I have developed the attached dynamic block which positions nested blocks according to the distance value set in a block properties table.
To avoid text mirroring of the nested block labels I have used attributes and added a flip action.
This all works well until I try and change the length after a flip.  It appears the xpos value in the block properties table is applied as positive despite the flip state.
I have tried changing the point parameters to stretch parameters but have similar problems, especially when rotating the assembly to different angles.
I was hoping something as simple as adding a formulae into the block properties table ie dist*flipstate would work but there doesn't seem to be anyway to do this.
Is there a way to solve this?
jam3.dwg
