I am searching for a lisp code to draw a section line like the test.dwg.
1) Select 2 points for the length of the section
2) Pick a point for the direction of the section
3) Draw section line with the arrows and ask for the section letter for exampl A,B
Thanks
TEST.dwg
(defun C:SECTIONLINE ( / pt1 pt2 dirpt baseAngle dirAngle angle
                        arrowLen arrowAng secLetter txtpt angleDeg
                        p1 p2 )
  (setq arrowLen 10.0)
  (setq arrowAng (/ pi 6.0))
  (setq pt1 (getpoint "\nSelect first point of section line: "))
  (if (not (and pt1 (listp pt1)))
    (progn (princ "\nCanceled or invalid first point.") (quit))
  (setq pt2 (getpoint pt1 "\nSelect second point of section line: "))
  (if (not (and pt2 (listp pt2)))
    (progn (princ "\nCanceled or invalid second point.") (quit))
  (setq dirpt (getpoint "\nPick a point to define section direction: "))
  (if (not (and dirpt (listp dirpt)))
    (progn (princ "\nCanceled or invalid direction point.") (quit))
  (setq baseAngle (angle pt1 pt2))
  (setq dirAngle (angle pt1 dirpt))
  (setq angle (if (< (abs (- baseAngle dirAngle)) (/ pi 2.0))
                baseAngle
                (+ baseAngle pi)))
  (command "._LINE" "_non" pt1 "_non" pt2 "")
  (setq p1 (polar pt1 (+ angle arrowAng) arrowLen))
  (setq p2 (polar pt1 (- angle arrowAng) arrowLen))
  (command "._LINE" "_non" pt1 "_non" p1 "")
  (command "._LINE" "_non" pt1 "_non" p2 "")
  (setq p1 (polar pt2 (+ angle arrowAng) arrowLen))
  (setq p2 (polar pt2 (- angle arrowAng) arrowLen))
  (command "._LINE" "_non" pt2 "_non" p1 "")
  (command "._LINE" "_non" pt2 "_non" p2 "")
  (setq secLetter (getstring T "\nEnter section letter (e.g., A, B): "))
  (if (= secLetter "") (setq secLetter "A"))
  (if (and (listp pt1) (listp pt2))
      (setq txtpt (mapcar '(lambda (a b) (/ (+ a b) 2.0)) pt1 pt2))
      (setq angleDeg (* 180.0 (/ angle pi)))
      (command "._TEXT" "_non" txtpt 2.5 angleDeg (strcat secLetter "-" secLetter))
    (princ "\nText not placed due to invalid points.")
  (princ "\nSection line created successfully.")
I have this error (I use ZWCAD)
Command: SECTIONLINE
Error: undefined function - nil
Thanks
You haven't defined "arrowAng" variable and you are using it in (polar) function...
Sorry, my mistake - you defined it firstly...
Edited by marko_ribar
