Danielm103 Posted July 20 Posted July 20 updating samples, this one is cool import traceback from pyrx import Rx, Ge, Gs, Db, Ap, Ed import wx import os # extract the image and save it def extractThumbnailsFromDb(db: Db.Database, path: str, targetpath: str): path_without_extension, _ = os.path.splitext(path) dwgname = os.path.basename(path_without_extension) bt = Db.BlockTable(db.blockTableId()) for name, id in bt.asDict().items(): blk = Db.BlockTableRecord(id) if ( blk.isLayout() or blk.isAnonymous() or blk.isFromExternalReference() or blk.isFromOverlayReference() ): continue img: wx.Image = Gs.Core.getBlockImage(id, 128, 128, 1.0, [0, 0, 0]) img.SaveFile("{}/{}_{}_128.png".format(targetpath, dwgname, name), wx.BITMAP_TYPE_PNG) # read the database in its own function so the database object # gets disposed after the blocks (gc is fifo) def extractThumbnails(path: str, targetpath: str): db = Db.Database(False, True) db.readDwgFile(path) db.closeInput(True) extractThumbnailsFromDb(db, path, targetpath) # register a new command # ensure the targetpath exists @Ap.Command() def doit(): try: targetpath = "E:/temp/icons" os.makedirs(targetpath, exist_ok=True) for path in Ap.Application.listFilesInPath("E:\\temp", ".dwg"): extractThumbnails(path, targetpath) except Exception as err: traceback.print_exception(err) 1 Quote
