Beeftimer Posted 23 hours ago Posted 23 hours ago It's been a LONG time since posting, so forgive me if I'm posting in the wrong section or whatnot. I've got a 3D drawing that I'm trying to plot using the HIDDEN visual style, but the properties window (when no objects are selected) is showing 2D Wireframe (and that is indeed what the drawing is showing as). How do I change the visual style in paper space to my desired style?? I searched the forum and didn't find anything on this one. Is it a system setting??? Please help. I've attached a photo of the properties box. Quote
SLW210 Posted 13 hours ago Posted 13 hours ago I moved your thread to the AutoCAD Drawing Management & Output Forum. Try this solution... Solved: PLOTTING A VIEW OF 3D MODEL, HIDDEN VISUAL STYLE PLOTS IN COLOR - Autodesk Community Quote
Beeftimer Posted 7 hours ago Author Posted 7 hours ago 6 hours ago, SLW210 said: I moved your thread to the AutoCAD Drawing Management & Output Forum. Try this solution... Solved: PLOTTING A VIEW OF 3D MODEL, HIDDEN VISUAL STYLE PLOTS IN COLOR - Autodesk Community The accepted solution on that article is what I tried to do, although on MY properties pane, it doesn't allow me to change that visual style; it's locked. That's my problem. Why is it locked? Why can't I change it? How do I fix it? It's a dilemma. Quote
