Get length of MLeader/QLeader spline.
Anyone have any hints on how to get Spline Leader lengths?
Ultimately, I am looking to make several already drawn spline leaders the same length.
As a spline gives two answers the points answer and another with nodes. So any way if you explode the Mleader then you can get at the spline using this. Just need to check that the spline is last entity, tested in Bricscad. A disclaimer not sure if length is correct. I think it is short by length of arrow. Will try to find arrow length. Yep found it.
(defun c:wow ( / plent pt len lenar)
  (setq plent (entsel "\nPick mleader "))
  (setq lenar (cdr (assoc 140 (entget (car plent)))))
  (command "undo" "M")
  (command "explode" (car plent))
  (setq ent (ssname (ssget "L") 0))
  (setq len (getpropertyvalue ent "length"))
  (command "undo" "B")
  (alert (strcat "Total  length is " (rtos (+ lenar len) 2 3)))
(c:wow)
I think you could do a "I want a length of 100 by drawing something close then move say arrow point till you get approx 100. Via lisp. It would be a two step process explode and move then undo and reset arrow head point.
  • Thanks 1
17 hours ago, 1958 said:
It would be nice if you could put the prompts and comments in English.
I saw the Dogleglength when I did a dump on a Mleader. I'll see what I come up with.
(c:wow)
I know how to get a Spline length, I don't want to explode the Mleaders, defeats the purpose.
The Undo un-explodes them though.  On my phone. Will have a look at the lsp tomorrow.
Edited by BIGAL
But wouldn't undo change it back to original length?
Quote
On 8/28/2025 at 12:45 PM, 1958 said:
Still looking to decipher this one, probably tomorrow when I get back to work.
