Nikon Posted 2 hours ago Author Posted 2 hours ago 11 hours ago, Steven P said: Edited: See if this works. I have put the other routines as sub routines (LM:Unformat and DoUnformatTable). Changed the text modifying about so it uses entmod instead of vla (personal preference) Try it and see if it works - if it does then the unformat part (Lee Macs) is working as expected (it usually does) and there is something you'll be wanting to look at in the code you added. @Steven P thanks. I ran your code, but unfortunately the mtexts were deleted again. Quote
