p7q Posted August 20, 2025 Posted August 20, 2025 Hi everyone, I'm working with a large AutoLISP routine that sets the Z elevation of all objects to 0 — similar to a custom Z0 command. It handles a wide range of entity types including: LINEs, ARCs, CIRCLEs, POLYLINEs (both 2D and 3D), LWPOLYLINEs, SPLINEs, HATCHes, TEXT, MTEXT, DIMENSIONs, INSERTs (blocks), including nested block content, and REGION entities. What it does: For each entity, I check its Z elevation and flatten it: For regular entities, I modify their coordinate group codes (10, 11, etc.) using entmod, or use vla-put-elevation where applicable. For INSERTs, I dive into their nested entities and apply the same logic. For REGIONs, I currently copy and explode them temporarily, analyze the resulting geometry to determine the average Z, then move the original REGION to Z=0. My problem: The command works fine, but performance is a major issue, especially on complex or large drawings. What are the best ways to optimize performance for a routine like this? Is there a better way to flatten REGIONs without exploding them? Specifically, is there a way (maybe via a filter or a helper LISP) to select only entities whose Z coordinate is not zero? That would allow me to skip processing objects that are already flat and significantly improve performance. Thanks a lot in advance for any suggestions! Quote
Steven P Posted August 20, 2025 Posted August 20, 2025 Here is a quick example, (ssget (list '(-4 . "<OR") '(-4 . "*,*,<>") (list 10 0.0 0.0 0.0) '(-4 . "*,*,<>") (list 11 0.0 0.0 0.0) '(-4 . "OR>") )) Should select the more simple entities not at 0 elevation - not sure it will work for 3d polylines for example, but should be OK for lines, circles, arcs and so on and apply similar to others? Quote
Steven P Posted August 20, 2025 Posted August 20, 2025 I guess the flatten command has some limitations for you (I've never been 100% with trusting flatten) Quote
p7q Posted August 20, 2025 Author Posted August 20, 2025 5 minutes ago, Steven P said: I guess the flatten command has some limitations for you (I've never been 100% with trusting flatten) yes flatten is not working sometimes block, pline, dimension. So ı need this lisp. 8 minutes ago, Steven P said: Here is a quick example, (ssget (list '(-4 . "<OR") '(-4 . "*,*,<>") (list 10 0.0 0.0 0.0) '(-4 . "*,*,<>") (list 11 0.0 0.0 0.0) '(-4 . "OR>") )) Should select the more simple entities not at 0 elevation - not sure it will work for 3d polylines for example, but should be OK for lines, circles, arcs and so on and apply similar to others? this lips so limited. for exaple there are multiple 10 dxf data in POLYLINE. I need something more comprehensive Quote
mhupp Posted August 20, 2025 Posted August 20, 2025 Can't really tell you how to optimize code you didn't post, but when people first get into lisp the rely heavily on command because its follows what you would type into the command line. It become apparent in a loop processing 1000's of entity's that its quite inefficient. rather then using entmod or some other way to update model. If flatten doesn' work also try the command Change > elevation > 0 1 1 Quote
Steven P Posted August 20, 2025 Posted August 20, 2025 1 hour ago, p7q said: this lips so limited. for exaple there are multiple 10 dxf data in POLYLINE. I need something more comprehensive That would get most of the simpler entities such as lines, text, circles and so on. LWPolylines you can add another "or": '(-4 . "<>") (cons 38 0.0) and so on building up the selection set filter that way: (ssget (list '(-4 . "<OR") '(-4 . "*,*,<>") (list 10 0.0 0.0 0.0) '(-4 . "*,*,<>") (list 11 0.0 0.0 0.0) '(-4 . "<>") (cons 38 0) '(-4 . "OR>") )) For 3d polylines, for example, so long as the first point (first dxf code 10 in the entity description) isn't at zero elevation it should also grab them too. However if this only removes lines, LWPolylines, circles, arcs, texts, ellipses... it should reduce the amount of processing. Depends how you are doing it but the blocks might be your slow point. Quote
p7q Posted August 20, 2025 Author Posted August 20, 2025 45 minutes ago, mhupp said: Can't really tell you how to optimize code you didn't post, but when people first get into lisp the rely heavily on command because its follows what you would type into the command line. It become apparent in a loop processing 1000's of entity's that its quite inefficient. rather then using entmod or some other way to update model. If flatten doesn' work also try the command Change > elevation > 0 I trid Change > elevation > 0 but not working. I can't share the full code, but for REGION entities, I'm currently using a method that copies and explodes them to get the Z values, then moves the original REGION to Z=0. I know it's not efficient, but it works. ((equal entType "REGION") (vl-catch-all-apply (function (lambda () (setq zList '()) (setq before (ssget "_X")) (command "regen") (command "_.copy") (command obj) (command "") (command '(0 0 0) '(0 0 0)) (setq newent (entlast)) (command "_.explode" newent) (setq after (ssget "_X")) (setq newents '()) (setq j 0) (while (< j (sslength after)) (setq ent (ssname after j)) (if (not (ssmemb ent before)) (setq newents (cons ent newents)) ) (setq j (1+ j)) ) (foreach e newents (setq entdata (entget e)) (cond ((= (cdr (assoc 0 entdata)) "LINE") (setq z1 (nth 2 (cdr (assoc 10 entdata)))) (setq z2 (nth 2 (cdr (assoc 11 entdata)))) (setq zList (cons z1 zList)) (setq zList (cons z2 zList)) ) ((member (cdr (assoc 0 entdata)) '("ARC" "CIRCLE" "ELLIPSE") ) (setq z1 (nth 2 (cdr (assoc 10 entdata)))) (setq zList (cons z1 zList)) ) ) ) (setq ztotal 0) (if (< 0 (length zList)) (progn (foreach z zList (setq ztotal (+ ztotal z))) (setq zmid (/ ztotal (length zList))) (command "_.MOVE" obj "" '(0 0 0) (list 0.0 0.0 (* zmid -1)) ) ) ) (foreach e newents (entdel e)) ) ) ) ) And also is there a way to use ssget to select only entities that have non-zero Z values? Quote
Steven P Posted August 20, 2025 Posted August 20, 2025 (edited) Depends what you are using for obj, if it is an entity name this is a bit quicker: (command "_.copy") (command obj) (command "") (command '(0 0 0) '(0 0 0)) (setq newent (entlast)) (command "_.explode" newent) becomes (command "_.Explode" (setq NewEnt (entmakex (entget obj)) ) ) where obj might be from (car (entsel)) or (ssname MySS number) Might want to look at the number of loops in the snippet you posted Edited August 20, 2025 by Steven P 2 Quote
Steven P Posted August 20, 2025 Posted August 20, 2025 (edited) Just to amuse myself, here is a snippet that will flatten simple entities, not sure if that helps you along the way - you can use what code works for 3d polylines, hatches, regions and blocks - might be a bit quicker Command: NewFlatten An edit for later... (defun FlattenLines ( Pt1 Pt2 / MySS MyEnt acount ed) ;;For arcs, attdef, circle, (dimension N/A), Insert, Line, LWPolyline, Mtext, Point, text, ;;Does lines, circles, arcs, ellipses, texts, LWPolylines (if (< (car pt1)(car pt2)) (setq MySS (ssget "_W" pt1 pt2 (list '(-4 . "<OR") '(-4 . "*,*,<>") (list 10 0.0 0.0 0.0) '(-4 . "*,*,<>") (list 11 0.0 0.0 0.0) '(-4 . "<>") (cons 38 0) '(-4 . "OR>") ))) ; end list, ssget, setq (setq MySS (ssget "_C" pt1 pt2 (list '(-4 . "<OR") '(-4 . "*,*,<>") (list 10 0.0 0.0 0.0) '(-4 . "*,*,<>") (list 11 0.0 0.0 0.0) '(-4 . "<>") (cons 38 0) '(-4 . "OR>") ))) ; end list, ssget, setq ) ; end f ; (setq MySS (ssget "_X" (list ; '(-4 . "<OR") ; '(-4 . "*,*,<>") (list 10 0.0 0.0 0.0) ; '(-4 . "*,*,<>") (list 11 0.0 0.0 0.0) ; '(-4 . "<>") (cons 38 0) ; '(-4 . "OR>") ; ))) ; end list, ssget, setq (setq acount 0) (while (< acount (sslength MySS)) (setq MyEnt (ssname MySS acount)) (setq ed (entget MyEnt)) (if (equal (assoc 0 ed) (cons 0 "LWPOLYLINE")) (progn (entmod (setq ed (subst (cons 38 0) (assoc 38 ed) ed) )) ;; Elevation to 0 ) ; end progn (progn (entmod (setq ed (subst (cons 10 (mapcar '* '(1 1 0) (cdr (assoc 10 ed)))) (assoc 10 ed) ed)) ) (entmod (setq ed (subst (cons 11 (mapcar '* '(1 1 0) (cdr (assoc 11 ed)))) (assoc 11 ed) ed)) ) ) ; end progn ) ; end if (setq acount (+ acount 1)) ) ; end while ) (defun SSMouseOrder ( / MyList MySS pt1 pt2 MyEnt SelSS MySS MyDuir acount) ;; Enttypelist: wildcards are OK but not for single selection. ;; Enttypelist in CAPITALS for single entity selection to work. (princ " (Crossing selection, not single picks please). ") ;;Set up LISP (setq MySS (ssadd)) ;; Blank Selelection Set (if (= EntTypeList nil)(setq EntTypeList (list "LINE" "ARC" "CIRCLE")) ) ;; default entity filter (setq MyList (list (cons -4 "<OR") )) ;; Create filter to use with ssget (foreach n EntTypeList (setq MyList (append MyList (list (cons 0 n)) ) ) ) ; end foreach (setq MyList (append MyList (list (cons -4 "OR>")) ) ) (while (setq pt1 (getpoint "Select Objects:"));; Loop to select entities (setq pta pt1) ; record pt1 selected (if (setq MyEnt (car (nentselp pt1))) ;; If 1st point selected was on an entity: Single entity selected (progn (if (ssdel MyEnt MySS) ;; If entity is in selected selection set, delete it (progn (redraw MyEnt 4) ;; Take away highlight ) (progn ;; Else add single entity to selection set (If (member (cdr (assoc 0 (entget MyEnt))) EntTypeList) ;;Check entity type is desired (progn (setq MySS (ssadd MyEnt MySS)) ;; Add to selection set (princ (strcat " 1 Found, ")) ;; Report selection found (redraw MyEnt 3) ;; highlight entity ) ; end progn ) ; end if member ) ; end progn ) ; end if ssdel ) ; end progn (progn ;; Else if clicked point not an entity (setq pt2 (getcorner pt1 " Specify Opposite Corner")) ;;get 2nd point (if (< (car pt1)(car pt2)) ;; Left to right, right to left to determine window or crossing filter (setq SelSS (ssget "_W" pt1 pt2 MyList) ) ;; Get selected entities (setq SelSS (ssget "_C" pt1 pt2 MyList) ) ) (setq acount 0) (if SelSS ;; If anything was selected (progn (princ (strcat " " (rtos (sslength SelSS) 2 0) " Found, ")) ;; report how many entities selected (while (< acount (sslength SelSS)) ;; add entities to selection set (setq MySS (ssadd (ssname SelSS acount) MySS)) (redraw (ssname SelSS acount) 3) ;; Highlight each entity (setq acount (+ acount 1)) ;; Loop counter ) ; end while ) ; end progn ) ; end if SelSS ) ; end progn ) ; end if MyEnt (setq MyDir 0) ;; Work out mouse click directions. Note single selection direction is LL->UR (if (< (cadr pt1)(cadr pt2)) ;; Horizontal (setq MyDir 0) (setq MyDir 1) ) (if (< (car pt1)(car pt2)) ;; Vertical (setq MyDir (+ MyDir 0)) (setq MyDir (+ MyDir 2)) ) ) ; end while (setq acount 0) ;; clear highlights (while (< acount (sslength MySS)) (redraw (ssname MySS acount) 4) (setq acount (+ acount 1)) ) (if (= (sslength MySS) 0) ;; report the selection set and direction or nil if no selection nil (list MySS MyDir) ;; MyDir: 0 BL->TR (or point selection), 1 TL->BR, 2 BR->TL, 3 TR->BL ) (list pta pt2 MyDir) ; MyDir 0, 1-> L to R, 2, 3 -> R to L ) (defun c:NewFlatten ( / Pts) (princ "Selection: ") (setq Pts (SSMouseOrder)) ;;Mouse order returns Selection set points. Used later. (FlattenLines (car Pts) (cadr Pts) ) ;; flatten simple entities ) ; end defun Edited August 20, 2025 by Steven P 2 Quote
mhupp Posted August 20, 2025 Posted August 20, 2025 (edited) Change elevation only works if all points are on the same Z elevation. this might be why also flatten isn't working for you. Two things you can do to speed up. Combine all the commands into one call like you did below Command has some type of "lag" but for example lets just call it 100ms this would remove 500ms for each loop. Not to mention all the command line spam. (setvar cmdecho 0) when you sent LastEnt anything created or modified is "behind" LastEnt in the drawing and can be added to a selection set with a simple loop. rather then selecting everything in the drawing and checking against the before selection set to find the new items. (setq zList '()) ;(setq before (ssget "_X")) ;not needed anymore (command "regen" "_.copy" obj "" '(0 0 0) '(0 0 0)) (setq LastEnt (entlast)) ;set right before you create/modify objects. you want to either add to a selection (command "_.explode" newent) (while (setq LastEnt (entnext LastEnt)) ;after entities are created this will add them to a selection set. (ssadd LastEnt newents) ) (foreach e newents -edit typo in code Edited August 20, 2025 by mhupp 2 Quote
Steven P Posted August 20, 2025 Posted August 20, 2025 Thanks MHUPP - that was a thought I'd add for the OP tomorrow, can copy and paste from here rather than try to remember where I last used last ent. 1 Quote
Tsuky Posted August 20, 2025 Posted August 20, 2025 Hi, Here is a code that projected simples entities : POLYLINE,LWPOLYLINE,LINE,SPLINE,ARC,CIRCLE,ELLIPSE,POINT. on the SCG at a Z-coordinate to zero if as the entities of start are in a UCS parallel or not. For example, a circle in a UCS non-parallel will become an ellipse. I do this because this is much faster than FLATTEN (which is more efficient: it can handle more entities, but slow) If it can help... (defun l-coor2l-pt (lst flag / ) (if lst (cons (list (car lst) (cadr lst) (if flag (+ (if (vlax-property-available-p ename 'Elevation) (vlax-get ename 'Elevation) 0.0) (caddr lst)) (if (vlax-property-available-p ename 'Elevation) (vlax-get ename 'Elevation) 0.0) ) ) (l-coor2l-pt (if flag (cdddr lst) (cddr lst)) flag) ) ) ) (vl-load-com) (defun c:my_project ( / jspl nbr n AcDoc Space UCS save_ucs WCS ent_name indx l_blg l_pt ename id_obj pl_typ index nw_pl) (setq jspl (ssget '((-4 . "<OR") (-4 . "<AND") (0 . "POLYLINE") (-4 . "<NOT") (-4 . "&") (70 . 112) (-4 . "NOT>") (-4 . "AND>") (0 . "LWPOLYLINE,LINE,SPLINE,ARC,CIRCLE,ELLIPSE,POINT") (-4 . "OR>")) ) nbr -1 n 0 ) (cond (jspl (setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object)) Space (if (eq (getvar "CVPORT") 1) (vla-get-PaperSpace AcDoc) (vla-get-ModelSpace AcDoc) ) UCS (vla-get-UserCoordinateSystems AcDoc) save_ucs (vla-add UCS (vlax-3d-point '(0.0 0.0 0.0)) (vlax-3d-point (getvar "UCSXDIR")) (vlax-3d-point (getvar "UCSYDIR")) "CURRENT_UCS" ) ) (vla-put-Origin save_ucs (vlax-3d-point (getvar "UCSORG"))) (vla-StartUndoMark AcDoc) (setq WCS (vla-add UCS (vlax-3d-Point '(0.0 0.0 0.0)) (vlax-3d-Point '(1.0 0.0 0.0)) (vlax-3d-Point '(0.0 1.0 0.0)) "TEMP_WCS")) (vla-put-activeUCS AcDoc WCS) (repeat (sslength jspl) (setq ent_name (ssname jspl (setq nbr (1+ nbr))) indx -1 l_blg nil l_pt nil ename (vlax-ename->vla-object ent_name) id_obj (vla-get-ObjectName ename) ) (cond ((member id_obj '("AcDbPolyline" "AcDb2dPolyline" "AcDb3dPolyline")) (setq pl_typ (if (vlax-property-available-p ename 'Type) (vlax-get ename 'Type))) (if (member id_obj '("AcDbPolyline" "AcDb2dPolyline")) (if (not (equal (vlax-get ename 'Normal) '(0.0 0.0 1.0) 1E-13)) (progn (repeat (fix (vlax-curve-getEndParam ename)) (setq l_pt (cons (vlax-curve-GetPointAtParam ename (setq indx (1+ indx))) l_pt) index (float indx)) (if (or (eq pl_typ 1) (if (< pl_typ 3) (not (zerop (vla-GetBulge ename indx))))) (while (eq indx (fix (+ 0.01 index))) (setq l_pt (cons (vlax-curve-GetPointAtParam ename (setq index (+ 0.01 index))) l_pt)) ) ) ) (setq l_pt (cons (vlax-curve-getEndPoint ename) l_pt)) ) (setq l_pt (mapcar '(lambda (x) (trans (list (car x) (cadr x) (- ;+ (if (eq id_obj "AcDbPolyline") (caddr x) 0.0) (if (vlax-property-available-p ename 'Elevation) (vlax-get ename 'Elevation) 0.0) ) ) ent_name 0 ) ) (l-coor2l-pt (vlax-get ename 'Coordinates) (eq id_obj "AcDb2dPolyline")) ) ) ) (setq l_pt (l-coor2l-pt (vlax-get ename 'Coordinates) T)) ) (if (eq (vla-get-ObjectName ename) "AcDbPolyline") (setq nw_pl (vlax-invoke Space 'AddLightWeightPolyline (apply 'append (mapcar 'list (mapcar 'car l_pt) (mapcar 'cadr l_pt))))) (setq nw_pl (vlax-invoke Space 'AddPolyline (apply 'append l_pt))) ) (vla-put-Normal nw_pl (vlax-3d-point '(0 0 1))) (if (vlax-property-available-p ename 'Type) (progn (setq pl_typ (if (eq (vla-get-ObjectName ename) "AcDb3dPolyline") (if (zerop (vlax-get ename 'Type)) (vlax-get ename 'Type) (1+ (vlax-get ename 'Type))) (vlax-get ename 'Type) ) ) (if (and (vlax-property-available-p ename 'Normal) (not (equal (vlax-get ename 'Normal) '(0.0 0.0 1.0) 1E-13)) (eq pl_typ 1)) (vla-put-Type nw_pl 0) (vla-put-Type nw_pl pl_typ) ) ) (if (and (vlax-property-available-p ename 'Normal) (equal (vlax-get ename 'Normal) '(0 0 1) 1E-13)) (progn (repeat (length l_pt) (setq l_blg (cons (vla-GetBulge ename (setq indx (1+ indx))) l_blg))) (foreach el l_blg (vla-SetBulge nw_pl indx el) (setq indx (1- indx))) ) ) ) (vla-put-Closed nw_pl (vlax-get ename 'Closed)) ) ((member id_obj '("AcDbEllipse" "AcDbCircle" "AcDbArc")) (if (not (equal (vlax-get ename 'Normal) '(0.0 0.0 1.0) 1E-13)) (progn (setq index (vlax-curve-getStartParam ename) l_pt (list (vlax-curve-GetPointAtParam ename index)) ) (while (< (setq index (+ 0.01 index)) (vlax-curve-getEndParam ename)) (setq l_pt (cons (vlax-curve-GetPointAtParam ename index) l_pt)) ) (setq nw_pl (vlax-invoke Space 'AddLightWeightPolyline (apply 'append (mapcar 'list (mapcar 'car l_pt) (mapcar 'cadr l_pt))))) ) (cond ((eq id_obj "AcDbEllipse") (setq l_pt (vlax-get ename 'Center) nw_pl (vlax-invoke Space 'AddEllipse (list (car l_pt) (cadr l_pt) 0.0) (list (car (vlax-get ename 'MajorAxis)) (cadr (vlax-get ename 'MajorAxis)) 0.0) (* (caddr (vlax-get ename 'Normal)) (vlax-get ename 'RadiusRatio)) ) ) (vla-put-Normal nw_pl (vlax-3d-point '(0 0 1))) (vla-put-StartAngle nw_pl (vlax-get ename 'StartAngle)) (vla-put-StartParameter nw_pl (vlax-get ename 'StartParameter)) (vla-put-EndParameter nw_pl (vlax-get ename 'EndParameter)) ) ((or (eq id_obj "AcDbArc") (eq id_obj "AcDbCircle")) (setq l_pt (vlax-get ename 'Center) nw_pl (if (eq id_obj "AcDbArc") (vlax-invoke Space 'AddArc (list (car l_pt) (cadr l_pt) 0.0) (vlax-get ename 'Radius) (vlax-get ename 'StartAngle) (vlax-get ename 'EndAngle)) (vlax-invoke Space 'AddCircle (list (car l_pt) (cadr l_pt) 0.0) (vlax-get ename 'Radius)) ) ) (vla-put-Normal nw_pl (vlax-3d-point '(0 0 1))) ) ) ) ) ((eq id_obj "AcDbSpline") (if (or (zerop (vlax-get ename 'IsPlanar)) (and (not (zerop (vlax-get ename 'IsPlanar))) (not (equal (cdr (assoc 210 (entget ent_name))) '(0.0 0.0 1.0) 1E-13)) ) ) (progn (setq index (vlax-curve-getStartParam ename) l_pt (list (vlax-curve-GetPointAtParam ename index)) ) (while (< (setq index (+ 10.0 index)) (vlax-curve-getEndParam ename)) (setq l_pt (cons (vlax-curve-GetPointAtParam ename index) l_pt)) ) (setq nw_pl (vlax-invoke Space 'AddLightWeightPolyline (apply 'append (mapcar 'list (mapcar 'car l_pt) (mapcar 'cadr l_pt))))) ) (progn (setq l_pt (l-coor2l-pt (if (zerop (vlax-get ename 'NumberOfFitPoints)) (cdddr (reverse (cdddr (reverse (vlax-get ename 'ControlPoints))))) (vlax-get ename 'FitPoints)) T) nw_pl (vlax-invoke Space 'AddSpline (apply 'append (mapcar '(lambda (x y) (list x y 0.0)) (mapcar 'car l_pt) (mapcar 'cadr l_pt))) (list (car (vlax-curve-getFirstDeriv ename 0)) (cadr (vlax-curve-getFirstDeriv ename 0)) 0.0) (list (car (vlax-curve-getFirstDeriv ename (vlax-curve-getEndParam ename))) (cadr (vlax-curve-getFirstDeriv ename (vlax-curve-getEndParam ename))) 0.0) ) l_pt (l-coor2l-pt (vlax-get ename 'ControlPoints) T) ) (vla-put-ControlPoints nw_pl (vlax-make-variant (vlax-safearray-fill (vlax-make-safearray vlax-vbDouble (cons 0 (1- (* (length l_pt) 3))) ) (apply 'append (mapcar '(lambda (x y) (list x y 0.0)) (mapcar 'car l_pt) (mapcar 'cadr l_pt))) ) ) ) ) ) ) ((eq id_obj "AcDbLine") (setq nw_pl (vlax-invoke Space 'AddLine (list (car (vlax-get ename 'StartPoint)) (cadr (vlax-get ename 'StartPoint)) 0.0) (list (car (vlax-get ename 'EndPoint)) (cadr (vlax-get ename 'EndPoint)) 0.0) ) ) (vla-put-Normal nw_pl (vlax-3d-point '(0 0 1))) ) ((eq id_obj "AcDbPoint") (setq nw_pl (vlax-invoke Space 'AddPoint (list (car (vlax-get ename 'Coordinates)) (cadr (vlax-get ename 'Coordinates)) 0.0) ) ) (vla-put-Normal nw_pl (vlax-3d-point '(0 0 1))) ) ) (vla-put-TrueColor nw_pl (vla-get-TrueColor ename)) (vla-put-LineType nw_pl (vla-get-LineType ename)) (vla-put-LinetypeScale nw_pl (vla-get-LinetypeScale ename)) (vla-put-Lineweight nw_pl (vla-get-Lineweight ename)) (vla-put-Material nw_pl (vla-get-Material ename)) (vla-put-Layer nw_pl (vla-get-Layer ename)) (vla-delete ename) ) (and save_ucs (vla-put-activeUCS AcDoc save_ucs)) (and WCS (vla-delete WCS) (setq WCS nil)) (vla-EndUndoMark AcDoc) (princ (strcat "\n" (itoa (sslength jspl)) " entity(s) submissive to the command. ENDED !" ) ) ) (T (princ "\nNo compliant entities selected..!")) ) (prin1) ) 1 Quote
p7q Posted August 21, 2025 Author Posted August 21, 2025 14 hours ago, Steven P said: Depends what you are using for obj, if it is an entity name this is a bit quicker: (command "_.copy") (command obj) (command "") (command '(0 0 0) '(0 0 0)) (setq newent (entlast)) (command "_.explode" newent) becomes (command "_.Explode" (setq NewEnt (entmakex (entget obj)) ) ) where obj might be from (car (entsel)) or (ssname MySS number) Might want to look at the number of loops in the snippet you posted thanks @Steven P. ı added and its work but ı dont sure more faster than previous Quote
p7q Posted August 21, 2025 Author Posted August 21, 2025 13 hours ago, Steven P said: Just to amuse myself, here is a snippet that will flatten simple entities, not sure if that helps you along the way - you can use what code works for 3d polylines, hatches, regions and blocks - might be a bit quicker Command: NewFlatten An edit for later... (defun FlattenLines ( Pt1 Pt2 / MySS MyEnt acount ed) ;;For arcs, attdef, circle, (dimension N/A), Insert, Line, LWPolyline, Mtext, Point, text, ;;Does lines, circles, arcs, ellipses, texts, LWPolylines (if (< (car pt1)(car pt2)) (setq MySS (ssget "_W" pt1 pt2 (list '(-4 . "<OR") '(-4 . "*,*,<>") (list 10 0.0 0.0 0.0) '(-4 . "*,*,<>") (list 11 0.0 0.0 0.0) '(-4 . "<>") (cons 38 0) '(-4 . "OR>") ))) ; end list, ssget, setq (setq MySS (ssget "_C" pt1 pt2 (list '(-4 . "<OR") '(-4 . "*,*,<>") (list 10 0.0 0.0 0.0) '(-4 . "*,*,<>") (list 11 0.0 0.0 0.0) '(-4 . "<>") (cons 38 0) '(-4 . "OR>") ))) ; end list, ssget, setq ) ; end f ; (setq MySS (ssget "_X" (list ; '(-4 . "<OR") ; '(-4 . "*,*,<>") (list 10 0.0 0.0 0.0) ; '(-4 . "*,*,<>") (list 11 0.0 0.0 0.0) ; '(-4 . "<>") (cons 38 0) ; '(-4 . "OR>") ; ))) ; end list, ssget, setq (setq acount 0) (while (< acount (sslength MySS)) (setq MyEnt (ssname MySS acount)) (setq ed (entget MyEnt)) (if (equal (assoc 0 ed) (cons 0 "LWPOLYLINE")) (progn (entmod (setq ed (subst (cons 38 0) (assoc 38 ed) ed) )) ;; Elevation to 0 ) ; end progn (progn (entmod (setq ed (subst (cons 10 (mapcar '* '(1 1 0) (cdr (assoc 10 ed)))) (assoc 10 ed) ed)) ) (entmod (setq ed (subst (cons 11 (mapcar '* '(1 1 0) (cdr (assoc 11 ed)))) (assoc 11 ed) ed)) ) ) ; end progn ) ; end if (setq acount (+ acount 1)) ) ; end while ) (defun SSMouseOrder ( / MyList MySS pt1 pt2 MyEnt SelSS MySS MyDuir acount) ;; Enttypelist: wildcards are OK but not for single selection. ;; Enttypelist in CAPITALS for single entity selection to work. (princ " (Crossing selection, not single picks please). ") ;;Set up LISP (setq MySS (ssadd)) ;; Blank Selelection Set (if (= EntTypeList nil)(setq EntTypeList (list "LINE" "ARC" "CIRCLE")) ) ;; default entity filter (setq MyList (list (cons -4 "<OR") )) ;; Create filter to use with ssget (foreach n EntTypeList (setq MyList (append MyList (list (cons 0 n)) ) ) ) ; end foreach (setq MyList (append MyList (list (cons -4 "OR>")) ) ) (while (setq pt1 (getpoint "Select Objects:"));; Loop to select entities (setq pta pt1) ; record pt1 selected (if (setq MyEnt (car (nentselp pt1))) ;; If 1st point selected was on an entity: Single entity selected (progn (if (ssdel MyEnt MySS) ;; If entity is in selected selection set, delete it (progn (redraw MyEnt 4) ;; Take away highlight ) (progn ;; Else add single entity to selection set (If (member (cdr (assoc 0 (entget MyEnt))) EntTypeList) ;;Check entity type is desired (progn (setq MySS (ssadd MyEnt MySS)) ;; Add to selection set (princ (strcat " 1 Found, ")) ;; Report selection found (redraw MyEnt 3) ;; highlight entity ) ; end progn ) ; end if member ) ; end progn ) ; end if ssdel ) ; end progn (progn ;; Else if clicked point not an entity (setq pt2 (getcorner pt1 " Specify Opposite Corner")) ;;get 2nd point (if (< (car pt1)(car pt2)) ;; Left to right, right to left to determine window or crossing filter (setq SelSS (ssget "_W" pt1 pt2 MyList) ) ;; Get selected entities (setq SelSS (ssget "_C" pt1 pt2 MyList) ) ) (setq acount 0) (if SelSS ;; If anything was selected (progn (princ (strcat " " (rtos (sslength SelSS) 2 0) " Found, ")) ;; report how many entities selected (while (< acount (sslength SelSS)) ;; add entities to selection set (setq MySS (ssadd (ssname SelSS acount) MySS)) (redraw (ssname SelSS acount) 3) ;; Highlight each entity (setq acount (+ acount 1)) ;; Loop counter ) ; end while ) ; end progn ) ; end if SelSS ) ; end progn ) ; end if MyEnt (setq MyDir 0) ;; Work out mouse click directions. Note single selection direction is LL->UR (if (< (cadr pt1)(cadr pt2)) ;; Horizontal (setq MyDir 0) (setq MyDir 1) ) (if (< (car pt1)(car pt2)) ;; Vertical (setq MyDir (+ MyDir 0)) (setq MyDir (+ MyDir 2)) ) ) ; end while (setq acount 0) ;; clear highlights (while (< acount (sslength MySS)) (redraw (ssname MySS acount) 4) (setq acount (+ acount 1)) ) (if (= (sslength MySS) 0) ;; report the selection set and direction or nil if no selection nil (list MySS MyDir) ;; MyDir: 0 BL->TR (or point selection), 1 TL->BR, 2 BR->TL, 3 TR->BL ) (list pta pt2 MyDir) ; MyDir 0, 1-> L to R, 2, 3 -> R to L ) (defun c:NewFlatten ( / Pts) (princ "Selection: ") (setq Pts (SSMouseOrder)) ;;Mouse order returns Selection set points. Used later. (FlattenLines (car Pts) (cadr Pts) ) ;; flatten simple entities ) ; end defun and tred this code but rotated arces move y axis so drawing broken. anda also need this objtype; Quote
p7q Posted August 21, 2025 Author Posted August 21, 2025 13 hours ago, mhupp said: Change elevation only works if all points are on the same Z elevation. this might be why also flatten isn't working for you. Two things you can do to speed up. Combine all the commands into one call like you did below Command has some type of "lag" but for example lets just call it 100ms this would remove 500ms for each loop. Not to mention all the command line spam. (setvar cmdecho 0) when you sent LastEnt anything created or modified is "behind" LastEnt in the drawing and can be added to a selection set with a simple loop. rather then selecting everything in the drawing and checking against the before selection set to find the new items. (setq zList '()) ;(setq before (ssget "_X")) ;not needed anymore (command "regen" "_.copy" obj "" '(0 0 0) '(0 0 0)) (setq LastEnt (entlast)) ;set right before you create/modify objects. you want to either add to a selection (command "_.explode" newent) (while (setq LastEnt (entnext LastEnt)) ;after entities are created this will add them to a selection set. (ssadd LastEnt newents) ) (foreach e newents -edit typo in code my code was like this but sometimes lastent didnt work so ı changed. Quote
Steven P Posted August 21, 2025 Posted August 21, 2025 3 hours ago, p7q said: and tried this code but rotated arcs move y axis so drawing broken. That's strange, in my testing it works as I expected. Are you able to post a sample drawing with an arc that rotates? Going to look at the other object types sometime today for you. There is a list at the top of 'Flatten Lines' that work at the moment for info. 3 hours ago, p7q said: and I also need this obj type; 1 Quote
SLW210 Posted August 21, 2025 Posted August 21, 2025 There is a CHZ20.vlx around somewhere, I do not recall everything it does or how fast it would be. What exactly is the time on a basic drawing? As mentioned, cannot really tell any specific issues without the full LISP. I have noticed FLATTEN actually can take a long time on a drawing with lots of objects, even if it is completely z=0 already. FLATTEN and FLATSHOT are mostly useless, IMHO. I would start with just a simple z=0 LISP, then run different LISPs to specifically target other objects like Regions and Blocks. I am not sure if the arc issue have ever been solved, you may have to look around and see. Can you post a sample drawing? 1 Quote
Isaac26a Posted August 21, 2025 Posted August 21, 2025 3 hours ago, SLW210 said: There is a CHZ20.vlx around somewhere, I do not recall everything it does or how fast it would be. I found it making a google research is at: https://sites.google.com/site/cadkits/home/chz20 And I don't know if this is of some help 1 Quote
mhupp Posted August 21, 2025 Posted August 21, 2025 (edited) 8 hours ago, p7q said: my code was like this but sometimes lastent didnt work so ı changed. Then something wasn't created or modified. aka trying to exploding a invalid or corrupted region, or one that is on a locked layer. maybe run audit and purge before and then check if entity is on a locked layers. -Edit Writing lisp isn't the hard part. figuring out all the different things that could go wrong and how to handle that is the hard part. had a user that would always select things with the crossing selection option(bottom right to top left) and complain about how my lisp was picking up things "outside" what they where selecting. Edited August 21, 2025 by mhupp Quote
p7q Posted August 22, 2025 Author Posted August 22, 2025 20 hours ago, SLW210 said: There is a CHZ20.vlx around somewhere, I do not recall everything it does or how fast it would be. What exactly is the time on a basic drawing? As mentioned, cannot really tell any specific issues without the full LISP. I have noticed FLATTEN actually can take a long time on a drawing with lots of objects, even if it is completely z=0 already. FLATTEN and FLATSHOT are mostly useless, IMHO. I would start with just a simple z=0 LISP, then run different LISPs to specifically target other objects like Regions and Blocks. I am not sure if the arc issue have ever been solved, you may have to look around and see. Can you post a sample drawing? You can try this dwg. But ı wrote code for arc this code. arc.dwg ((member entType '("ARC" "CIRCLE" "ELLIPSE") ) (vla-put-Center data (vlax-3d-point (list (car (vlax-get data 'Center)) (cadr (vlax-get data 'Center)) 0.0 ) ) ) (vl-catch-all-apply (function (lambda () (vlax-put data 'Normal (list 0.0 0.0 1.0)) ) ) ) ) But this code also didnt work. Quote
