(defun c:ctf (/ bm num i obj db p1 p2 midpt point_list table pt)
  (setvar "osmode" 0)
  ; Select all lines
  (setq bm (ssget '((0 . "LINE"))))
  (if bm
      ; Get number of lines
      (setq num (sslength bm))
      (setq i 0)
      (setq point_list '()) ; Initialize list to store points
      ; Loop through each line
      (repeat num
        (setq obj (ssname bm i)) ; Get entity name
        (setq db (entget obj))   ; Get entity data
        (setq p1 (cdr (assoc 10 db))) ; Start point
        (setq p2 (cdr (assoc 11 db))) ; End point
        ; Calculate midpoint
        (setq midpt (mapcar '/ (mapcar '+ p1 p2) '(2 2 2)))
        ; Store points in list
        (setq point_list (cons (list p1 p2 midpt) point_list))
        (setq i (1+ i))
      (setq pt (getpoint "\nSpecify table insertion point: "))
      (if pt
          ; Create table
          (command "._TABLE" 4 3 pt)
          ; Set header
	  (command "._TABLEdit" "A1" "TEXT" "sr.no")
          (command "._TABLEdit" "B1" "TEXT" "Start Point")
          (command "._TABLEdit" "c1" "TEXT" "endPoint")
          (command "._TABLEdit" "D1" "TEXT" "mid Point")
  ; extract data of the lines and filling in cells of table
; point_list data stored
	  ;autocad ver 2025
        (princ "\nNo insertion point specified.")
    (princ "\nNo lines selected.")
  (setvar "osmode" 511)
I need to help data automatically fill in the cells of the table
table.dwg
Perhaps this ?
(vl-load-com)
(defun c:lines2cell ( / js AcDoc Space nw_style oldim oldlay ins_pt_cell h_t w_c lst_id-seg lst_pt n
                        obj dxf_10 dxf_11 mid_pt nb nw_obj ename_cell n_row n_column)
  (princ "\nSelect points.")
  (while (null (setq js (ssget '((0 . "LINE")))))
    (princ "\nSelection empty, or is not a lines!")
  (setq
    AcDoc (vla-get-ActiveDocument (vlax-get-acad-object))
    Space
    (if (= 1 (getvar "CVPORT"))
      (vla-get-PaperSpace AcDoc)
      (vla-get-ModelSpace AcDoc)
  (cond
    ((null (tblsearch "LAYER" "Table-Lines"))
      (vla-add (vla-get-layers AcDoc) "Table-Lines")
  (cond
    ((null (tblsearch "STYLE" "Text-Cell"))
      (setq nw_style (vla-add (vla-get-textstyles AcDoc) "Text-Cell"))
      (mapcar
        '(lambda (pr val)
          (vlax-put nw_style pr val)
        (list 'FontFile 'Height 'ObliqueAngle 'Width 'TextGenerationFlag)
        (list (strcat (getenv "windir") "\\fonts\\arial.ttf") 0.0 (/ (* 15.0 pi) 180) 1.0 0.0)
      (command "_.ddunits"
        (while (not (zerop (getvar "cmdactive")))
          (command pause)
  (setq
    oldim (getvar "dimzin")
    oldlay (getvar "clayer")
  (setvar "dimzin" 0) (setvar "clayer" "Table-Lines")
  (initget 9)
  (setq ins_pt_cell (getpoint "\nLeft-Up insert point of table: "))
  (initget 6)
  (setq h_t (getdist ins_pt_cell (strcat "\nHigth text <" (rtos (getvar "textsize")) ">: ")))
  (if (null h_t) (setq h_t (getvar "textsize")) (setvar "textsize" h_t))
  (initget 7)
  (setq w_c (getdist ins_pt_cell "\nWidth of cells: "))
  (setq
    lst_id-seg '()
    lst_pt '()
    nb 0
  (repeat (setq n (sslength js))
    (setq
      obj (ssname js (setq n (1- n)))
      dxf_10 (cdr (assoc 10 (entget obj)))
      dxf_11 (cdr (assoc 11 (entget obj)))
      mid_pt (mapcar '* (mapcar '+ dxf_10 dxf_11) '(0.5 0.5 0.5))
      lst_pt (cons (list dxf_10 dxf_11 mid_pt) lst_pt)
      nb (1+ nb)
      lst_id-seg (cons nb lst_id-seg)
  (mapcar
    '(lambda (p tx)
      (setq nw_obj
        (vla-addMtext Space
          (vlax-3d-point p)
          0.0
          tx
      (mapcar
        '(lambda (pr val)
          (vlax-put nw_obj pr val)
        (list 'AttachmentPoint 'Height 'DrawingDirection 'InsertionPoint 'StyleName 'Layer 'Rotation)
        (list 5 h_t 5 p "Text-Cell" "Table-Lines" 0.0)
    (mapcar 'caddr lst_pt)
    lst_id-seg
  (vla-addTable Space (vlax-3d-point ins_pt_cell) (+ 2 nb) 10 (+ h_t (* h_t 0.25)) w_c)
  (setq ename_cell (vlax-ename->vla-object (entlast)) n_row (1+ nb) n_column -1)
  (vla-SetCellValue ename_cell 0 0
    (vlax-make-variant
      (strcat "Summary of " (itoa (sslength js)) " LINES")
      8
  (vla-SetCellTextStyle ename_cell 0 0 "Text-Cell")
  (vla-SetCellTextHeight ename_cell 0 0 (vlax-make-variant h_t 5))
  (vla-SetCellAlignment ename_cell 0 0 5)
  (foreach n
    (mapcar'list
      (append lst_id-seg '("N°"))
      (append (mapcar 'rtos (mapcar 'caar lst_pt)) '("Start X"))
      (append (mapcar 'rtos (mapcar 'cadar lst_pt)) '("Start Y"))
      (append (mapcar 'rtos (mapcar 'caddar lst_pt)) '("Start Z"))
      (append (mapcar 'rtos (mapcar 'caadr lst_pt)) '("End X"))
      (append (mapcar 'rtos (mapcar 'cadadr lst_pt)) '("End Y"))
      (append (mapcar 'rtos (mapcar 'caddar (mapcar 'cdr lst_pt))) '("End Z"))
      (append (mapcar 'rtos (mapcar 'caaddr lst_pt)) '("Middle X"))
      (append (mapcar 'rtos (mapcar 'cadadr (mapcar 'cdr lst_pt))) '("Middle Y"))
      (append (mapcar 'rtos (mapcar 'caddar (mapcar 'cddr lst_pt))) '("Middle Z"))
    (mapcar
      '(lambda (el)
        (vla-SetCellValue ename_cell n_row (setq n_column (1+ n_column)) (vlax-make-variant el 8))
        (vla-SetCellTextStyle ename_cell n_row n_column "Text-Cell")
        (vla-SetCellTextHeight ename_cell n_row n_column (vlax-make-variant h_t 5))
        (if (eq n_row 1)
          (vla-SetCellAlignment ename_cell n_row n_column 5)
          (vla-SetCellAlignment ename_cell n_row n_column 6)
      n
    (setq n_row (1- n_row) n_column -1)
  (setvar "dimzin" oldim) (setvar "clayer" oldlay)
  (prin1)
  • Thanks 1
