Good afternoon, everyone.
I am trying to select a arrayrect and insert a TEXT with the number of array elements into the drawing.
But the array is not selected.
How do I set the array selection correctly?
(defun c:CountElemArrayrect (/ ss n pt)
  (princ "Select a arrayrect: ")
  (setq ss (ssget '((0 . "ARRAY")))
        n 0)
  (if ss
      (setq n (vla-get-Count
                (vlax-ename->vla-object (ssname ss 0))))
      (princ (strcat "The number of elements in the array: " (itoa n)))
      (princ "Specify the insertion point of the text: ")
      (setq pt (getpoint))
      (if pt
        (entmakex
          (list
            (cons 0 "TEXT")
            (cons 10 pt)
            (cons 1 (itoa n))
            (cons 40 25) ; text height
            (cons 7 (getvar "TEXTSTYLE"))
Edited by Nikon
If you inspect the DXF data for a rectangular array (e.g. using my Entity List program, for example), you will see that it is in fact a block reference (INSERT).
  • Thanks 1
Consider the following function to obtain the data from the array:
(defun LM:arraydata ( ent / enx lst rtn )
    (if
        (and
            (setq enx (entget ent))
            (= "INSERT" (cdr (assoc 0 enx)))
            (setq lst
                (vl-some
                    (function
                        (lambda ( x )
                            (if (and (= 330 (car x)) (= "ACDBASSOCDEPENDENCY" (cdr (assoc 0 (entget (cdr x))))))
                                (cdr (assoc 330 (entget (cdr x))))
                    (member '(102 . "{ACAD_REACTORS") enx)
            (setq lst (entget lst))
            (setq lst (cons nil (member (assoc 1 lst) lst)))
        (while lst
            (setq rtn (cons (cons (cdadr lst) (cdar (cddddr lst))) rtn)
                  lst (cdddr (cddddr lst))
    (reverse rtn)
Call with the array block reference entity, e.g.:
(LM:arraydata (car (entsel)))
  • Thanks 1
The code writes the same amount for arrays with different numbers of elements...
(defun c:ArrCountTxt ( / ent arrData count insPt txtHeight)
  (prompt "Select a arrayrect: ")
  (setq ent (car (entsel)))
  (if (and ent (= "INSERT" (cdr (assoc 0 (entget ent)))))
            (setq arrData (LM:arraydata ent))
      ;; count the number of elements
      (setq count (length arrData))
      (princ (strcat "Number of array elements: " (itoa count)))
      (prompt "Specify the insertion point of the text: ")
      (setq insPt (getpoint))
      (setq txtHeight 20)
      (entmake
        (list
          (cons 0 "TEXT")
          (cons 8 (cdr (assoc 8 (entget ent)))) ;
          (cons 10 insPt)
          (cons 40 txtHeight)
          (cons 1 (strcat "Quantity: " (itoa count)))
          (cons 7 "Standard")
          (cons 50 0.0)
  (if
    (and
      (setq lst
        (vl-some
          (function
            (lambda ( x )
    (while lst
  (reverse rtn)
Edited by Nikon
Did you even look at the data that my function returns?
DXF data
    (-1 . <Object name: 233aa8f9cf0>)
    (0 . "INSERT")
    (5 . "17957")
    (330 . <Object name: 233aa8f9d80>)
    (102 . "}")
    (330 . <Object name: 23bc15009f0>)
    (100 . "AcDbEntity")
    (67 . 0)
    (410 . "Model")
    (8 . "Hatching")
    (100 . "AcDbBlockReference")
    (2 . "*U268")
    (10 77260.1 54657.3 0.0)
    (41 . 1.0)
    (42 . 1.0)
    (43 . 1.0)
    (50 . 0.0)
    (70 . 0)
    (71 . 0)
    (44 . 0.0)
    (45 . 0.0)
    (210 0.0 0.0 1.0)
I've looked at the data, but I need professional help...
How can I count elements in an array in lisp?
Edited by Nikon
If you post an example drawing, maybe someone else will be encouraged to join the conversation.
(defun c:CountElemArrayrect (/ ss n pt ent le dameFFCC)
  (defun dameFFCC (ent / items rows cont cols filas)
    (foreach l (entget (cdr (assoc 330 (entget (cdr (assoc 330 (entget ent)))))))
      (cond
        (items (if (= (setq cont (+ (if cont cont 0) (if (= (car l) 90) 1 0))) 3) (setq cols (cdr l) items nil cont nil)))
        (rows (if (= (setq cont (+ (if cont cont 0) (if (= (car l) 90) 1 0))) 3) (setq filas (cdr l) rows nil cont nil)))
        ((= (car l) 1)
          (if (= (cdr l) "Items") (setq items T)
            (if (= (cdr l) "Rows") (setq rows T))
    (if (and filas cols) (* filas cols))
;;;  (setq ss (ssget '((0 . "ARRAY")))
;;;        n 0)
  (if (and (setq ent (car (entsel))) (= (cdr (assoc 0 (setq le (entget ent)))) "INSERT") (= "ACDBASSOCDEPENDENCY" (cdr (assoc 0 (entget (cdr (assoc 330 le)))))))
      (setq n (dameFFCC ent))
;;;	     (vla-get-Count
;;;                (vlax-ename->vla-object (ssname ss 0))))
      (if pt
        (entmakex
          (list
            (cons 0 "TEXT")
            (cons 10 pt)
            (cons 1 (itoa n))
This is the first time I’ve ever done an “autopsy” on an object like this.
I’ve carefully extracted what seemed to me to be the information I was looking for.
So I must say:
DRIVE CAREFULLY AND RESPECT ALL STOP SIGNS. 🚦
  • Funny 1
  • Thanks 1
P.S.:
This is just my two cents — though to be honest, it’s probably counterfeit 😅
  • Funny 2
No, I mean the data returned by my (LM:arraydata) function - you just assumed you should use the length of the list, without actually checking what the list contains.
Edited by Lee Mac
  • Agree 1
8 hours ago, GLAVCVS said:
P.S.:
This fake is worth more than two cents.  💯
The code works the way I wanted it to. Thanks!  👍
But I don't understand why I should drive carefully. ⁉️ 🤣
Edited by Nikon
