I'm looking for a lisp that will allow me to do the exact same thing I do with TCOUNT but for multileaders.  I have a drawing where I have mleaders going to many different lines and each has three lines of text.  The first line has cable id and I want to be able to replace the last two characters of that line.  In TCOUNT I would select each mtext object in order, have the count start  at 1 and increase by 1 (1,1) and then I would have it find and replace the '0' I left at the end of each line with the sequential numbers created by TCOUNT.  This is what I need to be able to do but on all the mleaders I have in this drawing.  Anyone have something like this?
@rsdonna, please upload your sample.dwg and the TCOUNT lisp
I don't have a TCOUNT lisp.  TCOUNT is part of the express tools in AutoCAD.  It's what I use when I'm going to renumber text or mtext.  Unfortunately TCOUNT doesn't work in mleaders so I'm looking for a way to be able to do with mleaders what I do for text and mtext.
Sure, here is a sample of what I'll have in my drawings.  In my drawings I'll have maybe 50 mleaders like these and I'm looking for a way to be able to pick them in order and then have it replace the -00 at the end with the sequential numbering.  In TCOUNT I can pick what number I want it to start from and what the increment will be and then whether I want to overwrite, find and replace (which is what I need it to do), and also a prefix and a suffix option to place the text.  Thanks for your help
SAMPLE.dwg
Give this a try,  also it replaces what ever is the last 2 characters. Call it version 1.
; https://www.cadtutor.net/forum/topic/98622-tcount-for-multileaders/
; change mleader text add number on end.
; By alanH jultu 2025
(defun c:wow1 ( / num str newstr obj  len)
(setq num (getint "\nEnter start number "))
(while (setq ent (entsel "\nPick Mleader - Enter to stop. "))
 (setq obj (vlax-ename->vla-object (car ent)))
 (setq str (vlax-get obj 'textstring))
 (setq len (strlen str))
 (if (< num 10)
 (setq newstr (strcat (substr str 1 (- len 2)) "0" (rtos num 2 0)))
 (setq newstr (strcat (substr str 1 (- len 2)) (rtos num 2 0)))
 (vlax-put obj 'textstring newstr)
 (setq num (1+ num))
Edited by BIGAL
 (if (< num 10)
 (setq num (1+ num))
This is great.  Is there a way to have it still do this if there are multiple lines of text in the mleader?
I still have the wire name at the top line always but sometimes add 1 or 2 additional lines with other info about that wire.
Thanks for your help.
SAMPLE.dwg
1 hour ago, SLW210 said:
Did you try the codes in the thread I posted?
I did.  I had found it before and it is great just doesn't do exactly what i need.  I can use it to add the numbering at the end but if I need to renumber then it won't work the way I need it to.
Thank you for this.
I guess look for newline then work backwards two characters. Try this.
(defun c:wow ( / num str str1 str2 newstr obj  len )
(setq num (getint "\nEnetr start number "))
 (setq pos (vl-string-position 92 str))
 (if (= pos nil)
   (if (< num 10)
   (if (< num 10)
    (setq newstr (strcat "0" (rtos num 2 0)))
    (setq newstr (rtos num 2 0))
   (setq str1 (strcat (substr str 1 (- pos 2)) newstr))
   (setq str2 (substr str (+ pos 1)))
   (setq newstr (strcat str1 str2))
 (setq num (1+ num))
Edited by BIGAL
Thank you for this.
I linked several LISPs in that thread, which ones did you try?
I tried CopyText and MTMTMLT.  I found CopyText great as it is something that I will end up using quite a bit since I have to copy text to multiple mleaders sometimes, but neither of the ones I tried did what I was looking for unfortunately.  MTMTMLT only adds the sequential numbering at the end and doesn't let me replace what I have in the text as a place holder.  What I need replaced is always at the end of the first line and since I have multiple lines of text sometimes it doesn't work with the numbering being added at the end of all the text
There was a link to a LISP at Autodesk forums as well.
I have a few versions of my LISP as mentioned in that thread, I'll think about updating and altering one if I get time.
I need a clearly explained before and after .dwg, just go through what you do in TCOUNT, better yet show it with TCOUNT on MText as well, even with your drawings as MText, I followed the steps you gave in your first post and do not get the results you ask for.
You got lucky, stopped at work waiting on more information.
I lightly tested this on your drawings.
;;; Sequential Numbering added to MLeader, Mtext and Text as Prefix, Suffix or Find and Replace.  *|
;;; https://www.cadtutor.net/forum/topic/98622-tcount-for-multileaders/#findComment-675446        *|
;;; With help from: https://forums.augi.com/showthread.php?117315-Modify-text-in-multileader      *|
;;; By SLW210 (Steve Wilson)        *|
;;; No guarantees use at your own risk                                                            *|
;;; Original 07/28/2025        *|
;;; Thanks most to AlanJT, lpseifert and irneb (Where have y'all gone?)                           *|
;;; When asked for FIND/REPLACE, leave blank to skip.                                             *|
;;; For MTEXT/MLEADER, enter All to apply the change to all lines, or specify a line number.      *|
(vl-load-com)
(defun c:TMTMS () (c:TxtMTxtMldrSeq))	; shortcut
(defun c:TxtMTxtMldrSeq	(/	    ss	       ent	  en_obj
			 current_text	       new_text	  num
			 prefix	    suffix     numType	  i
			 entType    findStr    replaceStr lineNum
			 lineNumStr lineList   newLines
  ;; Prompt for prefix and suffix
  (setq prefix (getstring "\nEnter prefix text (or leave blank): "))
  (setq suffix (getstring "\nEnter suffix text (or leave blank): "))
  ;; Prompt for numbering type
  (setq	numType
	 (strcase
	   (getstring
	     "\nEnter 'P' for Prefix, 'S' for Suffix, or 'N' for No modification: "
  (if (not (member numType '("P" "S" "N")))
    (progn (princ "\nInvalid choice. Exiting.") (exit))
  ;; Find and Replace
  (setq	findStr
	 (getstring T "\nEnter FIND text (or press Enter to skip): ")
  (setq	replaceStr
	 (if (/= findStr "")
	   (getstring T "\nEnter REPLACE text: ")
  ;; Line number
  (initget 1 "All")
  (setq	lineNumStr
	 (getstring
	   "\nEnter line number for MTEXT/Multileader (or type 'All'): "
  (setq	lineNum	(if (wcmatch (strcase lineNumStr) "ALL")
		  nil
		  (atoi lineNumStr)
  ;; Get selection set
  (setq ss (ssget '((0 . "TEXT,MTEXT,MULTILEADER"))))
  (if (not ss)
    (progn (princ "\nNo valid text entities found.") (exit))
  ;; Loop through entities
  (setq i 0)
  (repeat (sslength ss)
    (setq ent (ssname ss i))
    (setq en_obj (vlax-ename->vla-object ent))
    (setq entType (cdr (assoc 0 (entget ent))))
    (setq current_text (vla-get-TextString en_obj))
    (setq num (itoa (1+ i)))
    ;; Find & replace
    (if	(and (/= findStr "") (/= replaceStr ""))
      (setq current_text
	     (vl-string-subst replaceStr findStr current_text)
    (cond
      ;; TEXT
      ((= entType "TEXT")
       (setq new_text
	      (cond
		((= numType "P") (strcat prefix num " " current_text))
		((= numType "S") (strcat current_text " " suffix num))
		((= numType "N") current_text)
       (vla-put-TextString en_obj new_text)
      ;; MTEXT or MULTILEADER
      ((or (= entType "MTEXT") (= entType "MULTILEADER"))
       (setq lineList (split-text-lines current_text))
       (setq newLines
	      (if (and lineNum (> lineNum 0) (<= lineNum (length lineList)))
		;; Modify specific line
		(mapcar
		  '(lambda (line idx)
		     (if (= idx (1- lineNum))
		       (cond
			 ((= numType "P") (strcat prefix num " " line))
			 ((= numType "S") (strcat line " " suffix num))
			 ((= numType "N") line)
		       line
		  lineList
		  (number-seq 0 (1- (length lineList)))
		;; Modify all lines
		(mapcar
		  '(lambda (line)
		     (cond
		  lineList
       ;; Combine lines
       (setq new_text
	      (apply 'strcat
		     (mapcar '(lambda (l) (strcat l "\\P")) newLines)
    (setq i (1+ i))
  (princ "\nModifications completed.")
;; Split text into lines (MTEXT line delimiter = \P)
(defun split-text-lines	(txt)
  (vl-remove-if 'null (parse txt "\\P"))
;; Parse string by delimiter
(defun parse (str delim / result pos start)
  (setq start 1)
  (while (setq pos (vl-string-search delim str (1- start)))
    (setq result (cons (substr str start (- pos start)) result))
    (setq start (+ pos (strlen delim) 1))
  (reverse (cons (substr str start) result))
;; Create list of numbers from start to end
(defun number-seq (start end)
  (if (> start end)
    nil
    (cons start (number-seq (1+ start) end))
I left the options from the other LISP, due to time, if you want or I get more time, I might remove the other options.
