Nikon Posted 4 hours ago Posted 4 hours ago (edited) Good afternoon, everyone. I am trying to select a arrayrect and insert a TEXT with the number of array elements into the drawing. But the array is not selected. How do I set the array selection correctly? (defun c:CountElemArrayrect (/ ss n pt) (princ "Select a arrayrect: ") (setq ss (ssget '((0 . "ARRAY"))) n 0) (if ss (progn (setq n (vla-get-Count (vlax-ename->vla-object (ssname ss 0)))) (princ (strcat "The number of elements in the array: " (itoa n))) (princ "Specify the insertion point of the text: ") (setq pt (getpoint)) (if pt (entmakex (list (cons 0 "TEXT") (cons 10 pt) (cons 1 (itoa n)) (cons 40 25) ; text height (cons 7 (getvar "TEXTSTYLE")) ) ) ) ) ) (princ) ) Edited 4 hours ago by Nikon Quote
Lee Mac Posted 2 hours ago Posted 2 hours ago If you inspect the DXF data for a rectangular array (e.g. using my Entity List program, for example), you will see that it is in fact a block reference (INSERT). 1 Quote
Lee Mac Posted 2 hours ago Posted 2 hours ago Consider the following function to obtain the data from the array: (defun LM:arraydata ( ent / enx lst rtn ) (if (and (setq enx (entget ent)) (= "INSERT" (cdr (assoc 0 enx))) (setq lst (vl-some (function (lambda ( x ) (if (and (= 330 (car x)) (= "ACDBASSOCDEPENDENCY" (cdr (assoc 0 (entget (cdr x)))))) (cdr (assoc 330 (entget (cdr x)))) ) ) ) (member '(102 . "{ACAD_REACTORS") enx) ) ) (setq lst (entget lst)) (setq lst (cons nil (member (assoc 1 lst) lst))) ) (while lst (setq rtn (cons (cons (cdadr lst) (cdar (cddddr lst))) rtn) lst (cdddr (cddddr lst)) ) ) ) (reverse rtn) ) Call with the array block reference entity, e.g.: (LM:arraydata (car (entsel))) 1 Quote
Nikon Posted 48 minutes ago Author Posted 48 minutes ago (edited) The code writes the same amount for arrays with different numbers of elements... (defun c:ArrCountTxt ( / ent arrData count insPt txtHeight) (prompt "Select a arrayrect: ") (setq ent (car (entsel))) (if (and ent (= "INSERT" (cdr (assoc 0 (entget ent))))) (progn (setq arrData (LM:arraydata ent)) ;; count the number of elements (setq count (length arrData)) (princ (strcat "Number of array elements: " (itoa count))) (prompt "Specify the insertion point of the text: ") (setq insPt (getpoint)) (setq txtHeight 20) (entmake (list (cons 0 "TEXT") (cons 8 (cdr (assoc 8 (entget ent)))) ; (cons 10 insPt) (cons 40 txtHeight) (cons 1 (strcat "Quantity: " (itoa count))) (cons 7 "Standard") (cons 50 0.0) ) ) ) ) (princ) ) (defun LM:arraydata ( ent / enx lst rtn ) (if (and (setq enx (entget ent)) (= "INSERT" (cdr (assoc 0 enx))) (setq lst (vl-some (function (lambda ( x ) (if (and (= 330 (car x)) (= "ACDBASSOCDEPENDENCY" (cdr (assoc 0 (entget (cdr x)))))) (cdr (assoc 330 (entget (cdr x)))) ) ) ) (member '(102 . "{ACAD_REACTORS") enx) ) ) (setq lst (entget lst)) (setq lst (cons nil (member (assoc 1 lst) lst))) ) (while lst (setq rtn (cons (cons (cdadr lst) (cdar (cddddr lst))) rtn) lst (cdddr (cddddr lst)) ) ) ) (reverse rtn) ) Edited 46 minutes ago by Nikon Quote
