BCDJOHN123 Posted September 24 Posted September 24 Hello, I have AutoCAD LT and created a new template this week, but I'm having an issue when saving .dxf files to be sent to our laser cutter. When the drawings are converted from inches to mm and saved, they are over 2000 KB, and the drawings do not appear on the laser computer. Our usual file size after converting and saving is around 200 KB. I am able to save the same drawings in our previous templates and send them to the laser, no problem. I have done PURGE, AUDIT, and selected all to make sure there are no unaccounted-for objects. All the save and plot settings under OPTIONS match up with the template that saves the .dxf correctly. What am I overlooking? An issue that occurs when adjusting the DWGUNITS? A preference for saving formatting? Quote
SLW210 Posted September 25 Posted September 25 Hard to say without a drawing to look at. Most likely something to do with going from inches to mm, what is the process for doing the conversion? Quote
BCDJOHN123 Posted September 25 Author Posted September 25 On the drawing, I do the DWGUNITS command and change units to (3) millimeters and press enter for all the other settings. When it converts, it will disappear from view, and I'll usually double-click the mouse scroller to find it. Quote
BIGAL Posted September 25 Posted September 25 Does not sound right an inch is 25.4 mm. So need to scale accordingly using that factor. Zoom extents should find. Post a dwg as suggested. Quote
CyberAngel Posted September 26 Posted September 26 13 hours ago, BIGAL said: Does not sound right an inch is 25.4 mm. So need to scale accordingly using that factor. Zoom extents should find. My guess is they mean they set their DWGUNITS variable to 3, which changes units to mm. But it doesn't sound like that's the real problem. They mentioned a new template, may be something there. Quote
