Hi everyone
I am looking for a lisp to quick select different objects according to their specific properties in the entire drawing. The objects I am going to select are:
1- Every line that has "start Z" or "End Z" "Not Equal" to zero.
2- All "Text" that have "Position Z"  "Not Equal" to zero.
3- All "Block References" that have "Position Z"  "Not Equal" to zero.
4- All "Polyline"  that have "Elevation"  "Not Equal" to zero.
Actually, I have so many files in which, Z values are not zero (Z values are about for example 0.000001). It makes the file so difficult to edit. I want to select every object and manually change the Z values to "zero".
Also, it would be great if you guys can help me by any other way, to solve my problem and change the whole drawing's Z value to "zero", if possible.
If not, it doesn't matter. Help me to write this Lisp, so that the selection of the objects get easier.
Below, I attach a simple sample of my file, in which, some block, text, or lines have Z value other than zero.
Z Value Problem.dwg
9 minutes ago, andyb57J said:
thank you.
It seems that this lisp finds the lines with Z value problem and adds a label near them. It is great that it can find the lines, but I don't want this label to be added near this lines. I only need to select them.
Can this lisp file be modified, so that it changes the Z values of the selected lines, to Zero?
I mean, it selects the lines and modifies the "Start Z" and "End Z" to 0.
Try
(defun c:todoA0 (/ cj e le n to p1 p2)
  (IF (setq cj (ssget "x" '((0 . "TEXT,MTEXT,INSERT,LINE,LWP*"))))
    (while (setq e (ssname cj (setq n (if n (1+ n) 0))))
      (setq le (entget e)
	    to (cdr (assoc 0 le))
	    p1 (assoc 10 le)
      (cond
	((= to "LINE")
	 (setq p2 (assoc 11 le))
	 (entmod (subst (cons 10 (list (cadr p1) (caddr p1) 0.0)) p1 le))
	 (entmod (subst (cons 11 (list (cadr p2) (caddr p2) 0.0)) p2 le))
	((= to "LWPOLYLINE")
	 (entmod (subst (cons 38 0.0) (assoc 38 le) le))
	((member to '("TEXT" "MTEXT" "INSERT"))
Edited by GLAVCVS
16 minutes ago, GLAVCVS said:
Try
      (setq le (entget e)
	    p1 (assoc 10 le)
      (cond
	((= to "LINE")
Wow
It worked great.
thank you very much.
just one last question: Only "End Z" of lines are being modified to Zero. how can I make this modification to "Start Z" of lines, too?
Just now, shokoufeh said:
Wow
It worked great.
Z Value Problem-modified.dwg
4 minutes ago, shokoufeh said:
Wow
It worked great.
Please check this code. I made a few modification, and I think now it works for both start and end Z values.
ZRemove.txt
Try again
      (setq le (entget e)
	    p1 (assoc 10 le)
      (cond
	((= to "LINE")
	 (entmod (subst (cons 11 (list (cadr p2) (caddr p2) 0.0)) p2 (entget e)))
9 minutes ago, GLAVCVS said:
Try again
      (setq le (entget e)
	    p1 (assoc 10 le)
      (cond
	((= to "LINE")
GREAT. It works.
Thank you very much 🙏
Sounds good
If you've tried it and it works: 👍🏼
There was a thread a few days ago about speeding up a LISP to do the same, have  look at that for ideas. I think the thread got as far as arcs are tricky to do with LISPs.
You could use the flatten command for small drawings.
This snippet will filter a selection set to lines or LWPolylines to anything not 0 Z
(setq MySS (ssget (list
    (cons 0 "*TEXT,INSERT,LINE,LWPOLYLINE")
    '(-4 . "<OR")
      '(-4 . "*,*,<>") (list 10 0.0 0.0 0.0)
      '(-4 . "*,*,<>") (list 11 0.0 0.0 0.0)
      '(-4 . "<>") (cons 38 0)
    '(-4 . "OR>")
  )) ; end list, end ssget
Can be added to the other solutions herein the case that your drawing has a lot of lines / polylines / blocks it speeds it up a bit
Link to other thread:
  • Agree 1
    '(-4 . "<OR")
    '(-4 . "OR>")
Sorry: The problem I referred to will never exist in a LWPOLYLINE: Forget what I said, if you managed to read the previous message
Edited by GLAVCVS
Error
Sorry: That problem will never exist in a LWPOLYLINE: Forget what I said, if you managed to read the previous message
I was checking my files and I found out another problem. Except elements I mentioned (lines, poly lines, texts and blocks), the problem with Z values exist in other elements, as I mention below:
Hatch: Elevation
Leader: Vertex Z
Ellipse: Start Z, Center Z, End Z
Arc: Start Z, Center Z, End Z
Circle: Center Z
Solid: Elevation
Attribute Definition: Text Alignment Z
Array (Rectangular) : Base Z
Please check this modified lisp and see if it is correct or not. This lisp doesn't work on HATCH.
ZRemove.lsp
I think hatch is the first '10' if an elevation has been set (10 0.0 0.0 'Z')
Missed your message but am intrigued now... (a guess I would say you were saying LWPolyline has X, Y, Z coords - I've done the same many times too)
so, how should I change the code?
28 minutes ago, Steven P said:
Yes
I briefly forgot that LWPOLYLINES don't have a Z coordinate and instead use group 38 to define their elevation.
Therefore @shokoufeh: the code you added to set the Z for LWPOLYLINES is unnecessary
3 minutes ago, GLAVCVS said:
Yes
Oh OK. Thanks for mentioning
Use what you have done previously but for dx code 10:
          (foreach dxf le
            (if (= (car dxf) 10)
              (setq le (subst (cons 10 (zeroz (cdr dxf))) dxf le))
