cadnub Posted September 27, 2025 Posted September 27, 2025 I am using (command "_.BREAK" pause "_F" "0,0.3" "0,-0.3") On the pause I am selecting a vertical line that spans well past the first and second point. When I got run this command and I select the line, I get this error BREAK Select object: Specify second break point or [First point]: F Specify first break point: 0,.3 Specify second break point: 0,-.3 Command: nil It doesn't break how I expect it to. If I run this command manually as in I manually type in the first and second points, it works but as soon as I try to run that single command line, it doesn't break properly. This is eventually part of a bigger lisp routine but I am getting hung up on this. Any thoughts? Quote
BIGAL Posted September 28, 2025 Posted September 28, 2025 I don't understand, if your just picking two points why are you not just doing (command "_.BREAK" "0,0.3" "0,-0.3") Quote
