jamami Posted 22 hours ago Posted 22 hours ago I have developed the attached dynamic block which positions nested blocks according to the distance value set in a block properties table. To avoid text mirroring of the nested block labels I have used attributes and added a flip action. This all works well until I try and change the length after a flip. It appears the xpos value in the block properties table is applied as positive despite the flip state. I have tried changing the point parameters to stretch parameters but have similar problems, especially when rotating the assembly to different angles. I was hoping something as simple as adding a formulae into the block properties table ie dist*flipstate would work but there doesn't seem to be anyway to do this. Is there a way to solve this? jam3.dwg Quote
SLW210 Posted 4 hours ago Posted 4 hours ago No time for me to look at your blocks, but have you looked into constraints? I have some dynamic block with lots of actions and even constrained if you do things in a weird order they can get a little off. So make sure length is set before the flip action. Probably could constrain them more or different. I don't know. I'll see what time I have today, but I am at work for a shorter time today than usual. Quote
jamami Posted 1 hour ago Author Posted 1 hour ago Problem is we cannot always set the length prior to flip as we need to find the right size after the flip. I am trying a few different methods hopefully I can get this to work Quote
