motee-z Posted July 30, 2025 Posted July 30, 2025 Hello friends i have in attached drawing 2 3dfaces i want to apply command loft on first one and second one but when selecting first 3d face it rejected and said invalid object i was filtered out but when moving or copying this object to some other places it worked so i want an explanation of what is happening loft on 3dface.dwg Quote
motee-z Posted August 4, 2025 Author Posted August 4, 2025 where are experts of autocad no answer since five days Quote
SLW210 Posted August 5, 2025 Posted August 5, 2025 AutoCAD gets strange sometimes when objects get far away from 0,0,0. That's all I can come up with. Quote
yangguoshe Posted January 4 Posted January 4 First, use the region command to convert two 3D faces into regions, then you can use the loft command to create a loft surface, and then use the surfsculpt command to create a 3D solid Quote
