Performance helps for Large-Scale Z-Flattening (Z0) AutoLISP Routine?
22 hours ago, Steven P said:
That's strange, in my testing it works as I expected. Are you able to post a sample drawing with an arc that rotates?
Going to look at the other object types sometime today for you. There is a list at the top of 'Flatten Lines' that work at the moment for info.
Thanks for interest. you can try this dwg also. I 'm waiting yours code.
arc.dwg
17 hours ago, mhupp said:
Then something wasn't created or modified. aka trying to exploding a invalid or corrupted region, or one that is on a locked layer. maybe run audit and purge before and then check if entity is on a locked layers.
-Edit
Writing lisp isn't the hard part. figuring out all the different things that could go wrong and how to handle that is the hard part. had a user that would always select things with the crossing selection option(bottom right to top left) and complain about how my lisp was picking up things "outside" what they where selecting.
I'm sure I did because I tried exploding an object. But it didn't fill. There must be an error somewhere, but I couldn't find it, so I tried another method. Also, I'm a new programmer and I started writing lips without knowing anything about ACAD, so it was extra difficult. I'm glad this forum exists :)))
arcs in this case will need to be converted to ellipses to display properly.. something to think about
  • Confused 1
