Someone_Pro Posted September 22, 2025 Posted September 22, 2025 (edited) Hello, Can anyone help me with my dilemma. I'm doing AutoCAD automation and I want a schedule to not shows at time but show at other times. The schedule is shown through a viewport. I have tried making a costume viewport layer for it and freezing it. But freezing the layer of the vp does not seem to stop what inside the vp from printing. So is there an option to link the viewport to what it shows so if I freeze the vp layer it won't print what it shows. Edited September 22, 2025 by Someone_Pro Quote
SLW210 Posted September 22, 2025 Posted September 22, 2025 You can turn the viewport off and everything in it will not plot. Frozen layers will still plot, you need to turn them off. 1 Quote
Someone_Pro Posted September 22, 2025 Author Posted September 22, 2025 3 hours ago, SLW210 said: You can turn the viewport off and everything in it will not plot. Frozen layers will still plot, you need to turn them off. Thank you for your reply! I was not the one who developed the code so I can only modify the sittings as they are. And it'll only let me freeze or thaw layers. I was hoping I can just freeze the VP layer to stop what's inside from printing when lunching the code. But it seems that won't be possible. Quote
SLW210 Posted September 22, 2025 Posted September 22, 2025 You didn't post this in one of the code forums. I have no idea what settings you can modify, maybe you should actually post something. What type of code are you using? Quote
