, 2025 There’s a sample point drawing on github TIN, Major and Minor and have transparency, but they are currently hard coded to TIN 50%, Minor 50%, Major %100 Quote
Danielm103 Posted July 18, 2025 Author Posted July 18, 2025 (edited) Oh, explode will create polylines and faces Edited July 18, 2025 by Danielm103 Quote
BIGAL Posted July 18, 2025 Posted July 18, 2025 Looks good, next option would be "Add breaklines" to make the TIN take into account edges. Quote
