dimjogline plus in dimension ... help
hello all:
There are dimensions I need to do this to.
I have a routine to do this
It would be possible to do everything in a single selection
I mean select the dimension and place the break and the line over the text
I await comments and here I put the code, thank you
; Original by RonJonP, edited by P. Kenewell
(defun c:ltx (/ o s)
  (setvar "cmdecho" 0)
  (command "._undo" "_be")
  (if (setq s (ssget ":L" '((0 . "*TEXT,DIMENSION"))))
    (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
      (setq o (vlax-ename->vla-object e))
      (cond
         ((= "TEXT" (cdr (assoc 0 (entget e))))
            (vla-put-textstring o
               (strcat "%%O"
                  (vl-string-subst "" ""
                     (vl-string-subst "" "%%O" (vla-get-textstring o))
         ((= "MTEXT" (cdr (assoc 0 (entget e))))
               (strcat "\\O"
                     (vl-string-subst "" "\\O" (vla-get-textstring o))
         ((= "DIMENSION" (cdr (assoc 0 (entget e))))
            (if (= (vla-get-textoverride o) "")
               (vla-put-textoverride o "\\O<>")
                  (strcat "\\O"
                        (vl-string-subst "" "\\O" (vla-get-textoverride o))
  (command "._undo" "_end")
  (setvar "cmdecho" 1)
Also you can return the vla-object list with foreach by wrapping it in mapcar.  eliminating having to use (setq o (vlax-ename->vla-object e)).  Pulling the vla-object name before the cond means your checking the variable rather then check the entity up to 3 times.
; Original by RonJonP, edited by P. Kenewell, updated by Mhupp
(defun c:ltx (/ D O S)
  (vl-load-com)
  (setq D (vla-get-activedocument (vlax-get-acad-object)))
  (vla-startundomark D)
    (foreach o (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))))
      (setq typ (vla-get-ObjectName o))
      (cond
        ((= typ "AcDbText")
          (vla-put-textstring o (strcat "%%O" (vl-string-subst "" "" (vl-string-subst "" "%%O" (vla-get-textstring o)))))
        ((= typ "AcDbMText")
        ((= typ "AcDbDimension")
  (vla-endundomark D)
-edit
also useing the (vla-startundomark allows you to have things selected before you run the command.
Edited by mhupp
  • Thanks 1
On 9/22/2025 at 10:32 PM, leonucadomi said:
hello all:
      (cond
               (strcat "%%O"
               (strcat "\\O"
                  (strcat "\\O"
Hi
Do you want to place the 'jog', indicating its location in each case, or in a predetermined location?
To indicate the 'jog' position 1 to 1, insert this code after the clause ((= "DIMENSION"... (entget e) ))))
      (if (not (tblsearch "APPID" "ACAD_DSTYLE_DIMJAG_POSITION"))
	    (regapp "ACAD_DSTYLE_DIMJAG_POSITION")
	  (if (setq pt (getpoint "\nJOG: Pick a point on the DIMENSION line"))
	    (entmod (append (entget e) (list (list -3 (list "ACAD_DSTYLE_DIMJAG_POSITION" '(1070 . 387) '(1070 . 3) '(1070 . 389) (cons 1010 pt))))))
  • Thanks 1
I think I forgot something important: when there are multiple selections, it's necessary to show the user which object will be modified in each case.
Below, I've included the complete code with a zoom utility to show the user the next object to modify.
; Original by RonJonP, edited by P. Kenewell and GLAVCVS
(defun c:ltx (/ o s pt i p1 p2 le)
      (cond
               (strcat "%%O"
               (strcat "\\O"
	  (command "_zoom" "_w" (setq i (cdr (assoc 10 (setq le (entget e))))) (polar i (angle (setq p2 (cdr (assoc 14 le))) (setq p1 (cdr (assoc 13 le)))) (distance p1 p2)))
	  (if (setq pt (getpoint "\rJOG: Pick a point on the DIMENSION line"))
	      (strcat "\\O"
  • Like 2
  • Thanks 1
Is it possible not to specify breakpoints, but just make a break to the right of the text? 😉
Edited by Nikon
  • Thanks 1
  (vl-load-com)
      (cond
        ((= typ "AcDbText")
  (vla-endundomark D)
-edit
image.png.a784687f92c1e96ca39d46156be96d79.png something is wrong
4 hours ago, GLAVCVS said:
Hi
a default location near any arrow
      (cond
               (strcat "%%O"
               (strcat "\\O"
	      (strcat "\\O"
This is what I need, I just would like it to be for selecting a single selection (entsel)  and not zoom,
Just select a dimension and a point for the jogline and repeat the routine.
Its incomplete code and only uses vla-object names showing best practice for using cond. Use the original code setting e type outside the cond to check instead of using enget for each cond check. with dimensions you use entget three times, mtext two times. its probably only saving ms of  time.
(defun c:ltx (/ o s pt i p1 p2 le typ)
      (setq typ (cdr (assoc 0 (entget e))))
      (cond
         ((= "TEXT" typ)
Every time you are using enget its returning something like this.
  (0 . "MTEXT")                         ; saving this bit
  (5 . "1F2")
  (330 . <owner>)
  (100 . "AcDbEntity")
  (67 . 0)
  (8 . "TextLayer")
  (100 . "AcDbMText")
  (10 100.0 200.0 0.0)
  (40 . 2.5)
  (41 . 50.0)
  (71 . 1)
  (72 . 5)
  (1 . "This is a multiline text")
  (7 . "Standard")
  (210 0.0 0.0 1.0)
  (11 100.0 200.0 0.0)
  (42 . 1.0)
  (43 . 1.0)
  (50 . 0.0)
  (73 . 1)
  (44 . 0.0)
  (45 . 0.0)
  (90 . 0)
  (91 . 1)
  (92 . 0)
  (93 . 0)
  (94 . 0)
  (95 . 0)
Edited by mhupp
  • Agree 1
  • Thanks 1
I have already managed to change the selection to individual and cancel the zoom but
to repeat the routine I use repeat 100 (....) I don't know any other way  :(
Change if to while.
(if (setq s (ssget ""_+.:E:S" '((0 . "*TEXT,DIMENSION"))))
  .. runs once
(while (setq s (ssget "_+.:E:S" '((0 . "*TEXT,DIMENSION"))))
  ... repeats while you have an entity selected. have to right click or enter to exit loop
Edited by mhupp
This will do what you want by selecting multiple objects in the selection set.
(defun c:ltx (/ o s le to p1 p2 pIns)
      (cond
         ((= "TEXT" (setq to (cdr (assoc 0 (setq le (entget e))))))
               (strcat "%%O"
         ((= "MTEXT" to)
               (strcat "\\O"
         ((= "DIMENSION" to)
		pIns (polar (cdr (assoc 10 le)) (angle p2 p1) (* (distance p1 p2) 0.8))
		x (entmod (append (entget e) (list (list -3 (list "ACAD_DSTYLE_DIMJAG_POSITION" '(1070 . 387) '(1070 . 3) '(1070 . 389) (cons 1010 pIns))))))
	      (strcat "\\O"
And this is the small variation that best fits what @leonucadomi is asking for, I think.
With the peculiarity that the "jog" will be placed where the selection is made with the pickbox.
(defun c:ltx (/ e o s le to l)
  (while (and (setq e (car (setq l (entsel "\rSelect a TEXT, MTEXT or DIMENSION...")))) (wcmatch (cdr (assoc 0 (setq le (entget e)))) "*TEXT,DIMENSION"))
    (cond
      ((= "TEXT" (setq to (cdr (assoc 0 le))))
	 (strcat "%%O"
      ((= "MTEXT" to)
	 (strcat "\\O"
      ((= "DIMENSION" to)
       (entmod (append le (list (list -3 (list "ACAD_DSTYLE_DIMJAG_POSITION" '(1070 . 387) '(1070 . 3) '(1070 . 389) (cons 1010 (cadr l)))))))
	   (strcat "\\O"
Edited by GLAVCVS
  • Thanks 1
      (cond
               (strcat "%%O"
         ((= "MTEXT" to)
               (strcat "\\O"
         ((= "DIMENSION" to)
	      (strcat "\\O"
I love this, it's excellent, thank you
