switch to turn on or off a variable
hello :
I use this code to quickly change a variable on or off. I would like to know if someone can improve it in appearance or functionality.
Quote
(defun c:SF (/  gira)
(repeat 100
(setq gira (getreal "\nActiva UCS FOLLOW  <1>: "))
(if (equal gira nil)(setq gira 1))
(if (= gira 1)
(Command "_UCSFOLLOW" "1" "")
(princ "\nUCS Follow Activado")
(setq gira (getreal "\nDesactiva UCS FOLLOW  <1>: "))
(if (= gira 1)
(Command "_UCSFOLLOW" "0" "")
(princ "\nUCS Follow Desactivado")
);repeat
  );fin defun
'repeat 100...'?
Changing the same variable 100 times...why?
I guess that's a mistake.
Something simple: every time the command sf is called, UCSFOLLOW changes state, without asking
(defun c:sf (/ act)
  (setvar "UCSFOLLOW" (if (setq act (= (getvar "UCSFOLLOW") 0)) 1 0))
  (princ (strcat "\n*** Variable UCSFOLLOW " (if act "activada" "desactivada")))
  • Thanks 1
Or this, for toggle
(defun c:SF ( / )
  (if (zerop (boole 1 (getvar "UCSFOLLOW") 1))
      (setvar "UCSFOLLOW" (1+ (getvar "UCSFOLLOW")))
      (setvar "UCSFOLLOW" (1- (getvar "UCSFOLLOW")))
  (prin1)
  • Thanks 1
Another -
(defun c:sf ( )
    (setvar 'ucsfollow (- 1 (getvar 'ucsfollow)))
  • Thanks 1
On 9/26/2025 at 4:52 PM, GLAVCVS said:
'repeat 100...'?
(defun c:sf (/ act)
'repeat 100...'?
(defun c:sf (/ act)
I do it by repeating it 100 times because I don't know how to make a routine repeat itself indefinitely until I execute escape.
What I'm looking for is not to have a routine that turns it on and one that turns it off, but rather a single routine that, like a roulette wheel, allows me to change the state of the variable just with enter
Another way, taking advantage of @Lee Mac's idea and condensing an output message for the user
(defun c:sf (/ v)
  (princ (strcat "\n*** " (setq v "UCSFOLLOW") (nth (setvar v (- 1 (getvar v))) '(" desactivado" " activado"))))
Edited by GLAVCVS
  • Thanks 1
Another way not as compact but a little easier to read/follow. Would also handle if uscfollow wasn't 1 or 0 Tho i don't know when/if that would ever happen.
;; Toggle UCSFOLLOW using COND
(defun c:foo (/ v)
  (setq v (getvar "UCSFOLLOW"))
  (cond
    ((= v 1) ;; If it's currently ON turn it OFF
     (setvar 'UCSFOLLOW 0)
     (princ "\nUCSFOLLOW Desactivado")
    ((= v 0) ;; If it's currently OFF turn it ON
     (setvar "UCSFOLLOW" 1)
     (princ "\nUCSFOLLOW Activado")
    (T ;; If it’s some unexpected value, default to OFF
     (setvar "UCSFOLLOW" 0)
