Nikon Posted Sunday at 01:55 PM Posted Sunday at 01:55 PM (edited) If all the primitives (TEXT,MTEXT,INSERT,LINE,LWP,Circle,Mleader,Dimension) are perceived as objects, then you can use this code: ;; Set coordinates of objects (TEXT,MTEXT,INSERT,LINE,LWP,Circle,Mleader,Dimension) Z in 0 (defun zeroz-in-list (lst /) (cond ;; The list of coordinates-vertex ((and (listp lst) (= (length lst) 2) (numberp (car lst)) (numberp (cadr lst))) ;; if only XY - expanding to XYZ (list (car lst) (cadr lst) 0.0) ) ((and (listp lst) (= (length lst) 3) (numberp (car lst)) (numberp (cadr lst)) (numberp (caddr lst))) ;; if already XYZ - just do Z=0.0 (list (car lst) (cadr lst) 0.0) ) ;; If it's a large list, it's probably nested ((listp lst) (mapcar 'zeroz-in-list lst) ) (t lst) ) ) (defun c:ObjZ0 (/ ss n e el newel) (prompt " Select objects (all types, including polylines, mleader, dimension): ") (if (setq ss (ssget)) (progn (setq n 0) (while (< n (sslength ss)) (setq e (ssname ss n) el (entget e) newel nil ) (foreach pair el (cond ;; height LWPOLYLINE (code 38) ((and (= (car pair) 38) (numberp (cdr pair))) (setq newel (cons (cons 38 0.0) newel)) ) ;;Point codes (for example, 10, 11, 12...), etc. ((and (numberp (car pair)) (not (= (car pair) 210))) ; Don't touch the normal (if (listp (cdr pair)) (setq newel (cons (cons (car pair) (zeroz-in-list (cdr pair))) newel)) (setq newel (cons pair newel)) ) ) ;; The rest (t (setq newel (cons pair newel))) ) ) ;; Restoring order and modifying the object (entmod (reverse newel)) (setq n (1+ n)) ) ) ) (princ) ) If the Z coordinate is not displayed in the properties (example, for dimensions, for Mleader), then you need to use the _LIST command. Don't think of me as a programmer... The code is written using AI. Edited Sunday at 01:58 PM by Nikon 1 Quote
shokoufeh Posted 5 hours ago Author Posted 5 hours ago On 8/31/2025 at 5:03 PM, Steven P said: Use what you have done previously but for dx code 10: (foreach dxf le (if (= (car dxf) 10) (setq le (subst (cons 10 (zeroz (cdr dxf))) dxf le)) ) ) I applied this and the problem is solved for Hatches, too. Thank you 1 Quote
shokoufeh Posted 5 hours ago Author Posted 5 hours ago On 8/31/2025 at 5:25 PM, Nikon said: If all the primitives (TEXT,MTEXT,INSERT,LINE,LWP,Circle,Mleader,Dimension) are perceived as objects, then you can use this code: ;; Set coordinates of objects (TEXT,MTEXT,INSERT,LINE,LWP,Circle,Mleader,Dimension) Z in 0 (defun zeroz-in-list (lst /) (cond ;; The list of coordinates-vertex ((and (listp lst) (= (length lst) 2) (numberp (car lst)) (numberp (cadr lst))) ;; if only XY - expanding to XYZ (list (car lst) (cadr lst) 0.0) ) ((and (listp lst) (= (length lst) 3) (numberp (car lst)) (numberp (cadr lst)) (numberp (caddr lst))) ;; if already XYZ - just do Z=0.0 (list (car lst) (cadr lst) 0.0) ) ;; If it's a large list, it's probably nested ((listp lst) (mapcar 'zeroz-in-list lst) ) (t lst) ) ) (defun c:ObjZ0 (/ ss n e el newel) (prompt " Select objects (all types, including polylines, mleader, dimension): ") (if (setq ss (ssget)) (progn (setq n 0) (while (< n (sslength ss)) (setq e (ssname ss n) el (entget e) newel nil ) (foreach pair el (cond ;; height LWPOLYLINE (code 38) ((and (= (car pair) 38) (numberp (cdr pair))) (setq newel (cons (cons 38 0.0) newel)) ) ;;Point codes (for example, 10, 11, 12...), etc. ((and (numberp (car pair)) (not (= (car pair) 210))) ; Don't touch the normal (if (listp (cdr pair)) (setq newel (cons (cons (car pair) (zeroz-in-list (cdr pair))) newel)) (setq newel (cons pair newel)) ) ) ;; The rest (t (setq newel (cons pair newel))) ) ) ;; Restoring order and modifying the object (entmod (reverse newel)) (setq n (1+ n)) ) ) ) (princ) ) If the Z coordinate is not displayed in the properties (example, for dimensions, for Mleader), then you need to use the _LIST command. Don't think of me as a programmer... The code is written using AI. WOW. Great. It works Thank you Quote
