Here is what I am trying to do.
Draw a TRIM - FENCE from these two points to cut the vertical lines
Here is my code
(setq pt1 "0.5,1.0,0.0")
(setq pt2 "3.0,1.0,0.0")
(command "trim" "fence"  pt1 pt2)
If I execute this code,  I get this
(the lines are not trimmed)
If I manually type TRIM - FENCE - !PT1 - !PT2
I get this
(it works, I have to press enter to finish)
What am I missing in getting this code/command to work the way I want?
Edited by ILoveMadoka
(defun c:FOO (/ pt1 pt2)
  (if
    (and
      (setq pt1 (getpoint "\nSpecify first point: "))
      (setq pt2 (getpoint pt1 "\nSpecify second point: "))
     (command-s "._trim" "_o" "_s" "" "_f" pt1 pt2 "" "")
Edited by BlackBox
  • Agree 1
I know that's how command line works (typing in points), but you have to pass it a list. so either use getpoint or use the following to hard code x y z.
(setq pt2 '(0.5 1.0 0.0))
or
(setq pt2 (list 0.5 1.0 0.0))
Asks user to set points with getpoint. used the first point so you can see the fence. defaults do your point if nothing is picked.
(setq pt1 (getpoint "\nPick Point<0.5, 1.0, 0.0>: "))
(if (= pt1 "")(setq pt1 '(0.5 1.0 0.0)))
(setq pt2 (getpoint pt1 "\nPick Point<0.5, 1.0, 0.0>: "))
(if (= pt2 "")(setq pt2 '(3.0 1.0 0.0)))  ; '(makes it a list
-edit
using @BlackBox Command-s means it wont run the command unless both points are defined. good for error handling
Edited by mhupp
BLACKBOX for the WIN!!
Thank you so very much..
Works perfectly now.
Thank you both for the input.
