mhy3sx Posted 5 hours ago Posted 5 hours ago I am searching for a lisp code to draw a section line like the test.dwg. 1) Select 2 points for the length of the section 2) Pick a point for the direction of the section 3) Draw section line with the arrows and ask for the section letter for exampl A,B Thanks TEST.dwg Quote
mhy3sx Posted 2 hours ago Author Posted 2 hours ago (defun C:SECTIONLINE ( / pt1 pt2 dirpt baseAngle dirAngle angle arrowLen arrowAng secLetter txtpt angleDeg p1 p2 ) (setq arrowLen 10.0) (setq arrowAng (/ pi 6.0)) (setq pt1 (getpoint "\nSelect first point of section line: ")) (if (not (and pt1 (listp pt1))) (progn (princ "\nCanceled or invalid first point.") (quit)) ) (setq pt2 (getpoint pt1 "\nSelect second point of section line: ")) (if (not (and pt2 (listp pt2))) (progn (princ "\nCanceled or invalid second point.") (quit)) ) (setq dirpt (getpoint "\nPick a point to define section direction: ")) (if (not (and dirpt (listp dirpt))) (progn (princ "\nCanceled or invalid direction point.") (quit)) ) (setq baseAngle (angle pt1 pt2)) (setq dirAngle (angle pt1 dirpt)) (setq angle (if (< (abs (- baseAngle dirAngle)) (/ pi 2.0)) baseAngle (+ baseAngle pi))) (command "._LINE" "_non" pt1 "_non" pt2 "") (setq p1 (polar pt1 (+ angle arrowAng) arrowLen)) (setq p2 (polar pt1 (- angle arrowAng) arrowLen)) (command "._LINE" "_non" pt1 "_non" p1 "") (command "._LINE" "_non" pt1 "_non" p2 "") (setq p1 (polar pt2 (+ angle arrowAng) arrowLen)) (setq p2 (polar pt2 (- angle arrowAng) arrowLen)) (command "._LINE" "_non" pt2 "_non" p1 "") (command "._LINE" "_non" pt2 "_non" p2 "") (setq secLetter (getstring T "\nEnter section letter (e.g., A, B): ")) (if (= secLetter "") (setq secLetter "A")) (if (and (listp pt1) (listp pt2)) (progn (setq txtpt (mapcar '(lambda (a b) (/ (+ a b) 2.0)) pt1 pt2)) (setq angleDeg (* 180.0 (/ angle pi))) (command "._TEXT" "_non" txtpt 2.5 angleDeg (strcat secLetter "-" secLetter)) ) (princ "\nText not placed due to invalid points.") ) (princ "\nSection line created successfully.") (princ) ) I have this error (I use ZWCAD) Command: SECTIONLINE Select first point of section line: Select second point of section line: Pick a point to define section direction: Error: undefined function - nil Thanks Quote
marko_ribar Posted 1 hour ago Posted 1 hour ago (edited) You haven't defined "arrowAng" variable and you are using it in (polar) function... Sorry, my mistake - you defined it firstly... Edited 1 hour ago by marko_ribar Quote
