hello all:
I recently changed windows on my computer
and some of my routines don't work
I have reviewed the notepads
and I realize that my routines that had the letter "ñ" have disappeared that symbol
and some give me a syntax error.
Also in some routines the answer was square meters and the number 2 indicated as a subindex and it also disappeared.
I don't know if when I save my routines they are saved in some other format and I know the reason.
can someone help me?
Not an AutoCAD issue.
What encoding are the files saved with?
Font?
You are not providing very much to go on.
The squared symbol issue would lead me to believe a font issue.
Font?
My old routines are in ANSI configuration, the problem is that they updated me to Windows 11, if I open and close an lsp it is not modified, the problem happens when I make some modification to the routine,  Even though I save the routines as ANSI, Windows automatically saves them as UTF-8 and there are symbols that disappear, for example the letter "Ñ"
If I just open and close nothing happens
but if I modify my file and save it, even though I use save as ANSI, it still saves it to UTF-8 and deletes characters, and then the routine doesn't work.
perhaps not the fix you want, but avoid "ñ", do a find and replace, maybe to 'n' ?
I would copy the original file to a temporary or archive folder and make the change to the original - so the LISPs will still work until you can work out how to get the correct characters working.
Just checking my default text editor is UTF-8 also
What do other text editors do and what encoding do they use?
  • Thanks 1
Hi
Start by checking which ANSI setting you have on your new OS.
Control Panel → Region → Administrative tab → Change system locale button.
The system locale should appear in Spanish and the option 'Version beta: Use UTF-8...' should be unchecked.
  • Thanks 1
I don't know if it has to do with the fact that the autocad I use is the 2013 version. :(
I don't think it has anything to do with it.
And if it does, it can probably be fixed by configuring the OS.
