AutoLISP: Change Block Spacing in X-Direction (Row-Wise, No Y-Shift)
I need help with adjusting the X-direction spacing of multiple blocks (row-wise) in AutoCAD. The Y-position should remain unchanged. For example, the current spacing between blocks is 27 ft, but once I select all the blocks and input a new value like 23 or 24, the blocks should automatically update to the new spacing as per my requirement.
BLK Sample.dwg
Hi @Tamim,
Try with this:
(prompt "\nTo run a LISP type: reara")
(defun c:reara ( / old_osmode base_blk spacing ss base_blk_pt dist_blk_lst len i ins_pt dist n dist_n x_cord y_cord new_pt)
  (setq old_osmode (getvar 'osmode))
  (setvar 'osmode 0)
  (setq base_blk (car (entsel "\nPick the base block:\n"))
	spacing (getreal "\nEnter the spacing:\n")
  (prompt "\nSelect BLOCK's:")
  (setq ss (ssget (list (cons 0 "INSERT")))
	base_blk_pt (cdr (assoc 10 (entget base_blk)))
	dist_blk_lst (list)
  (if (ssmemb base_blk ss)
    (ssdel base_blk ss)
  (setq len (sslength ss)
	i 0
  (while (< i len)
    (setq ins_pt (cdr (assoc 10 (entget (ssname ss i))))
	  dist (distance base_blk_pt ins_pt)
	  dist_blk_lst (cons (list dist (ssname ss i)) dist_blk_lst)
	  i (1+ i)
  (setq dist_blk_lst (vl-sort dist_blk_lst (function (lambda (x1 x2) (< (car x1) (car x2)))))
	n 0
  (repeat (length dist_blk_lst)
    (setq dist_n (- (car (nth n dist_blk_lst)) spacing (* spacing n))
	  x_cord (- (cadr (assoc 10 (entget (cadr (nth n dist_blk_lst))))) dist_n)
	  y_cord (caddr (assoc 10 (entget (cadr (nth n dist_blk_lst)))))
	  new_pt (list x_cord y_cord)
    (command-s "_move" (cadr (nth n dist_blk_lst)) "" (cdr (assoc 10 (entget (cadr (nth n dist_blk_lst))))) new_pt)
    (setq n (1+ n))
  (setvar 'osmode old_osmode)
  (prompt (strcat "\nThe " (itoa (length dist_blk_lst)) " are rearanged!"))
See the following video how it works.
Best regards.
6 minutes ago, Saxlle said:
Hi @Tamim,
Try with this:
  (setvar 'osmode 0)
	dist_blk_lst (list)
    (ssdel base_blk ss)
	i 0
  (while (< i len)
	  i (1+ i)
	n 0
    (setq n (1+ n))
Best regards.
Thanks for the prog. However, this only works for a single X row. I need to select both top and bottom rows (like Y1 and Y2), and show the result below the image.
