Hello,
With the help of AI I am trying to make a .lsp script that insert specific block on every vertex of a polyline and orient two "arrows" to the previous and next vertex.
I try with different AI models and always I end up with error in Autocad (I use Autocad 2022) Error: "ActiveX Server returned the error: unknown name: "DYNAMICBLOCKPROPERTIES".
AI say that the block is not really a dynamic block, which I dont get, how block can be not really dynamic.
I am attaching both block and .lsp script. I hope someone will give me some advice what is wrong with the block or with .lsp script.
BlockInsert.lsp block.dwg
Maybe it's just that property doesn't exist on the specified object.
For a client did draw arrows I used a entmake pline so have control over the arrow sizes length and width. Its a case of setting the start as 0.0 and a length and an end arrow width. Yes matching angle of a pline and same layer.
Can you provide more information about how the arrows are to be shown at each vertice, length and width plus direction.
Edited by BIGAL
Hello thank you for your reply.
May be I did not explain properly what I want to do. I will post some pictures may be they will help.
On the Block_1.jpg is how the drawing has to look like.
On the Block_2.jpg is the block it self when is edited.
So the script has to change "Angle" and "Angle1" so the so called arrows point to the previous and next block - Block_3.jpg
Ok thats is very similar to what I was talking about, its easy to draw an arrow at a point along a pline, you can do this in a number of ways one of the easiest is to just use "V" rotated + - to to the angle between the points.
Which of these is correct ? You should post a dwg not an image, can then see sizes and offsets from vertices.
